Le 'Rapidement'. Bored tracker.
Discussion in 'Some Assembly Required' started by Wildebeest90210, Feb 4, 2016.
  1. Lurkio
    Lurkio Adventurer
    Oct 27, 2015
    10
    The Deep South........of Wales
    You had a damaged hip as a baby? :hide That's tough
    JagLite likes this.
  2. Kai Ju
    Kai Ju Long timer Supporter
    Jul 29, 2009
    4,084
    Long Beach, California
    At least he had a third 'leg' to stand on...
    JagLite, villageidiot and Lurkio like this.
  3. Wildebeest90210
    Wildebeest90210 Long timer Supporter
    May 24, 2013
    3,233
    Yes, sad but true. As you can see if I now try to ride a bicycle I always fall off to the right!!!
    JagLite likes this.
  4. Beezer
    Beezer Long timer Supporter
    Oct 26, 2004
    9,385
    Anchorage, formerly Spenard (hub of the universe)
    I have a special sling....
    it's a constant source of embarrassment for me
    Lurkio likes this.
  5. Kai Ju
    Jul 29, 2009
    4,084
    https://tinyurl.com/y7mcar2h
    Add to Wishlist
    Coping With A Large Penis: Don't Let Your Member Define Your Membership Of Society
    by Hugh Jones
    1 Customer Review
    Absolutely amazing , very helpful. I've been looking for a book o ...
    19 days ago
    Sad-but-Huge
    Absolutely amazing , very helpful. I've been looking for a book or anything that might be helpfull with my day to day struggles living with this babys arm beating up my inner thighs.
    Thank you Thank you Thank you
    • Share
    0
    0
    Paperback
    $21.99
    • Ship This Item — Qualifies for Free Shipping
      Check Availability at Nearby Store
    _______________________________________________________________________________________________________________________
    I found this book to be quite helpfull...
  6. Beezer
    Oct 26, 2004
    9,385
    you see how this haunts my life.... pix of me on page 47 (no face shot). like I said.... a constant source of embarrassment.
  7. Wildebeest90210
    May 24, 2013
    3,233
  8. JagLite
    JagLite Long timer Supporter
    Jun 17, 2010
    8,093
    Anchorage Alaska
    Funny! :imaposer
    more koolaid likes this.
  9. Wildebeest90210
    May 24, 2013
    3,233
    It made it off the bench, don't worry it's back again now. It's a bit lower than expected but then it is a lowrider frame so no surprise really. I found the MTB shop I had build the wheels didn't build in the offset so I've spent this afternoon spacing things out. Just the final drive to do now.
    Also the pedal at full extension didn't clear the front tyre so have shifted the rake out by moving to the set of holes currently used by the headlight mount. Will have to re-mount the light.
  10. DiggerD
    DiggerD DougFir from SuperDuke Days
    Mar 14, 2013
    4,936
    Mid Wet Or A Gun
    PNW chain saw comp engine..if in need more speed captain.
    JagLite and alvincullumyork like this.
  11. JagLite
    Jun 17, 2010
    8,093
    Anchorage Alaska
    That's ho-hum...
    Only one engine?
    This is what the captain needs when he calls for warp 9
    And the 24 engine bike will get you going too!
    The women love fast bikes with chainsaw engines obviously.
    Richy likes this.
  12. villageidiot
    villageidiot Long timer Supporter
    Apr 29, 2010
    11,699
    Orange County, CA
  13. Wildebeest90210
    May 24, 2013
    3,233
    An update, need to get this finished this week, weather is good for riding to pub...
    Got the exhaust welded up and polished. Bought a cheapo single speed sprocket to break apart and use the threaded part to weld for pedal side extension.
    List now is,
    rear brake set up and cable
    space and mount motor drive side sprocket
    new headlight mount
    Simple!!?
  14. DonM
    DonM Do-dah Do-dah Supporter
    Jan 13, 2008
    2,672
    Atlanta, GA
    Be-ooo-the-fulllll!
  15. TUCKERS
    TUCKERS the famous james
    Dec 23, 2005
    19,646
    Villa Maria Sanitarium, Claremont, CA. USA
    Just go to the pub at lunch then you can hold off on the headlight! Less weight too.....
  16. Roofchop
    Roofchop Hands up mother stickers, this is a f**k up!
    Jan 9, 2016
    618
    Carool, NSW
    Hey 'Beast have you weighed the orange beast with its engine and moon boot wheels yet?
    I had a shitty MTB with same ish engine and it weighed a ton, mainly the motor was ridiculously heavy then the cheapo mtb on top.
    I dont't reckon it will go up hills! (without pedal assist!):D
  17. lesman
    lesman Live easy, Brake Hard
    Sep 7, 2006
    4,022
    Baja Okahoma
    Don't you think the rear brake is just superfluous?
  18. DiggerD
    Mar 14, 2013
    4,936
    Mid Wet Or A Gun
    Wellll....that one way to make the engine look bigger.:photog
    JagLite likes this.
  19. TUCKERS
    Dec 23, 2005
    19,646
    You should always come to a full stop using your rear brake. Using the front in a gas station, your garage, stop sign....can result in a lock up, slide and even tip over. That’s why there are so many low speed drops, after slowing down using your front, gently applying your rear brake is the way when you are coming to a complete stop. So no the rear brake isn’t superfluous......
    JagLite likes this.
  20. DonM
    Jan 13, 2008
    2,672
    Atlanta, GA
    Eek!
