LC4 footpegs
Discussion in 'Thumpers' started by ncfitton, Jun 24, 2004.
  1. docwyte
    docwyte Long timer
    Dec 23, 2012
    2,587
    Denver, CO
    I have a set of fastway adv pegs from my BMW dakar, will they fit on the 640?
  2. JParanee
    JParanee Adventurer
    Sep 5, 2013
    60
    I just put these on
    They are certainly big enough :)
  3. supercoyote
    supercoyote Been here awhile
    Jun 28, 2012
    136
    Edmonton, AB
    Anyone have a lead on the left hand brackets? Looked and looked and have yet to find anything
  4. Queen of Spades
    Queen of Spades tall drink of water
    Mar 20, 2009
    1,939
    Decatur, GA
    I got mine from KTM Parts Warehouse a few months ago. Price may have gone up since or it may not be available anymore, check their fiche and see.
    KTM Part Number: 58403038100
    Description: FOOTREST BRACKET LEFT ALU 05 for 2004 KTM 625 SXC
    Order Quantity: 1
    Unit Price: $43.65
    Total Cost: $43.65
    http://www.ktmpartshouse.com/
  5. Droptarotter
    Droptarotter Long timer
    Jul 11, 2007
    2,186
    Cloverdale,BC
    Where did you get these??
  6. docwyte
    docwyte Long timer
    Dec 23, 2012
    2,587
    Denver, CO
    Those look like the CJ Designs peg extensions...
  7. Baggi'tard
    Baggi'tard If I don't answer I'm ridin' or shootin' Supporter
    Sep 20, 2006
    3,199
    Farmhouse Inn, Tellico Plains, TN
    Thought I would post an update to this thread. Just added new pegs to my 2000 640. Got them for $57 shipped off eBay, fit really well width wise, just needed a little grinding so they would fold up a bit. Better slightly too big than small! They even came with 10 or 12 new screw cleats. I bought the left footpeg bracket listed below, new bolt/pin, and new springs (the stock left one is all wrong). Springs needed one of the legs shortened a bit, but other than that fitment was straight forward. And the new bolts you need are actually socket cap 10M x 60mm (not 65 or 70 as posted above). 60mm fits perfect, about 2-3 threads showing past nut. (I think somebody measured the total length...)
    58403038100 - KTM
    54803044000 - KTM
    BOLT FOR FOOT PED 03
    Unlike the old one, these are actually damn near level!
    Shooter1 likes this.
  8. biensur22
    biensur22 litigious poster
    Oct 26, 2011
    183
    Denver, CO
    Those look identical to the tusk pegs, but for the color.
  9. Whodatschrome
    Whodatschrome Long timer
    May 4, 2015
    3,010
    North of North Plains
    I'm bringing this thread back to life...
    I just got that aluminum footrest bracket from RMATV (58403038100 - KTM FOOTREST BRACKET LEFT ALU 05). It's being bolted to a 2003 625 SXC that originally had that odd ball steel bracket. Like Baggi'tard pointed out, 60mm allen head bolts are the perfect length.
    But....if you want to use actual KTM bolts instead of just "hardware store" bolts, the KTM part number for them is #0035100609S (AH-Collar screw M10x60 ISA45). KTM uses them on a 2014 1190 ADV. To find the location that they're used, go to the 1190 ADV chassis parts fiche and look under "Tank, Seat, Cover". It's item #51 on the list. It's used for bolting the tank protectors to the fuel tank.
  10. Parx400
    Parx400 Long timer Supporter
    Jun 17, 2010
    7,123
    Sacramento CA
    Old thread but does any one have pics of the left side sxc mount where it’s been trimmed to accept the Fastway peg? I got mine mounted but it won’t pivot. I clearly need to take some material off.
  11. Droptarotter
    Jul 11, 2007
    2,186
    Cloverdale,BC
    If the Fastway peg is like my Warp9 pegs, you don't trim the mount, you file the footpeg to make it pivot.
    I'm going by memory, so be cautious...........file your new footpeg to match the peg you removed. You should see where the pegs differ where they contact the peg mount and have to go in the peg mount recess.
    If I'm wrong, send me a PM to remind me to take a photo for you later.......maybe include your email to make it easier for me.
    Cheers
  12. Parx400
    Jun 17, 2010
    7,123
    Sacramento CA
    Got them mounted but Im going to swap over the adventure pegs from my 990. In the low position my right food is hanging way off the standard fast way pegs.
    The adventure pegs are going to require a bit more grinding on the left side. Right side went right on.
  13. Parx400
    Jun 17, 2010
    7,123
    Sacramento CA
    ADV pegs went on with a lot of work. Pray to go to didn’t grind off too much of the peg or mount.
  14. Whodatschrome
    May 4, 2015
    3,010
    I just saw your posting Parx. So does your bike currently have the original SXS left side bracket, or the newer 640A bracket? When i mounted my Fasway F3 pegs on my '07 640A, i ground down the peg bracket some to get the peg to fit (i have them mounted in the upper position, so that there's more peg to ground clearance). When i swapped a left side 640A bracket onto my friend's SXS, it was simple for the only reason that i used a stock 640A peg with a CJ Designs peg extender. On another friend's '05 640A, i ground down his aluminum Warp9 peg to fit his left bracket.
    EA1434A6-A795-43F0-9600-F29C41B007E7.jpeg 33A9C6DA-80A5-4B8B-ABAB-24695AF0CD49.jpeg
  15. Parx400
    Jun 17, 2010
    7,123
    Sacramento CA
    As in the 2004 up bracket ? If so that is what I have. There are only two right?
  16. Whodatschrome
    May 4, 2015
    3,010
    I didn’t mean to cause confusion, but Yes, there are only two versions.
    I also added a couple pics above. ^^^
