LC front brake caliper rebuild?
Discussion in 'GS Boxers' started by marchyman, Jun 19, 2019.
  1. marchyman
    marchyman barely informed Supporter
    Jun 30, 2005
    11,949
    SF Bay Area
    Does anyone have experience with a a front brake caliper rebuild on an LC bike?
    I feel/hear a click when slowly pulling of the front brake lever of my '13 GS wethead. If I put fingers on the right brake caliper I can feel the click. I suspect the piston is sticking or I've a bad seal or something like that. In searching the net I've not found anyone who's re-built LC front brakes nor have I found a front brake rebuild kit. Perhaps my search-fu is weak. The beemer shop does have a kit but their site claims it is for '05-'12 bikes.
    I'd appreciate hearing from anyone who has torn into their front caliper. Any issues or words of wisdom?
  2. attila_66
    attila_66 Been here awhile
    Jan 3, 2009
    101
    Izmir, Turkey
    34118556200 This part no is piston with seals. No.11 on the picture.
    SmittyBlackstone likes this.
  3. b_rubenstein
    b_rubenstein Been here awhile
    Apr 4, 2018
    157
    Melbourne, FL
    Keep in mind that these brakes have fixed calipers and a floating rotor The click is probably the rotor shifting. My '17 makes the same click when I pull the front brake lever when the bike isn't running or moving.
  4. marchyman
    Jun 30, 2005
    11,949
    SF Bay Area
    Thanks. Except for the cost. $166.51
    I think I'll wait until I put things apart before I order the entire kit. I may only need new seals. Assuming I can find a place to buy seals, only.
    I found this video on rebuilding a similar Brembo caliper.
    I don't think that is the issue but I'll be sure to check again. For one think I only get the click from the right side and I certainly can feel it in the brake lever. when it happens.
    nobody0101 likes this.
  5. LAFS
    LAFS Long timer
    Dec 15, 2016
    1,658
    Have you looked at the switch on your brake handle? You know that little plunger in the handle? It could be that. Also have you checked the cable and the retaining end of the cable where it goes into the slot of the handle?
  6. KHud
    KHud Survivor Supporter
    Jun 24, 2008
    4,491
    The Outpost, Silver City, Montana
    This guy specializes in Ducati bikes, but there is crossover in Brembo parts. Email him and he may have seals and pistons for your caliper. It is quite possible you can just clean the caliper and solve the problem. Remove the caliper from the bike; put a spacer between the pistons to prevent them from coming out; use compressed air to force the pistons out as far as the spacer allows; clean with brake fluid and an old tooth brush. If the the pistons have build-up that the tooth brush will not remove then use fine steel wool.
  7. b_rubenstein
    Apr 4, 2018
    157
    Melbourne, FL
    To get a metallic click sound, something metallic has to hit something else metallic. About the only way to get a metallic click from one of those calipers is to have loose caliper mounting bolts, or a pad shim moving. The only moving parts in the caliper are the pistons and typically sealed with a square section O-Ring in their bore, so there is no metal to metal moving parts in the caliper to cause a click.
    It's obvious that you've decided its a problem with a caliper based upon having a rather tenuous understanding of how the front brakes work and what parts do what. Have fun.
    Steve W. and JimVonBaden like this.
  8. LAFS
    LAFS Long timer
    Dec 15, 2016
    1,658
    So you do know these are floating rotors right?
    Your metal statement is not true at all as a rotor can make noise with no brake applied if the buttons that float loosen up over time. It can also make noise when the brakes grab a loose floating rotor to a stop.
    #8
  9. marchyman
    Jun 30, 2005
    11,949
    SF Bay Area
    Did I say metalic? I suspect I've got a piston hanging up on the dust seal and breaking free when enough pressure is applied.
    #9
  10. LAFS
    LAFS Long timer
    Dec 15, 2016
    1,658
    Sometimes a good cleaning is all that is needed. That is where I would start. I do mine every time I change tires. They will build a ridge but I am not sure that would cause a vibration. In the last pic you see the pin the pads slide on, that can become very caked up. I sand it with 200-400 grit paper and use a high temp copper grease on all the slide points and that pin. Liberal use of brake cleaner is called for on this project.
    #10
  11. marchyman
    Jun 30, 2005
    11,949
    SF Bay Area
    That is what I'm hoping. If it is something like crud built up on one of the pistons a cleaning may be all that is needed. Or maybe it not a piston, but a brake pad hanging up on something. In any case I'm not going to disconnect the caliper from the brake lines until I know I have to, if for no other reason that getting all the air out of calipers that have been drained can be such a pain. My asking for pointers is a boy scout thing: be prepared.
    I will also be replacing a rear disk... it will be at the specified minumum just about the time the bike is due for a service. Seems I get about 50K miles per rear rotor. Got that on my '05. Am getting that on my '13. Pretty linear wear of about 0.01 mm/1000 miles.
    #11
    LAFS likes this.
  12. antariusjp
    antariusjp Large Title Here
    Mar 22, 2015
    239
    Bay Area, California
    Just remember most brake cleaner is, believe it or not, not good for rubber parts - like the seals you're trying to protect. Just regular dish soap, warm water and a soft tooth brush will work just fine when you clean the pistons.
    #12
    OzRider64 likes this.
  13. LAFS
    LAFS Long timer
    Dec 15, 2016
    1,658
    Brake cleaner will not affect brake piston seals.
    I was told that strait from a Brembo car brake rep many years ago.
    Good thing as I been cleaning brake calipers on cars and motorcycles for 40 years with brake cleaner and never had a piston seal fail.
    As a matter of fact I have never had a caliper fail in any car or motorcycle I have ever owned.
    Of course I run summer and winter wheel/tires on my car so when I swap wheels the calipers get cleaned so been doing that for 25 years or so.
    I guess preventive maintenance pays off.
    #13
    roookie1 and JimVonBaden like this.
  14. JimVonBaden
    Feb 11, 2005
    85,359
    Alexandria, VA
    Agreed. I question whether this is a caliper failure, or something else?
    #14
    roookie1 likes this.
  15. marchyman
    Jun 30, 2005
    11,949
    SF Bay Area
    It is not a failure, more of an annoyance. And yes, it could be something else. As noted above I simply want to be prepared should it turn out that I need to replace seals, etc.
    #15
    LAFS and JimVonBaden like this.
