Let’s talk about BMW bolts
Discussion in 'Airheads' started by lucky6600, Jun 15, 2019.
  1. lucky6600
    lucky6600 Long timer
    Feb 27, 2010
    1,866
    CT USA
    Let’s talk about bolts
    I am in the process of sorting my junks.
    BMW has been using different vendors over the years.
    Any particular years ? Brand?
  2. Disston
    Disston ShadeTreeExpert
    Aug 31, 2009
    15,767
    Silver Spring, Md
    One of the first things I learned 20 years ago when I got my '75 R90/6 was to not wire brush the stock bolts when I cleaned things up because the bolts were, mostly, cadmium plated and wire brushing would remove the coating so the bolts would then all rust away. Happened of course because I was told this after I had wire brushed most of the bolts.
    Since then I have replaced most of the ugly rusted parts with second hand stuff in good condition and sometimes stainless steel. I'm not in favor of too much stainless steel but for a lot of parts there is not much option. And the look of rusted bolts is really the worst.
    This is not what you were looking for? I'd like to hear where original style cadmium plated bolts can be bought if that's what you're after.
    theDQG, nk14zp and lucky6600 like this.
  3. AntonLargiader
    AntonLargiader Long timer
    Aug 28, 2003
    6,487
    Charlottesville, VA
    I buy nearly all of my hardware from BMW. There are exceptions, but most of it is still nicely plated and reasonably priced.I have a bunch of it listed here, and you can submit new hardware that isn't already listed.
    Jim Day, globalt38, spokester and 3 others like this.
  4. lucky6600
    Feb 27, 2010
    1,866
    CT USA
    I know for years, we all busy with keeping our airheads running and enjoy the way it was designed for. As people sometimes say, the cheapest part on a BMW motorcycle is the owner. Most of us will do whatever it takes to keep the bike running in a most economic way while includes using a random nuts and bolts that you have in your tool box if needed. I was the same way until awhile ago, I even saw a "S " (Suzuki style S) bolt on one of my new acquisitions.
    Many people went to the shiny stainless route when the bike was "restored". They look nice but isn't my cup of tea. I would like to keep my bikes as original as possible including bolts.
    I found BMW used different vendors for all their models. VERBUS here and RIBE there..... I am hoping I am not the only one had been OCD about it.
    Anton,
    Your list is awesome as always but I wish the hardware list has one more column : manufacturer
    spokester likes this.
  5. ccmickelson
    ccmickelson MonoMania Supporter
    Dec 11, 2013
    2,267
    Fanta Se
    I've always been pretty OCD about fastener originality on my bikes even as much as how they are oriented when assembled. I can't let myself spin a nut on with the ISO/manufacture markings face down (this includes the little fiddly nuts on valve cover studs. (I may not remember to tighten them but by-god they'll be installed properly:lol3). I've replaced a few badly corroded socket head cap screws on the exhaust clamps with stainless, but I didn't feel good about it.
    bobthekelpy, nk14zp and bmwrench like this.
  6. Warin
    Warin Retired
    Aug 30, 2012
    9,500
    If the old bolts just 'look ugly' they can be re-plated.
    You'd want a few to make it worth while.. and the cleaner they are the better ($ wise).
  7. AntonLargiader
    Aug 28, 2003
    6,487
    Charlottesville, VA
    Re-plating is definitely an option. I'm having some stuff replated for my /2. For old, fine-thread stuff I suspect this is the best option.
    For my hardware list, I'm not concerned about the manufacturer because that list is about current replacement parts. If you need to match a particular bolt on your bike, you already have all the info you need. If you want to buy a new bolt from BMW in a particular size, try my list.
    Sometimes BMW screws up on the replacement hardware, like when they change a thread pitch without changing the mating part. Or they replace an Allen with a Torx, which just looks wrong on older bikes and doesn't match the toolkit. Other stuff is just different, like the new oil pan bolts which have a captive hard washer rather than a captive wavy washer. But often these things change again after a year or so.
    Some bolts are made just for BMW. For instance, I wanted longer OEM-look radial caliper bolts for the new bikes so I could mount Motolights without looking like I had made a trip to Home Depot, and contacted the manufacturer. Nope, that bolt is made just for BMW and is not produced in different lengths.
