Leatt 3DF Airlift Body Protector
Discussion in 'Equipment' started by traveltoad, Dec 4, 2013.
  1. stujamur
    stujamur keep rollin rollin rollin
    Dec 12, 2009
    2,434
    Brisbane north side
    I have the airfit lite in l/xl and wear it with leatt gpx 5.5 - very cumfy and adaptable with layers . Maybe try one on?
    Street brace like leatt is designed to work with jackets with back armour - go gpx 5.5.
    Leatt airfit is cumfy under jacket and for me the gpx 5.5 is great cause it can be adjusted easily to suit different armour / jacket / jersey combos .
    Adrenolin likes this.
  2. OKDQ
    OKDQ Long timer
    Nov 7, 2009
    1,158
    OK
    I can only help with a couple of your questions.
    1. Anyone think I should perhaps order the XXL large or stick with the L/XL? They are a pretty snug fit by design, but I would say if you are on the fence about size then order up a size and not down.
    4.
    Does the AirFit comfortably fit under a jacket? Mine does, but I think it's going to depend a lot on how loose your jacket fits. If you have a tight fitting jacket then it's going to be much tighter with the airlift underneath too.
  3. Y E T I
    Y E T I Unpossible
    Apr 26, 2007
    8,521
    San Diego
    1. L/XL would be my recommendation.
    2. :dunno
    3. Yes. That's what I have, it's great.
    4. Yes and yes. I often just leave the collar of my jacket open around the GPX, but the best feature of the GPX (to me) is that you can quickly adjust the size/fit.
  4. Adrenolin
    Adrenolin Been here awhile
    Aug 26, 2015
    315
    Delaware
    Thanks for the help.. I'll be placing an order for a number of items tonight or tomorrow.
  5. DSquared
    DSquared Dilly Dilly!
    Mar 13, 2015
    3,615
    Burlington WI
    I'm 5'11" 195 and the L/XL fits very well. I went with the Atlas Air neck brace and it feels very good with my Aerostich RC3 and the 3DF with just a jersey. Can't answer #3. Yes, I put my MX setup(3DF, Jersey, MXpants, Dual Axis knee guards) if you will on under the RC3 and it felt great so I am comfortable for the road to and from the dirt.
  6. Nesquik
    Nesquik Long timer
    Sep 18, 2012
    4,731
    Kenosha
    I was thinking about doing this, what do you do with your roadcrafter when you get to the dirt?
  7. DSquared
    Mar 13, 2015
    3,615
    Burlington WI
    Without any pads, A roadcrafter actually rolls pretty small. It fits on the rear rack of my KLR. I may put it in a dry bag if I know I am gonna get messy.
  8. Nesquik
    Nesquik Long timer
    Sep 18, 2012
    4,731
    Kenosha
    that's a good idea
    I was planning on doing the same thing but was going to use my Darien on top over armor and just wear the same street pants off road. May try out the roadcrafter.
  9. Adrenolin
    Aug 26, 2015
    315
    Delaware
    Thanks for the extra suggestions. I've ordered a
    Scorpion Covert Flannel Shirt and a pair of Klim K Fifty riding jeans to add to my street riding gear. Still need to order a set of protection pads for the shirt but will likely wear the AirFit under it as well.
    Haven't looked at the RoadCrafter yet but will do so later today. Also need to find a decent 4-season adventure pant to go with my TourMaster 4 jacket.
  10. Nesquik
    Nesquik Long timer
    Sep 18, 2012
    4,731
    Kenosha
    For you guys that have the Airfit is it possible to wear under a jacket and remove it/put it on as one piece? Like leave the Airfit in as if it were a liner?
  11. OKDQ
    OKDQ Long timer
    Nov 7, 2009
    1,158
    OK
    I understand what your talking about and I've done that with two shirts before but I don't think that's a very feasible option with the airfit just because it fits too snugly. I don't see it being a timesaver in that manner.
  12. Nesquik
    Nesquik Long timer
    Sep 18, 2012
    4,731
    Kenosha
    Thanks for the info
    In looking for a good pressure suit that can function as a liner under my Darien
  13. fullmonte
    fullmonte Reformed Kneedragger
    Nov 14, 2005
    8,473
    Chattanooga, Tennessee
    What OKDQ said, plus the Airfit takes longer to don/doff than a typical zipper in the middle pressure suit. Once it is on, it's on. I don't take mine off until the ride is finished.
  14. OKDQ
    OKDQ Long timer
    Nov 7, 2009
    1,158
    OK
    The airfit can certainly function as a liner but wouldn't be very practical IMO as a stay in the jacket liner. Not sure any pressure suit would function very well as a stay-in-the-jacket liner. However all pressure suits I'm familiar with are "best" when a jacket is worn over the top although on real hot days I've worn mine sans jacket lots of times.
  15. Nesquik
    Nesquik Long timer
    Sep 18, 2012
    4,731
    Kenosha
    The only one I have available to be local was a Fox, dunno the model
    It was surprisingly easy to remove in and out it on without separating the jacket and pressure suit. To be honest, it was easier to put it on as one piece than one at a time
  16. Adrenolin
    Aug 26, 2015
    315
    Delaware
    Just received my AirFit last week. As a liner no. As stated, this is a very tight fitting garment and can't be used as a liner. That said, I wore mine as a base layer the other day with a light shirt over it with a Kevlar flannel riding jacket on over it with the protective pads removed using it as an abrasion layer only. With the AirFit one could wear pretty much any motorcycle jacket over it and remove the pads since having two sets doesn't really help you at all.
  17. Droptarotter
    Droptarotter Long timer
    Jul 11, 2007
    2,622
    Creston,BC
    How would you wear a kidney belt with the Airfit? Would you have to put the kidney belt on first or would it fit overtop of the Airfit?
  18. Adrenolin
    Aug 26, 2015
    315
    Delaware
    The AirFit is like a 2nd skin due to the Lycra material. Properly sized there would be no room under it. Any kidney belt would have to fit over it for certain.
  19. Droptarotter
    Jul 11, 2007
    2,622
    Creston,BC
    Is there any padding where a kidney belt would sit? If so, any idea how much more girth the Airfit would add to my ever increasing waistline?
    Anybody tried a kidney belt with one of these suits?
    Cheers
  20. Y E T I
    Y E T I Unpossible
    Apr 26, 2007
    8,521
    San Diego
    There is no padding where a kidney belt would sit. At least in the front. In the back, I guess it would depend on how wide the belt is and how tall you are. It would probably work just fine.
