Le 'Rapidement'. Bored tracker.
Discussion in 'Some Assembly Required' started by Wildebeest90210, Feb 4, 2016.
  1. DiggerD
    DiggerD DougFir from SuperDuke Days
    Mar 14, 2013
    4,743
    Mid Wet Or A Gun
    Been runnin' with scissors too much as of late...I do remember you mentioned a brush...my bad...
    Sounds cool !
  2. Wildebeest90210
    Wildebeest90210 Long timer Supporter
    May 24, 2013
    3,145
    Bit of paint to tidy then it's time to start throwing it together.
  3. GR0NK
    GR0NK Got some screws loose!
    Sep 24, 2006
    10,058
    Stuck in 80s
    Looks good but, what's the accent for? :scratch
    Sean :dunno
    MrPopples likes this.
  4. Wildebeest90210
    May 24, 2013
    3,145
    Should have known better than to try and sneak that one by, got a friend to paint it and we decided it needed one.
  5. nickguzzi
    nickguzzi Long timer
    Feb 17, 2010
    7,520
    below the sea
    Makes it unpronounceableable.
    Adds that je ne sais quoi for anglophones though.
  6. Bt10
    Bt10 Long timer
    Dec 18, 2012
    1,048
    Saranac,MI
    I have no idea what you mean...:y0!:lol3
    tinwelp and nickguzzi like this.
  7. Wildebeest90210
    May 24, 2013
    3,145
    Le moto est le dangle from le sky hooks....
    Two instant problems, chain alignment for fat wheel, may have to move the engine over which will be a pain. The front sprocket is on a taper and the kit actually includes a puller for it! Not an easy job to space the sprocket out.
    Exhaust clashes due to forward position of crank. I feel a crude expansion pipe coming on...
  8. more koolaid
    more koolaid Been here awhile
    Nov 5, 2015
    474
    Bel Air Md.
    "I feel a crude expansion pipe coming on..." I hope you feel better soon:sick
    The bike looks great.
  9. Dryslick
    Dryslick Been here awhile
    Feb 11, 2011
    218
    Lake Berkely, Montana
  10. Roofchop
    Roofchop Hands up mother stickers, this is a f**k up!
    Jan 9, 2016
    556
    Carool, NSW
    Can you just weld a pushie sprocket to that one (with a boss if necessary) to obtain the offset?
    Got to be better than moving the engine over.
    Cheers
    Dave
    JagLite likes this.
  11. anonny
    anonny What could go wrong?
    Mar 20, 2007
    6,717
    Beautiful Revelstoke BC
    Have you investigated to see if anyone makes an offset sprocket? Maybe you machine the sprocket down and fabricate an offset sprocket to weld on?
    I went through the same problem with my H1b project
    JagLite likes this.
  12. Roadracer_Al
    Roadracer_Al louder, louder, louder!
    Aug 5, 2007
    2,353
    Oakland, CA
    Is it just me or does that air filter look Punisher a.f.?
    JStory and JimVonBaden like this.
  13. Wildebeest90210
    May 24, 2013
    3,145
    I'll paint that white then...
  14. Wildebeest90210
    May 24, 2013
    3,145
    I've been a measuring today. Motor side needs a chain line 55mm from C/L to clear tyre, that means 17mm on the front sprocket and about the same rear.
    I've just bought a new front sprocket at £3.99 so can make the longer one up with the two and some welding. The clutch will need an extension rod turned up and the casing spaced off but all doable. Also bought a new 130 link 415 chain for next to nothing.
    The rear can be spaced out with an ally ring dimensions of which will have to wait until the wheel is built.
    Pedal side needs a 53mm chain line which means 11mm on the front sprocket, easy spacer, but the 8mm on the rear is going to be a little more problematic.
    Bought 4 of these today at a cost double that of chain and sprocket! I've got to get some brake levers next, hopefully for less.
    nuggets and JagLite like this.
  15. nuggets
    nuggets It's all my fault...
    Jul 13, 2010
    3,580
    Virgina
    I'm loving those invisible spokes :D
    JagLite likes this.
  16. Wildebeest90210
    May 24, 2013
    3,145
    Makes it look fast even when standing still !
    JagLite and nuggets like this.
  17. Kai Ju
    Kai Ju Long timer Supporter
    Jul 29, 2009
    4,056
    Long Beach, California
    Faster than it will ever be...
    :hide
    JagLite likes this.
  18. more koolaid
    Nov 5, 2015
    474
    Bel Air Md.
    Nothing wrong with this build that another 100cc couldn't cure :hide
    JagLite likes this.
  19. nuggets
    Jul 13, 2010
    3,580
    Virgina
    I fix! :super
    JagLite likes this.
  20. Wildebeest90210
    May 24, 2013
    3,145
    I could go twin engine, it's within my budget. Have to check health insurance though....:muutt
    JagLite likes this.
