KTM LC4 (640) Thread Index
Discussion in 'Thumpers' started by meat popsicle, Jul 9, 2005.
  1. PaulBarton
    PaulBarton Long timer Supporter
    Apr 14, 2015
    3,978
    Seattle
    I like the idea of zip-tie'ing it to the nearby fuel line. Not fool proof but should help.
  2. Bowser
    Bowser Been here awhile
    Dec 23, 2007
    372
    Gloucester
    why not just replace the connector or better still add a connector in line in the wire a standard 12v round male/female connector, like below,
    if you firmly attach one side to the tank with a cable tie, if you pull tank off without first disconnecting then it will just pull apart no problem
    its not a circuit that takes high current, so any kind of simple push on connector will work.
    Whodatschrome likes this.
  3. PaulBarton
    Apr 14, 2015
    3,978
    Seattle
    That’s not a bad idea. I might practice with my “spare”
  4. dunc289
    dunc289 Been here awhile Supporter
    Apr 14, 2011
    186
    Westside Los Angeles
    Fuel line tip.
    That super expensive ($25 per meter) ID 7.5mm braided fuel line the ADV uses about 2 yards of...
    Is also available as a vintage Porsche 911 part for about $5 per meter.
  5. Whodatschrome
    Whodatschrome Long timer
    May 4, 2015
    4,513
    North of North Plains
    Or file down the existing locking tab a little bit on the original connector?
  6. Bowser
    Dec 23, 2007
    372
    Gloucester
    the problem is that you can never "unfile" it if needed also it is designed to be a friction fit, where as the push together 12v connectors they are used in heated clothing and designed to pull apart if you forget to disconnect getting off the bike.
  7. Whodatschrome
    May 4, 2015
    4,513
    There's also lots of options here... https://www.corsa-technic.com/category.php?category_id=125 I don't know how well those 12v connectors (as in the heated gear style) holds up to mud/water/dust/pressure washer.
  8. PaulBarton
    Apr 14, 2015
    3,978
    Seattle
    Or if you “forget” to plug them back in when putting the tank on and the +12v wire shorts to ground.
  9. Whodatschrome
    May 4, 2015
    4,513
    It shouldn't short out, but when you get low on fuel your 12v heated gloved might automatically turn on.
    bikemoto and PaulBarton like this.
  10. Bowser
    Dec 23, 2007
    372
    Gloucester
    not likley if you wire it correctly, it can be the inside of the female part and never touch a thing, besides which less of an issue than taking the tank off and ripping either the connector off or wires out of the sensor in the tank, same for the question above, no they are probably not very warter/dust/pressure washer proof, but what the hell does it matter you can buy 10 for £6 they are pretty much disposable, the point is to save the cost of replacing way more expensive parts.
    drhippie2 likes this.
  11. Desert Silver
    Desert Silver Desert Rat
    Jul 27, 2007
    117
    Ash Fork AZ
    Anybody ever have the center stand rub on the brake side of the swing arm? I think that side of the center stand got bent inwards on shift side when it fell over while up on the center stand. I've tried to bend it out wards but haven't been able to.
  12. Racer322
    Racer322 Adventurer
    Dec 2, 2020
    25
    NJ
    Hey all, I'm a current 950 owner that I am finishing a frame-off restoration on and I should be completed soon. With that said, I am in the process of purchasing an 06 640 Adv. What Scott's damper kits are readily available for the 640 Adv? I'd prefer to not swap out the upper triple clamp. Also, does anyone have an OE tool kit and OE roadbook holder that they'd like to sell me? Let me know. Really looking forward to having this bike to complement my 950 for when I want to do tighter off road areas. Thanks
  13. skibum69
    skibum69 slave to gravity Super Supporter
    May 14, 2006
    15,577
    New Melbourne, Newfoundland
    Mine took a new upper clamp when I installed it.
  14. Whodatschrome
    May 4, 2015
    4,513
    Yes. You can slip a pipe over the leg of the centerstand and pull it back where it needs to be.
  15. Whodatschrome
    May 4, 2015
    4,513
    The only "readily" available is the Scotts upper triple mount that Skibum posted up.
    Emig Racing has a fancy damper and mount kit, but i don't know how readily available it is. http://www.emigracing.com/ktm-640-adv.html
    Stenhouse used to make and inexpensive one many years ago, but he's not making them again. http://stenhouseracing.com/shop/index.php?main_page=product_info&products_id=6
  16. Quazzymoto
    Quazzymoto Adventurer Supporter
    Sep 19, 2019
    48
    Harrisville, New Hampshire
    Looking for the BST40 Bible. supposedly the Bible for rebuilding this carburetor Anyone have a link to it I was told it was in ADV rider and can’t seem to put my fingers on it Thanks...
  17. Antti
    Antti Been here awhile Supporter
    Mar 14, 2003
    681
    Finland
  18. motolab
    motolab Long timer
    Feb 16, 2006
    7,221
    Make sure you read it back to front rather than front to back.
    Regards,
    Derek
    PaulBarton likes this.
  19. docwyte
    docwyte Long timer
    Dec 23, 2012
    3,188
    Denver, CO
    Stenhouse isn't making their mount anymore and has none in stock. Not sure about the Emig unit but it also replaces the triple tree. I had it on my last 640 and it was a nice unit but I do prefer the scotts damper...
  20. PaulBarton
    Apr 14, 2015
    3,978
    Seattle
    I have the Emig set-up on mine with HDB top plate/hand guards. It works as proclaimed. I have the Emig offset top brace too. Not sure how “readily accessible” it is but a quick phone call should clear that up.