  8. bpeckm
    bpeckm Grin! Supporter
    Apr 2, 2008
    7,917
    Road Island
    Interesting thread, yes verging on OCD....but interesting. I've started saving the old bolts nuts as well: does anyone have names of places that will still cad plate? I was under the impression that cad plating is such an industrial hazard that it is rarely done anymore.
    #8
  9. bmwrench
    bmwrench Long timer
    Nov 10, 2006
    7,320
    I use stainless steel fasteners where I feel safe in doing so. Places that cad plate are rarer by the day, and nickel and zinc plating don't hold up well. Newish BMWs are being built with more stainless hardware as time goes by.
    #9
  10. 100RT
    100RT Long timer
    Nov 4, 2009
    1,703
    NEWTON FALLS, OHIO
    On occasion I have used Rub n Buff to freshen up the look of the old fasteners on my 81 R100RT. Very fast, just a dab on a q-tip and rub off . Done! Not permanent but lasts a long time.
    #10
  11. sprouty115
    sprouty115 Long timer Supporter
    May 29, 2012
    7,043
    Providence, RI
    Does it stop rust?
    #11
  12. 100RT
    100RT Long timer
    Nov 4, 2009
    1,703
    NEWTON FALLS, OHIO
    it's basically a carnuba wax with metallic powder in it. Have no idea about preventing rust very well.
    #12
    sprouty115 likes this.
  13. photorider
    photorider Been here awhile
    Nov 24, 2008
    718
    Zion
    Wow. I thought I could be OCD. Properly orienting the markings on fasteners? The bar has been raised.
    #13
  14. SculptD
    SculptD Smells like tech
    Jun 20, 2013
    1,514
    SF, CA
    Ah, the many shades of rebuilding, refreshing, restoring...
    A proper restoration should be all original down to the minute details, no? Some no-nothings look at my efforts and ask if I will present my bikes in another format. “You should go down to Pebble Beach...” and so on.
    Right. And be humiliated by my incorrect nuts and bolts? Just to mention the most minor of my infractions.
    I like stainless, and socket heads, when it looks right. But there are plenty of places when it doesn’t function as well. Small button heads for example.
    Rub-n-Buff offers a little bit of protection. If you refresh it often. Might be as good as any other non-durable rust preventative.
    #14
  15. Disston
    Aug 31, 2009
    15,767
    Silver Spring, Md
    Look at a quality made nut and you'll see manufacturers marking on one side. These are properly assembled with the non marked end not visible.
    Bearings are assembled so the markings are visible.
    These issues come up once in a while. Supposedly many manufacturers assembled their products this way.
    I have no idea if this is a thing with BMW in the age of building Airheads but I do it this way with everything and anything. It's a habit.
    #15
    spokester and sprouty115 like this.
  16. photorider
    Nov 24, 2008
    718
    Zion
    Front and back is one thing. Lots of fasteners have different faces. But orienting text so it’s not upside down? That’s the prize winner.
    #16
  17. ccmickelson
    Dec 11, 2013
    2,267
    Fanta Se
    That was, "face down", not "upside down".:deal You just won the reading comprehension prize, photorider.:lol3
    For all intents and purposes my hermetically preserved ST, with 1,400 original miles when I bought it a little over a year ago, was a brand new bike. Still had all of the factory paint marks aligned on the drain and fill plugs and their associated original gaskets. Hell, I did the first oil filter change on it since it came from the factory. A virtual airhead time capsule. Additionally every single nut on it was installed with the markings visible.
    All of the nuts on the brand new Hyundai engine I am about to swap into my Delica were installed in the same manor.
    The information stamped into fasteners is there for a purpose. If the stamp is no longer legible because the nut was installed stamped side down, that information is lost.
    Obsessiveness is relative I guess. Reminds me of my buddy's favorite axiom: Nothing screams poor workmanship like wrinkles in the duct tape.:lol3
    #17
    OLD GREEN, spokester and Disston like this.
  18. Disston
    Aug 31, 2009
    15,767
    Silver Spring, Md
    I thought so. I didn't want to assert it as fact because I wasn't sure.
    #18
  19. nk14zp
    nk14zp Long timer
    Feb 24, 2010
    2,869
    Maine
    It's not as fun when it's your boss with the affliction and your trying to get the skidder out of the shop as fast as possible.
    #19
  20. photorider
    Nov 24, 2008
    718
    Zion
    Touché! Read it too fast and misunderstood the initial post. What you are doing is not OCD. That is just attention to detail :)
    #20
