LC4 Spark Plug Socket
Discussion in 'Thumpers' started by b17flyguy, Apr 21, 2006.
  1. braaap!
    braaap! Long timer Supporter
    Mar 16, 2005
    4,374
    Here and There
    I've changed oil over a dozen times... always a new crush washer and a torque wrench... never had a problem (bit like changing plugs) finger tight then nipped up, slow and even pressure.
    The main drain bolt required that much force to undo... I 'pooped' a little bit when it came free!....
    Mechanics under pressure to turn around each job against the clock... where's the torque wrench?.... aw fcukit! gnaa-ahhh! Shit! have we got some 3Bond.... that'll do.... next!
    I like the grease on the drill and tap advice... cheers Donkey! Now where's my Uriah Heep cassettes?.... :lol3
    #21
  2. Donkey Hotey
    Donkey Hotey De Jo Momma
    Aug 18, 2005
    14,949
    20 Mule Team Trail (Palmdale, Ca)
    Yup, exactly the same as mine. And when it came out, the threads were still attached to the bolt. That's what I'm saying: I think there may be something different about the plating on that particular drain plug that causes the corrosion. I don't remember how many times I've seen that same problem with the same bolt for people on here. If over-torquing was really the problem, they'd have failed upon installation, not on removal.
    #22
  3. meat popsicle
    meat popsicle Ignostic
    Feb 9, 2004
    14,584
    Circumlocution Office of Little Dorrit
    :lol3
    I tend to think its like braaap! says with the mechanics, or when owner's doing it themselves have some pile of shit on their mind, and they go out to do a little Zen and the Art of Motorcycle Maintenance without warming up properly! My mind was obviously not clear when I set the direction on the ratchet...
    If there was a systemic problem with an oil drain plug it would be addressed by KTM. If only the disService Centers would address their problems.
    #23
  4. braaap!
    Mar 16, 2005
    4,374
    Here and There
    Ah Ha! The mag' drain bolt on mine was perfect before the shop did the last change... I put the socket on it expecting it to be as 'effing tight as the large plug.. yet it was only finger tight!.. close inspection on removal, shows silicone / sealant had been applied around the crush washer and head of the drain plug.... :brow
    You could be right that removal of the plug stripped the thread out.. just as easy as it could have been stripped out during the install... Whether KTM metalurgy is suspect, all I'm saying is it's a complete bitch that it happened in the shop... and the simple fact it wasn't communicated or noted on the service sheet.
    If it had of been, I'd be philosophical... shit happens right? at least if it fails near home I can always get a taxi.
    :D
    #24
  5. Deep
    Deep n00b
    Jul 17, 2011
    2
    OMG why would they do that!
    #25
  6. Hurricane Bob
    Hurricane Bob Long timer
    Jun 6, 2007
    3,003
    Rhode Island
    thin walled spark plug sockets in the lawn mower dept at lowes and home depot.
    #26
  7. Donkey Hotey
    Aug 18, 2005
    14,949
    Because 10 years ago, a gifted, clairvoyant engineer in Austria knew that in 2012, somebody would be so shy that it would take them 6 months to spend their first post in a three year old thread. :lol3
    #27
  8. meat popsicle
    Feb 9, 2004
    14,584
    I'll say it - NICE FIND! :beer
    #28
  9. motzingg
    motzingg n00b
    Mar 5, 2014
    4
    sweet!
    bumping this
    the stamped 'screwrench' (scrench) style was my first thought but i don't have the 5/8 one, just the more common 13/16...
    we'll see if this clears the cam bosses on my '89 600 LC4, its more of a height clearance issue thing than diameter, my 18 mm socket just barely fits in the hole, but its too tall to make the turn.
    #29
