let's see a picture of your camping setup and how it all fits on your bike... please
Discussion in 'Camping Toys' started by ClearwaterBMW, Jun 8, 2007.
  1. 1911fan
    1911fan Master of the Obvious Supporter
    Aug 13, 2007
    5,339
    Lewiston, Idaho
    oh no, get insulated! I've got an Expedia Downmat that is the bomb.
  2. PNWet
    PNWet Long timer
    Nov 2, 2014
    1,060
    Puget Sound, WA, USA
    I understsnd getting one that doesn't self inflate, but why non-insulated?
    For me, insulated Static V Lite.
  3. Andrew
    Andrew Optimus Primer Administrator Super Moderator
    Sep 25, 2001
    23,517
    Eastbania
    The new pads have multiple chambers that fill with air. They're tight enough that I don't sink "through" the pad and touch the ground, thus keeping me sleeping, literally, on air all night. I don't need the insulation since the air chamber is quite good at insulating me from the ground. Short of an electric heating element, I don't see how one can do better than the new pads.
    Older pads that self-inflated (up to a point) relied on foam inside, that drew in air as they expanded from being compressed. That foam added weight and bulk. The new pads have to be blown entirely by mouth (or adaptive pump), and have no added weight or bulk, just their sheer material.
    Snake Oiler and Mr Head like this.
  4. PNWet
    PNWet Long timer
    Nov 2, 2014
    1,060
    As I understand it, R value is a measure of how well the object (in this case, a sleeping pad) resists conductive heat loss while inflated. Sinking through and touching the ground would cause additional heat loss, but is not how a pad's R value is determined.
    While R value sleeping pad calculations won't be standardized until 2020, it is generally accepted that the higher the R value, the less conductive heat loss. And, generally, non insulated pads have a lower R value than insulated pads.
    All that said, whether you need an insulated pad (and if so, how much insulation) or not has many factors (ambient temperature, ground temperature, hot or cold sleeper, wind, humidity, quality and type of your other insulation, etc).
    I camp in areas where it gets below freezing often. Sometimes I use the pad on the ground, sometimes on a mesh cot. On the cot convective heat loss is another factor as air circulates below it. Having an insulated pad assures me I will stay warm, and I've never found it to be too warm.
    My Klymit Static V lite insulated weighs 1.6 ounces more at 19.6 ounces than Klymit's non insulated offering at 18 ounces. Thermarest Neoair Xlite is 12 ounces. To me an ounce or 2 extra makes no difference.
    RoundTrip, Jim K. and nvklr like this.
  5. skibum69
    skibum69 slave to gravity Super Supporter
    May 14, 2006
    12,869
    New Melbourne, Newfoundland
    This was my pack heading to Tennessee in June, worked well for me. My Ortlieb soft panniers fit well inside the hard cases which was great, waterproof and easy for grab and go.
    Maggot12, Square1, Ladybug and 2 others like this.
  6. 1911fan
    Aug 13, 2007
    5,339
    Lewiston, Idaho
    It's interesting to me to see the way people load their bikes. A common theme is a honkin' huge bag on the back of the seat. Can't imagine what that does to CG and handling unless it's light and bulky stuff.
  7. borderlinebob
    borderlinebob Been here awhile
    Aug 21, 2016
    428
    CANADA-1/4 mile N of International Falls, MN
    Probably quite similar to carrying a passenger?
    But usually less weight so maybe not as much effect.
    Myself, I removed rear grab handles and rear foot pegs so my Wolfman bags fit better.
    Use tank panniers also so no issues for me with stuff on rear seat.
    Clampett and 1911fan like this.
  8. marchyman
    marchyman barely informed Supporter
    Jun 30, 2005
    13,126
    SF Bay Area
    The only thing wrong with my Exped Downmat is the packed size. And maybe the minor hassle of inflation. I'm a side sleeper who appreciates a pad 9 cm thick. I suppose another negative is the price. I paid a lot less than what they are going for today.
  9. 1911fan
    Aug 13, 2007
    5,339
    Lewiston, Idaho
    I've been told it's possible to pack it into the tiny bag it came in. Haven't tried; I think you'd need a vacuum pump. Side sleeper here too, and the Exped is worth even the current price.
    surferbum likes this.
  10. surferbum
    surferbum Been here awhile
    Apr 25, 2010
    819
    Relocated to Scottsdale, AZ from SF Bay area
    Who says that a honkin' huge bag is heavy
    My 35L dry bag holds my tent, sleeping bag, inflatable mattress and freeze-dried food (<8lbs).
  11. appliance57
    appliance57 Long timer Supporter
    Dec 11, 2014
    2,697
    Boston
    If the bag is between the 2 axles (ahead of the rear) there's some change in CG but not much - assuming <50lbs weight.
  12. 1911fan
    Aug 13, 2007
    5,339
    Lewiston, Idaho
    Good to know on both counts. Thanks!
  13. Ladybug
    Ladybug Bug Sister Supporter
    Nov 6, 2005
    16,391
    Spokane Valley, WA (the dry side of the mountains)
    I've ridden with a big pack on my passenger seat for years and years. It's not a problem at all. It wouldn't be something I would do for technical single track riding but all other riding it's been fine. I have done most of IDBDR (before it was IDBDR), Elk City Wagon Rd., Magruder, Lolo Motorway, Best of Montana, Baja, and many other rides packed heavy and looking cumbersome with no issues..
    When I'm riding and camping multiple days I like having things that keep me comfortable in camp. A good night's sleep is a requirement for me.
    Baja
    Loaded for Best of Montana - The red behind the side bag is a rotopax on each side, one with gas & one with fuel.
    Alaska
    2500 mile street ride to WI via Canada.
    With my bikes being on the small side the pack looks even bigger and heavier then if they same stuff was packed on a big bike.
  14. 1911fan
    Aug 13, 2007
    5,339
    Lewiston, Idaho
    Tell me about Elk City Wagon Road. I was on the Hwy 14 end at Newsome a couple days ago. Where does it go?
  15. Ladybug
    Nov 6, 2005
    16,391
    I started from Lowell, ID heading S on Selway Rd., connected with the Elk City Wagon Rd. and took it to Elk City, ID. It's been a while since I did that one and there may have been a connecting Rd. between Selway Rd. And Elk City Wagon Rd. I used the ID Gazetteer for routing.
  16. 1911fan
    Aug 13, 2007
    5,339
    Lewiston, Idaho
    I know the road from the end of the Selway River Road to Elk City is now closed. There's a washout that you can't get a horse around, much less a bike or quad.
    Thanks, LB, I'll have to check it out!
  17. marchyman
    Jun 30, 2005
    13,126
    SF Bay Area
    Barely knew the gear was there. The bag sticking up on top is my ice chest. It is very light as it only contained dry food. Ice and beer wouldn't be added until I got to camp.
    Bombs4breakfast, gfh, MYUMPH and 2 others like this.
  18. Brutalguyracing
    Brutalguyracing Long timer
    May 15, 2013
    3,347
    Long Island New York
    What cooler is that
  19. Maggot12
    Maggot12 U'mmmm yeaah!!
    Feb 21, 2010
    19,393
    Canada's ocean playground
    One with gas and one with fuel..
    Is this for a stove that doesn't burn gasoline?
  20. cfootball73
    cfootball73 Adventurer
    Apr 17, 2016
    59
    Lake of the Ozarks
    Yeah ive seen them, ive had this one since i was a kid and camped every weekend in colorado with it. one day ill upgrade to a inflatable one.
    Andrew likes this.
