LED Indicator kit from KTM
Discussion in 'Dakar champion (950/990)' started by Gous, Sep 13, 2014.
  1. Gous
    Gous KTM Nam
    Sep 12, 2014
    2
    Bought a LED indicator kit from KTM for my 09 KTM 990 Adv. The instructions in package very simple and clear but the replacement relay they supply in kit does not fit. Any one that can help?
  2. Peanuts
    Peanuts Long timer
    Sep 12, 2009
    2,005
    Beautiful but often rainy North Yorkshire, UK
    Whats the part number for the kit?
  3. keener
    keener Speed changes you.
    Feb 24, 2010
    2,253
    Toronto, Canada
    it must be an IC relay and should have three wires just like the stock.
  4. Peanuts
    Peanuts Long timer
    Sep 12, 2009
    2,005
    Yes you need a different flasher unit designed for LED indicators. Lots on Ebay, buy one and change the connectors on the loom.
    Stock only has 2 wires, feed in and the out goes to the indicator switch. The dash repeater works by using the non illuminated lamp for a ground path. This causes an issue with LED indicators so you have to be creative by using a pair of diodes to feed the repeater and ground the other side of the repeater or mess about with resistors in parallel with the indicators or buy a different style flasher unit.
  5. rider911
    rider911 Shortcut Navigator
    Sep 18, 2009
    1,309
    Australia
    I believe that the 2009 onward have the flasher relay built into the hazard light button assembly and therefore no special LED flasher relay will work for these later models. You will need to fit resistors to each indicator. Apparently you can buy resistors with the KTM plugs so is just a plug and play senario.
    I have just fitted a LED relay to my 07, it is a 2 wire unit off ebay that came with a 3 pin plug. I removed the pins from the plug and pushed them into a 2 position plug (off ebay) and it worked and fitted perfectly.
    Mr Head likes this.
  6. micky1
    micky1 MANCC
    Aug 30, 2014
    189
    Bath. UK
    any links rider? i have a 2009 and want t upgrade
  7. rider911
    Sep 18, 2009
    1,309
    Australia
  8. micky1
    micky1 MANCC
    Aug 30, 2014
    189
    Bath. UK
    cheers ears :thumb
    #8
  9. Peanuts
    Peanuts Long timer
    Sep 12, 2009
    2,005
  10. QUICKIT
    QUICKIT DCT convert
    May 22, 2013
    25
    Boise Idaho area
    Is the the part number : 76014937044
    http://shop.ktm.com/za_en/led-indicator-set-3446.html
    #10
  11. FakeName
    FakeName Wile E Coyote SuperGenius
    Jan 1, 2007
    2,154
    San Diego
    Interesting kit. Not showing up on any of the domestic parts sources.
    #11
  12. rider911
    Sep 18, 2009
    1,309
    Australia
    I just checked that number and some listings say it fits all models of 990 Adv.
    I have a 2012 990 as well, and I cant find any blinker relay on my bike, which is also confirmed by my wiring diagram.
    Can anyone with a 09 onward ADV confirm their bike actually has a blinker relay, I dont believe they do unless USA model bikes dont have hazard flashers?
    #12
  13. QUICKIT
    QUICKIT DCT convert
    May 22, 2013
    25
    Boise Idaho area
    But the part number does not pull up as a valid part number in the KTM USA parts system, only other countries. I guess we have to order from the UK???
    #13
  14. Peanuts
    Peanuts Long timer
    Sep 12, 2009
    2,005
    #14
  15. Sumi
    Sumi Long timer
    Mar 30, 2010
    2,239
    Hungary
    Will this fit a 950?
    #15
  16. rider911
    Sep 18, 2009
    1,309
    Australia
    yes
    #16
  17. Sumi
    Sumi Long timer
    Mar 30, 2010
    2,239
    Hungary
    Yaaay, there goes another $100 :D
    #17
  18. Alex_RO
    Alex_RO Been here awhile
    Apr 9, 2007
    226
    Romania, Bucharest
    Please post pictures of the installed blinkers on a 9X0.. I might... need... a set..:norton
    #18
  19. rider911
    Sep 18, 2009
    1,309
    Australia
    The reason I went to LEDs was to reduce the size of the physical blinker as I kept wiping out the front units on shrubs, Im not sure these KTM ones are much smaller than stock.
    My whole set up was less than $40 I think off ebay. I did have to rob the plugs off the the std blinkers and solder them on to the ebay units.
    #19
  20. Gous
    Gous KTM Nam
    Sep 12, 2014
    2
    Thank you every one for the feedback. Fitted kit to bike but need to fit resistors. Believe relay in kit is for 1190, LED's looks good on bike though!
    #20
