    Dismiss Notice
LEDRider - Quality LED aux lighting
Discussion in 'Vendors' started by JustinP, Oct 13, 2013.
  1. heirhead
    heirhead worlds worst mechanic
    Jan 2, 2009
    1,390
    On the water in South OC
    Hello Justin,
    Received my 3rd and last set of your lights, for now. Don't know where to put them on the Burgman. Will be sporting these at the ADV Noob DV Rally.
    Thanks again for supporting the Rally as someone will be very happy winning these lights at the raffle!!
    heirhead
  2. JustinP
    JustinP Long timer
    Jun 19, 2011
    13,159
    Sunny Colorado
    Missed this - very Nice :clap. I like the high mounting location. Thanks for sharing.
  3. JustinP
    JustinP Long timer
    Jun 19, 2011
    13,159
    Sunny Colorado
    Some pictures from a customer - First picture is stock low beams on a Yamaha FJR, second picture is high beams plus a set of LR5's and a set of LD35's. That's 16,500ish lumens down range :clap. Lit up signs down the road are a measured half mile, both shots have the same manual camera setting. That's ~1300 feet of clear lighting based on 300 ft rural spacing of utility poles.
    Stock FJR Low Beam: *Click here for full size*
    High beam, LR5's and LD35's: *Click here for full size*
  4. JustinP
    JustinP Long timer
    Jun 19, 2011
    13,159
    Sunny Colorado
    Cool picture from a customer. LR4's on the bottom, Optumus spots up top, and a 2200 Lm LED H4. Multiple UFO sightings reported :clap
  5. JustinP
    JustinP Long timer
    Jun 19, 2011
    13,159
    Sunny Colorado
    Doing a little more cleaning around the shop.
    1 set of used LR4's from one of our bikes here. *SOLD*
    1 set of used LR5's. **SOLD**
  6. NSFW
    NSFW basecamp4adv Super Supporter
    Feb 20, 2007
    25,501
    Burbank CA
    +1 on the wiring harness.
    i'm capable of doing my own wiring. anyhow, bought the harness with the lights. it's easy and simple...and very clean install.
    thanks justin.
  7. Andylaser
    Andylaser Heavy Metal
    Feb 17, 2011
    1,955
    Southampton UK
    Will the LR40 lights work with the Skene dimmer? Dont really need full adjust-ability, but a low brightness option is good.
  8. JustinP
    JustinP Long timer
    Jun 19, 2011
    13,159
    Sunny Colorado
    Yes, the Skene will work with the LR40's!
  9. Funbronco
    Funbronco Adventurer
    Sep 1, 2012
    84
    Newville, PA
    I'm so confused, so many choices. Don't know where to start.
  10. Funbronco
    Sep 1, 2012
    84
    Newville, PA
    How do the LD35 compare to the LR35? and does the harness and dimmer make for a complete install? Any provision for running on the dimmer on low beam and full power on high beam? Enquiring minds want to know.
  11. JustinP
    JustinP Long timer
    Jun 19, 2011
    13,159
    Sunny Colorado
    Sorry for the confusion :) What bike are you riding? The LR35 has more raw output. The LD35 has less output, but more range. The LR35 has more otuput and a lot more side light - but, personally, I really like the LD35. It has awesome range and good width for a 22 watt light, and the color (5000k) and tint are perfect. Shoot me a message - happy to help get you the right light for your application!
  12. Jersey_Dave
    Jersey_Dave n00b
    May 21, 2013
    2
    Justin
    Looking for the LR4 or 5 for a 14 goldwing
    Looked at the website
    which harness, dimmer should I get and does the harness come with a switch/relay
    Dave
  13. JustinP
    JustinP Long timer
    Jun 19, 2011
    13,159
    Sunny Colorado
    On the LR5, the harness option comes with a switch and a relay 9but not a dimmer). If you go the dimmer route, order the lights without the harness. And, the LR5's are actually over the power rating of our dimmer, so I'd steer you towards the Skene dimmer if you wanted that functionality. With the Skene dimmer you will not need any relay or switch, the unit handles all of that.
  14. NSFW
    Feb 20, 2007
    25,501
    Burbank CA
    oooooooooooooooooh Dang those lights are purdy :eek1
    I stole this pic from the noobs death valley rally ride report....http://www.advrider.com/forums/showthread.php?t=1051999
    We solicited from a lot of vendors and many responded. Big thanks to LED RIDER for the support.
    Justin, this year's noobs rally was a huge success and big turnout.
    Because of the sponsors like LED RIDER, we had awesome raffle prizes and were great incentives for participants to buy raffle tickets. We were able to raise significant $ in one weekend; which in return we donated to Blue Ribbon Coalition ($1500), CORVA ($500), CTUC ($1600) and Stewards of the Sequoias ($1500 + $300).
    Fellow inmates, please support the vendors who support us, not just for the discount but those who believe in our cause.
  15. Funbronco
    Sep 1, 2012
    84
    Newville, PA
    Thanks for all the help in deciding what lights to go with as well as wiring options Justin. Can't wait to get these babies on the Tiger.:clap
  16. gadogad
    gadogad
    Feb 10, 2013
    66
    Anyone know if on the LR4, the mount can be flipped in between the light and the rear heat sink?
  17. JustinP
    JustinP Long timer
    Jun 19, 2011
    13,159
    Sunny Colorado
    Are you referring to the mounting "foot"? If so, then yes, you can flip that around.
  18. madmaximum
    madmaximum She said we're all idiots
    Sep 10, 2008
    5,527
    Port Matilda, the poor side
    ADV15 code is not working
  19. JustinP
    JustinP Long timer
    Jun 19, 2011
    13,159
    Sunny Colorado
    On which product?
  20. bluestar
    bluestar sheep shagger
    Mar 14, 2014
    26,950
    sheep pen
    I thought I'd post a quick review. Last weekend, I got to try out my LR35's on a dark and twisty road. I shut them off momentarily and immediately turned them back on. What an amazing difference. These lights are worth every penny. :clap
