lets see ur bike carrying extra fuel
Discussion in 'Equipment' started by Wistrick, Oct 6, 2011.
  1. AllSeasonRider
    AllSeasonRider Wandering, maybe a little lost...
    Feb 20, 2008
    2,827
    Los Angeles, CA
    I ended up using some aluminum c-channel and some big hose clamps to mount a couple mega tubes with Primus 1.5 liter bottles under the tail. Used some screw holes for the passenger grab rails. Never had to use them, though I need to figure out how to add another 3 gallons or so if I was want to take this bike up the Dalton...
    Baroquenride, L.B.S. and suprbst like this.
  2. nzrian
    nzrian renegade master Supporter
    Feb 20, 2009
    1,717
    Queenstown , NZ
    shit pic, but the rear bags have a 10 litre can in each of them, for a simpson desert crossing.
    about 45 litres all up for about 600km of sand.
    i hit reserve as we pulled into Mt Dare for fuel.
    [​IMG]DSC01903 by rian munro, on Flickr
    Te Hopo likes this.
  3. XRman
    XRman Long timer
    Dec 9, 2006
    8,171
    SW Victoria Oz
    Over tank bags tied to crash bars; 12L fuel bladder and 10 L water. Rolled up and tied to rear rack when not needed.
    Maggot12 likes this.
  4. EastRoad
    EastRoad Road Viking Supporter
    May 10, 2014
    2,072
    Switzerland
    After a paranoid fuel-finding in the midst of france (running low already: first gas station close... second one was fully automated (non-manned) and refused all my cards (I guess their phone line was broken).... third one was the charm... and I wouldn't have made it much further)... I decided to get some add-on fuel just in case.
    But of course as Murphy's law dictates: ever since, I've never needed them.
    anyhow here's the crappy setup in all its glory:
    Essentially its this:
    A 1000 denier cordura two-compartment bag that I've made on my sewing machine... each compartment holds a 2ltr fuel can.
    on each side there's two heavy duty loops double-bar-tacked in place (I've clipped a carbine clip on it and hoisted myself up a few times on the pull up bar... I guess its strong ;) ).
    And I loop a cam-buckle cinch strap through and around the top-case.
    when tightened - the top of the compartments gets "closed" around the bottles - and you can't take the bottles out without first releasing the cam strap.
    it's unobtrusive enough.. doesn't get in the way and can be fully removed if needed.. also the top-case stays fully accessible.
    there's room for improvement ;)..
    it was made in a hurry before my morocco trip...
    Useless... morocco has more gas station than you'll ever need. ;)
  5. EastRoad
    May 10, 2014
    2,072
    Switzerland
    Fuel Bladder??
    like a hydration bladder but fuel resistant?? what are you using?
  6. Nickhob
    Nickhob Armchair adventurer
    Nov 7, 2013
    1,502
    Nyon, Switzerland
  7. EastRoad
    May 10, 2014
    2,072
    Switzerland
  8. AllSeasonRider
    Feb 20, 2008
    2,827
    Los Angeles, CA
    Agree. I'm betting I could get a size that would fit into my backpack. My range now is just shy of 200 miles if I used the bottles I have, but according to Alcan Rider I need range for 320 in case I need to turn back.
  9. KSO
    KSO Grab a Handfull
    Jun 2, 2014
    549
    Idaho
  10. frozenpoet
    frozenpoet Valks rule, clowns drool
    Feb 16, 2014
    1,102
    Strasburg, va
    For those that have mounted a rotopax to a case, mostly thinking the lid, did you do anything to reinforce the mount? My plan is to mount a 1 gallon tank on its side on the top of the truck. (Kappa garda 52l)
  11. XRman
    XRman Long timer
    Dec 9, 2006
    8,171
    SW Victoria Oz
    I have a 12L Liquid Containment fuel bladder from Oz. They make various sizes. price/L of fuel is cheaper than the Desert Fox bladder.
    I don't like carrying them in my luggage in case of fuel smell pervading the contents. I usually clip the bladder to the rear luggage externally when it is full and roll it up and stow it when empty on top somewhere.
    My next big trip will mean carrying the bladder more often ( my DRZ has 30L + 12L) but my Tiger only carries 19L. I will also need water 8-10L to be carried.
    Rather than have all the extra load up high and at the rear the tank sling idea means the load will be central and lower.
    There is a discussion on this in the Australian regional thread at present. heavy duty shade cloth is being used to sew up custom built bags. Mine are replica army surplus items.
  12. kenstone
    kenstone worn out
    Mar 3, 2013
    1,907
    Boysee
    AllSeasonRider likes this.
  13. MotoChron
    MotoChron Got Dirt?!
    May 22, 2005
    1,466
    Tip of the Mitt
    Rotopax on the tail rack.
    Kawasakirob and Te Hopo like this.
  14. ER70S-2
    ER70S-2 Long timer
    Sep 30, 2009
    17,157
    SE Denver-ish
    ^^ Gooseneck below Dead Horse Point on Potash Road, Moab, Utah? :augie
  15. MotoChron
    May 22, 2005
    1,466
    Tip of the Mitt
    Correct.
  16. ER70S-2
    ER70S-2 Long timer
    Sep 30, 2009
    17,157
    SE Denver-ish
  17. fast4d
    fast4d Long timer
    Jul 27, 2007
    3,103
    Los Angeles, CA
    1.6 gal
    feeds into tank using breather hose
    Tall Man likes this.
  18. NumberCruncher
    NumberCruncher Long timer
    May 28, 2009
    1,217
    Spokane, WA
    This is such a simple and effective solution for a rider like me who rides solo that I think I am going to go with it for my trip to Alaska this Summer.
    Do you worry about theft since they are so easy to get to? I may put the gas can in a lightweight nylon stuff sack and then place that on the peg packer bracket. Do you think there is room for the additional thickness of a a thin layer of nylon material?
    Thanks.
    NC
  19. Hikertrash
    Hikertrash Wasted Rock Ranger
    Aug 19, 2011
    4,079
    Arizona
    Are those one or 2 gallon containers?
    Sent from under a rock using Tapatalk
  20. xtremewlr
    xtremewlr Long timer
    Jun 20, 2014
    1,590
    Tucson, AZ
    I made a tail rack using a spare passenger seat and mounted a rotopax for my SV1000 in preparation for doing an IBA Saddlesore 1000 in June.
    HaChayalBoded, L.B.S. and remzamora like this.
