Leaking coolant from here - how to fix?
Discussion in 'Ridiculous streetbikes with 6 CPUs and too much HP' started by surreyrider, Jun 12, 2018.
  1. surreyrider
    surreyrider Adventurer
    May 12, 2015
    40
    London
    Noticed coolant level dropping over time from my 1050.
    Had a look and noticed this.
    Anyone know what this is and how to fix?
  2. kokos79
    kokos79 Nomad
    Apr 13, 2009
    801
    Greece
    That's the fuel line quick disconnect, so that's probably petrol.
    ScooterNoMore likes this.
  3. Broken&Lost
    Broken&Lost Been here awhile
    Jun 5, 2016
    182
    Leeds, UK
    As above it’s your petrol quick disconnect. Squeeze the silver disc in the middle and pull apart. Clean up, line it up and push firmly together until it clicks together.
  4. surreyrider
    May 12, 2015
    40
    London
    Thanks I think it must be leaking coolant higher up near the radiator and it is running down the fuel line as liquid is red
    Will investigate further
  5. Broken&Lost
    Jun 5, 2016
    182
    Leeds, UK
    Could be the radiator bleed screw or a hose. Need to remove the tank to get a better look at the source. Not hard to do but easier with a near empty tank.
  6. surreyrider
    May 12, 2015
    40
    London
    Ok thanks will have a look
    Do you need the tank off to get to the bleed screw?
  7. Broken&Lost
    Jun 5, 2016
    182
    Leeds, UK
    Most likely as the radiator is covered by the plastics. For how long it takes to remove it, you might as well make it easier to work on.
    Lord Explorer and ScooterNoMore like this.
  8. GCecchetto
    GCecchetto Long timer
    Jun 29, 2013
    2,748
    Woodside CA
    Very common for the hose clamp on the radiator side of the hose to be loose.
    #8
  9. Bluesilver
    Bluesilver Long timer
    Aug 6, 2013
    1,458
    South Africa
    You said red...both my 1190 and 1290 have yellow coolant in them so check the right side and see what colour yours is.
    If in doubt pull the tank,very easy and quick.
    #9
  10. Lewilewi
    Lewilewi Ride it like you stole it......
    Oct 22, 2017
    811
    N.W.Kent.Uk
    Rottweiler web site has a video showing how to pull the tank
    #10
  11. Snort
    Snort Adventurer
    Aug 30, 2015
    52
    UK
    The top radiator to hose connection started leaking from mine when it was a couple of years old.
    I just tightened the jubilee clip up with a screwdriver. You can do it through the gap between the painted tank cover plastic and the black tank (where your left knee goes).
    That's in about the right place to run down the fuel line.
    #11
  12. GCecchetto
    Jun 29, 2013
    2,748
    Woodside CA
    Most 1190's use the red coolant.
    #12
  13. surreyrider
    May 12, 2015
    40
    London
    EB48CC07-8B62-4968-B71A-3CDDC2747DD7.jpeg Thanks guys
    Have pulled the tank off - great vid cheers
    All hoses look ok and are tight but there is a slight red stain on the back of the radiator - see pic
    Any ideas?
    #13
  14. Broken&Lost
    Jun 5, 2016
    182
    Leeds, UK
    Check the front for damage in the same but I think it may be the hose above it. Did any of the clamps have play in them.
    #14
  15. surreyrider
    May 12, 2015
    40
    London
    Thanks no damage to front and clamps all tight
    #15
  16. Broken&Lost
    Jun 5, 2016
    182
    Leeds, UK
    Did you check the bleed screw on top of the radiator?
    If you clean it down and see if it reappears, which hopefully it won’t. If it does you may have a fault in the radiator.
    #16
  17. surreyrider
    May 12, 2015
    40
    London
    Will check hoses above again as you make a good point would explain why it is dripping onto back of rad and fuel line
    Also only seems to lose coolant when running no drips when left overnight under bike
    Cheers
    #17
  18. surreyrider
    May 12, 2015
    40
    London
    Yes bleed screw is tight and no signs of leakage
    Rad will be expensive. Ever tried radweld or similar on a bike?
    #18
  19. Broken&Lost
    Jun 5, 2016
    182
    Leeds, UK
    An old trick was to cover the pipes in talc powder. Any leak will leave a trail through talc. Obviously you’ll not be able to ride or the talc will blow away. Should work on the radiator too.
    #19
  20. Broken&Lost
    Jun 5, 2016
    182
    Leeds, UK
    Is your bike still under warranty?
    #20
