LED Headlight ?
Discussion in 'Parallel Universe' started by mosey.levy, Nov 16, 2014.
  1. mosey.levy
    mosey.levy Long timer
    Jul 13, 2013
    2,421
    NYC
    have any of you upgraded?
    is it as simple as swapping out the bulb?
    photos?
    instructions ?
    links?
    cost?
    (Edit: 2014 F700GS)
  2. gnurob
    gnurob Adventurer
    Sep 19, 2012
    99
    St. John's, Newfoundland and Labrador
    The shape of LED replacements do not match the incandescent filiment, which means the reflector is incorrect.
    The folks at candle power forums know this subject well.
    But, it can be done. Oracle has an H7 bulb (2200 lm) that I would at least consider testing. Warning: it has an enlarged base for cooling. Also note, it is overpowered:
  3. Arclite
    Arclite Been here awhile
    May 22, 2007
    149
    TBD
  4. mosey.levy
    Jul 13, 2013
    2,421
    NYC
  5. Stephenmarklay
    Stephenmarklay Been here awhile
    Mar 22, 2012
    614
    Spokane, WA
    Read the Cyclops specific thread.
    I have one in mine.
    Good:
    Light output
    Light color
    reduced current draw
    installs like a standard H7
    great customer service
    Bad:
    On the 800, there rear plastic cover has to be modified to fit the fan assembly.
    Pre 2013 bikes have a different housing and the rear cover is shallower. It has to be modified more.
  6. mosey.levy
    Jul 13, 2013
    2,421
    NYC
    So did you just cut out a larger hole in the rear plastic?
    Thanks for the info I'll check out the threads.
  7. Cavediver29
    Cavediver29 Adventurer
    Apr 16, 2014
    30
    Seattle
    I tried to buy one of the cyclops led bulbs at the touratech rally. Unfortunately on the 2014 f800gsa the end cap will not fit. Myself and the guy at the booth couldn't find a way to modify the cap to make it work.
  8. jengel451
    jengel451 1 Cool MotherF#$cker
    May 2, 2011
    1,766
    Kansas City
    That may have changed since June. Give Cyclops a call.
    #8
  9. Stephenmarklay
    Mar 22, 2012
    614
    Spokane, WA
    I mis-typed above saying that the pre 2013 is shallower.
    I meant to say the pre 2013 bikes have a different cap than the 2013-2015 bikes. Actually, the light is different but dimensionally the same. So the rear cap on the new bikes is even tighter. You have to cut the cap so the rear fan can stick out.
    I have thought about trying to find a rubber boot that would fit but have not yet.
    #9
  10. jengel451
    May 2, 2011
    1,766
    Kansas City
    Cyclops has my stock headlight out off my 2013 bike. I know they've been using it for R&D and have it working, not sure what the specifics are though.
    I just said screw it mounted up a laser/flood/flamethrower :evil
    #10
  11. Stephenmarklay
    Mar 22, 2012
    614
    Spokane, WA
    Yeah they go in fine but the rear cover won't go on. Maybe they will come up with a solution.
    #11
  12. ebrabaek
    ebrabaek Long timer
    Jan 12, 2010
    5,661
    Grand Valley, Colorado
    I think they have something else in mind.... :D:D
    #12
  13. RedHawk47
    RedHawk47 Adventurer Supporter
    Oct 5, 2006
    990
    Berthoud, CO
    #13
  14. TTGSA
    TTGSA TTGSA
    Oct 6, 2014
    42
    Sweden
    #14
  15. MTrider16
    MTrider16 Ridin' in MT
    Oct 16, 2006
    1,870
    Eastern Montana
  16. TTGSA
    TTGSA TTGSA
    Oct 6, 2014
    42
    Sweden
    Thanks MTRider16, really impressiv projekt!
    But I want the OEM lamphouse and a LED bulb, for both high beam and lowbeam, anyone any suggestions? :D
    #16
  17. Stephenmarklay
    Mar 22, 2012
    614
    Spokane, WA
    Gotcha :clap
    #17
  18. mosey.levy
    Jul 13, 2013
    2,421
    NYC
    #18
  19. jttele
    jttele Been here awhile
    Feb 24, 2005
    397
    Alexander, NC
    Got these in both low and high beam on my 2011 F800gs and they fit and work excellent (no error light or canbus issues at all). The only problem is the rear covers do not fit over the heat sink. Not a big deal really, as the bulbs themselves are waterproof and the headlight housing is vented anyway. I guess in really dusty conditions you could get some in the housing.
    #19
  20. mosey.levy
    Jul 13, 2013
    2,421
    NYC
    so you think leaving the back cover off is ok?
    hows the projection on that thing?
    I'm sure its brighter then the stock, but hows the throw distance compared to the stock?
    #20
