KTM LC8 Air Filter Kits by SW7
Discussion in 'Vendors' started by Sporting Wood, Mar 14, 2013.
  1. OldDog
    OldDog non impediti ratione cogitationis
    Feb 20, 2005
    6,934
    Kalgoorlie, Western Australia
    Placed an order with Chris a while ago and received fairly prompt communications about the order the whole way through. Had to can the jet portion of the order as FP were stuffing Chris around just too much and it was holding up the supply of the rest of the kit. Chris ended up sending me just the filter kit and the sock, which is excellent quality I must say. With the aid of this thread and the Aussie 950 thread i'll get it tuned to acceptable then throw the bike on the dyno.
    Thanks again Chris, much appreciated!
  2. Lumberjeff
    Lumberjeff River City MC
    Dec 21, 2012
    401
    Tacoma, WA
    Chris - PM sent for a new filter.
  3. Sporting Wood
    Sporting Wood I
    Oct 18, 2011
    918
    Horneytown, NC
    Hi guys, I have been sorting through some backorders but am completely restocked and everything is out now. Sorry for the delays. We sometimes have long delays getting filters through customs!
  4. STANIMAL
    STANIMAL SUPPORT THE SECOND Supporter
    Oct 12, 2009
    3,317
    Northbrook IL
    Did you have any seals available ? That go between the mount and the carbs to take the slack out .
  5. Sporting Wood
    Sporting Wood I
    Oct 18, 2011
    918
    Horneytown, NC
    Yes, sure do.
  6. ericlemonde
    ericlemonde FrenchCanadian63
    Sep 19, 2012
    10
    Calgary
    Chris, since you have them now can you please send me those seals i am missing from the kit together with the o rings. This was all paid for with the original order.
  7. montibank
    montibank Happy
    Feb 7, 2007
    3,191
    Fresno, Ca
    Still loving mine! (maybe 7k miles later? maybe more?)
    Sent from my SM-G930P using Tapatalk
  8. SloBee
    SloBee n00b
    Aug 10, 2015
    2
    Slovenia
    What kind of carbs do you have my 07 950smr has the Keihin cvrd43 and I simply cannot find the jetting for it,...
    Any advice? Thank you in advance.
  9. ManuC
    ManuC 950 SM
    Dec 20, 2013
    267
    Ardennes Belgium
    Look at Bhir
    KEC for the mains
  10. ABuck99
    ABuck99 0.0
    Feb 21, 2009
    800
    Georgia
    Have you tried asking your KT'M dealer? If it's jets only im sure they prob have jets. Or Buy the kit from factory pro.
    STANIMAL likes this.
  11. Pitster
    Pitster miniac
    Aug 15, 2007
    928
    I could really use some jetting advise!!
    I have a 08 Se 950 with the rottweiler system installed, all emission junk removed. Remus 2 into 1 exhaust.
    Trying to find the correct jetting. Most of my riding is between 4500ft and 9000ft.
    I have recently just installed the 45 pilots and 170/175 mains. During the first little 5 minute run , it seemed like I was very close, then after a run up to red line it started acting like it was starving or surging for fuel (sputtering under acceleration ) I keep reading mixed results of running the 42s or the 45s. I am confused!!
    Before the recent change, I was running 42 pilots, with 165 and 170 mains. It seems to run good on top end, but at mid throttle and lower RPM it would surge very bad. If I pulled the choke in the surging was less ( meaning its lean ) Also when a heavy wind gust would hit me the surging would increase, as if too much air was being rammed into the intake.
    I would appreciate and help and suggestions you can send!! Thank you!
    I am beginning to wonder if I have something else wrong besides a jetting problem?
    Thanks!!
  12. ABuck99
    ABuck99 0.0
    Feb 21, 2009
    800
    Georgia
    42 pilots
    Get your mains under 170 for that altitude-and floats set lean.
    I got very good performance with 42 pilots, mains 162 rear and 160 front, clips at #3 and 2 turns out on the mixture screws ( flex jets best to fine tune). Floats at 4mm. This set up worked great from 4500ft-13,000 feet.
    Bonnie & Clyde likes this.
  13. Pitster
    Pitster miniac
    Aug 15, 2007
    928
    Thanks so much! You are running a similar set up right? 2 into 1 and rottweiller air filter system, no emissions.
  14. ABuck99
    ABuck99 0.0
    Feb 21, 2009
    800
    Georgia
    2-2 set up. And SW7 set up which is same air filter and sas mods.
    Wether 2-2 or 2-1 won't make much if any difference to jetting requirements
    Look up H2W vent hose routing and lengths as this will have a helpful
    Impact on surge- also running the front carb 1/4-1/2 turn richer also helps with lean surge. Also correct float height helps with lean surge. And lastly carb synch and TPS adjustment will have some impact on throttle response.
  15. BoGaRa
    BoGaRa Adventurer
    Nov 23, 2007
    91
    WIndsor, Canada
    Would this setup fit on 990 SMT?
  16. crofrog
    crofrog Long timer
    Sep 26, 2007
    1,473
    Annapolis Maryland
    Fuck no toil... The ITG filter started falling apart. I should have trusted my gut and just used twin air liquid power like I do on all the other filters. I've never had a good experience with notoil
  17. alvincullumyork
    alvincullumyork Ol Two Flags Supporter
    Feb 26, 2012
    17,879
    Richland WA
    I was using NoToil for quite some time with my filter and no problems aside from the fact it was a pain in the ass to clean. That's more due to the filter design than NoToil though.
  18. crofrog
    crofrog Long timer
    Sep 26, 2007
    1,473
    Annapolis Maryland
    Define "quite some time" I've got filters from 2004 that have only used liquid power and look as good as new. And I've got a few year old ITG that's crumbling.
  19. ABuck99
    ABuck99 0.0
    Feb 21, 2009
    800
    Georgia
    Crofrog- Wondering what you clean the filter with and how often? These filters can take a lot of dirt & dust before loosing performance .
    FWIW Ive been using either twinair filteroil or Maxima Fab-1 on the ITG and small bikes. Clean filters with Maxima air filter cleaner ( sometimes chain cleaner - it's the same formula as the filter cleaner) then follow with dawn dish soap to clean out any remaining filter cleaner. 3 years and no filter issues yet.
  20. crofrog
    crofrog Long timer
    Sep 26, 2007
    1,473
    Annapolis Maryland
    I clean it about every 5000 miles or so, using the no toil cleaner. This has been my experience with quiet a few filters using no-toil products.
    Yeah I use twin air liquid power and the liquid power remover on most other filters with no issues.
