1. eNewsletter Sign Up
KTM LC8 Exhaust and Auxillary Tank
Discussion in 'Vendors' started by neduro, Jan 20, 2008.
  1. dad2bike
    dad2bike Retired! Cranky Old Fart Supporter
    Aug 12, 2007
    16,661
    Las Vegas, NV
    I ended up just doing the one side. This gives me enough room to get the cap off good. :D
    I uses hand saw to cut the bracket from the pannier loop. I then swung it back as close as I felt good to the turn signal. Welded and cleaned up there. Only part I took off was the bracket to contour the notch. I used a grinder and fine sandpaper to clean up. Then painted all with simple Black gloss paint.
    Edit: Do the job BEFORE putting the tank on. You can see the scratches I put on the aux tank with the sandpaper.
  2. crazybrit
    crazybrit Long timer
    Mar 16, 2006
    8,919
    Portland, OR
    If you'd looked at the other thread, you basically answered my question :D Pics are very useful but they'd be useful on that other thread also :D
    Anyways, thank very much you've confirmed what I was thinking of doing. Also I was planning on just taking the rack off and using the rear rack/plate to maintain alignment (as the guy did on the other thread). I'm surprised you tried to do it on the bike.
  3. dad2bike
    Aug 12, 2007
    16,661
    Las Vegas, NV
    What other thread???
    Give me a link.
  4. dad2bike
    Aug 12, 2007
    16,661
    Las Vegas, NV
    Trying to mind read a Brit is like Playing football with a monkey. :eek1
  5. EdGear
    EdGear Edventurer
    Oct 31, 2008
    671
    Bay Area, CA
    I just found a good deal on some Hepco Becker Standard Aluminum Cases. Really well built but when I tried to mount it on my 990 with the AdvTank I ran into a major problem, the aux tank was in the way. Very depressing.
    See how the cross bar can't go down enough to meet the side rack and the cross bar towards the center mount does not meet the fender.
    I did a little research and another advrider inmate had a good suggestion (possibly in this thread), move the tank inwards, a little bit. I moved the rear end of the aux tank in towards the wheel about 5mm (there is still plenty of swing arm clearance and I plan to add a brace to prevent any further flex), then I spaced the rear cross bar up about 5mm from the fender. The path of the rear upper cross member just touches the tank. I added a patch of curly velcro to the tank to take the brunt of any abrasion. Velcro is very abrasion resistant and is cheap to replace. To level out the rear luggage plate I added spacers on top of the grab handles. (adding spacers under the grab handle base changes the spacing too much and does not work, I know this because...)
    Drat! I left out a spacer, not done yet.
    With the modified HB installation the filler cap is much more accessible than with the Gobi racks.
  6. Vicks
    Vicks gets stuck in sand
    Oct 4, 2006
    3,397
    gone RTW...
    So, whats the status of the tank deliveries ? Are they in stock ready to be shiped out OR is there a lead time ?
    thx
  7. FORE!
    FORE! Dakar Vet, but that's not what defines me
    Sep 27, 2007
    61
    the dog house
    We are anticipating having the next batch in stock by late March.
  8. boerdi
    boerdi n00b
    Sep 25, 2003
    5
    so, finally i got the 2 into 1 with an akrapovic (without cat) and the aux tank.
    i own a 990 R (2010). can anybody tell me if i need the akra-mapping with 2 in 1 + akra without cat, or can i leave the original mapping?
    thanks for help
    cheers, boerdi
  9. hvman
    hvman Been here awhile
    Jul 13, 2009
    185
    Ridgefield, WA
  10. Vicks
    Oct 4, 2006
    3,397
    gone RTW...
    are tanks in stock ready to be delivered now ?
    cheers
  11. chrish4ku
    chrish4ku Long timer
    Jul 30, 2009
    1,014
    San Leandro, CA
    Love the 200 Plus mile range of my 990 now!
    FYI - I believe I have the KTM racks on this bike: I am NOT sure if this pattern will work with other racks if the design is different. I am running the Heidenau K60 Scout Rear Tire.
  12. robdogg
    robdogg turnip truck driver Supporter
    Jan 29, 2004
    2,210
    wren-tonne, WA
    couple of questions..
    1. Are these readily available now? i.e. no waiting for the next production cycle?
    2. any fitment issues with Jesse luggage on a 990A?
    3. is there a version 2 or anything done to improve some of the swingarm and/or cap clearance issues?
    4. have the instructions improved?
  13. FORE!
    Sep 27, 2007
    61
    the dog house
    :d
  14. Parx400
    Parx400 Long timer Supporter
    Jun 17, 2010
    7,441
    Sacramento CA
    Anyone know if the tank fits with wolf man racks?
  15. EdGear
    EdGear Edventurer
    Oct 31, 2008
    671
    Bay Area, CA
    Yes, I have an 06 950 Adv S with the Neduro aux tank and Wolfman racks.
    They work really well together.
    Good fuel access
    That small dent near the cap is from rubbing when I had a SW Motech rack. See my post above. Got rid of the hard cases and bought Wolfman soft bags.
    There is lots of room between Wolfman rack and tank.
    When putting on Wolfman bags I start on the tank side and do the bottom two first with the bag tipped slightly out so I get better visibility. I do the rear upper first, because the front has more room to work with.
    Some people worry that the tank will bend inward into the path of the swing arm when fully loaded.
    I put a bracket on the passenger footage and ran a bolt over to the lower mount.
  16. Parx400
    Jun 17, 2010
    7,441
    Sacramento CA
    You sir are awesome. Now I just need to find a set.
  17. Parx400
    Jun 17, 2010
    7,441
    Sacramento CA
    I have been trying to find a set of wolfman racks for ever now. Anyone know of others that fit with the ADV tank? Maybe the Tusk or the moose racing ones?
