1. eNewsletter Sign Up
LEDRider - Quality LED aux lighting
Discussion in 'Vendors' started by JustinP, Oct 13, 2013.
  1. krumgrinder
    krumgrinder Been here awhile
    Jun 10, 2008
    358
    Columbus, Ohio
    Well, then here's another 'independent' review for you.
    Solid product. I bought a pair of (I believe) LR4's - the 4-element bullet style - with one of his first dimmers, maybe three years ago and they have been next to bulletproof. I mounted them on a Black Dog triple clamp bracket, so they sit just above my front fender and below the front fairing, a little more protected than out on the sides. Bike has been dumped, submerged and otherwise abused on multiple occasions, including getting hammered on a highway on the commute home- and these little lights have never quit. The right side one took a flung rock once, breaking the lens, but Jason replaced it at his cost. How's that for you? :D
  2. BMWGSA
    BMWGSA Geländefahrer Supporter
    Jun 26, 2015
    685
    Virginia, Blue Ridge Mountains
    So the LX5 is the same as the LR4 ? They looked different to me.
    Dimmer ? can I not just use a HexEZcan ? or is a Seperate dimmer required?
    I have been looking for a side by side comparison with comparable clearwaters.
  3. heirhead
    heirhead worlds worst mechanic
    Jan 2, 2009
    1,325
    On the water in South OC
    Hello Justin,
    Bought 5 sets, coming back for more.
    Have to keep from selling bikes with lights on them but GREAT selling point.
    Still have LR4, need some for TW200 getting ready to travel.
    Don't need dimmer, just bright lights.
    hh
    wwm
  4. Duckati
    Duckati Adventurer
    Feb 13, 2017
    50
    Austin, TX
    Heya Justin... Will a pair of the LX3's be ok on a 5A fuse? And is the 3150 lumens spec "raw" or delivered? ...I assume raw based on the XML-2's spec @ 10W per emitter? Thanks!
  5. JustinP
    JustinP Long timer
    Jun 19, 2011
    13,159
    Sunny Colorado
    5 Amps will be borderline for the fuse. I'd go with 10 amp for a set. The 3150 is raw.
  6. 1stgenfarmboy
    1stgenfarmboy The Sherpa Man
    Jun 2, 2013
    6,177
    southern tip of ILL
    Justin, I have some LR4's I have had for years, yesterday one just went out, if you look close a couple of the LED's are on but very very dim, I did take it apart and I do have 12v power going all the way to the LED's.....can this be repaired? or am I just in for some new ones.
    Thanks Dar.
  7. playinatwork
    playinatwork Been here awhile
    Jul 30, 2010
    693
    Jacksonville FL
    Justin, I ordered some LD5's today and I was wondering if I can get the snap on covers in amber?
