KTM SuperMoto wheels
Discussion in 'Parts' started by sceep, Aug 20, 2019.
Thread Status:
Not open for further replies.
  1. sceep
    sceep Long timer
    Jun 15, 2010
    1,392
    Edgewood NM
    KTM 950 SuperMoto wheels for sale. $900
    17x5.5 Excel rear with 180/55 zr17 pirelli scorpion. Pretty worn but has a little life left.
    17x3.5 Excel front with 120/70 zr17 pirelli scorpion. Not as worn. Will last the rest of the season I'd guess.
    Removed from my 950. Unsure what other bikes they will fit. Do your research.
    Will ship on your dime. Located in ABQ, NM. (when I bought these it was roughly $200 to ship them from the NE)
    Can remove tires for shipment to save you some $.
  2. ncj01
    ncj01 Long timer Supporter
    Nov 1, 2006
    1,019
    NW Arkansas
    rear will not fit any model smaller than a 950, free FYI-
    Front will fit the small bikes, given you use the small bike axle spacers, axle, and rotor.
    Xcelite and OneTireFryer like this.
  3. sceep
    sceep Long timer
    Jun 15, 2010
    1,392
    Edgewood NM
    Thanks for the info.
    I was 95% sure when I bought them from here they had come off a 450. But I can be wrong. Will edit.
  4. Xcelite
    Xcelite Been here awhile Supporter
    Oct 6, 2014
    160
    Corner of No and Where.
    Is the front wheel compatible with the OEM dual brakes? I don't see a second rotor on it.
  5. ncj01
    Nov 1, 2006
    1,019
    NW Arkansas
    if willing to seperate, i may be interested in the rear
  6. sceep
    sceep Long timer
    Jun 15, 2010
    1,392
    Edgewood NM
    It is single rotor, I ran them on my ADV. Remove right side caliper and hose. Install short single fitting banjo bolt @ master cylinder. It does make the lever much more firm but I never noticed any reduction in braking ability. Put close to 5k miles on them on 2 different bikes.
  7. Whodatschrome
    Whodatschrome Long timer
    May 4, 2015
    3,004
    North of North Plains
    Is the rear carrier included? What sprocket gear ratio did you use?
  8. sceep
    sceep Long timer
    Jun 15, 2010
    1,392
    Edgewood NM
    Rear cush drive is not included.
    17/42 is what I ran.
    #8
Thread Status:
