1. eNewsletter Sign Up
lets see ur bike carrying extra fuel
Discussion in 'Equipment' started by Wistrick, Oct 6, 2011.
  1. xtremewlr
    xtremewlr Long timer
    Jun 20, 2014
    1,590
    Tucson, AZ
    I made a tail rack using a spare passenger seat and mounted a rotopax for my SV1000 in preparation for doing an IBA Saddlesore 1000 in June.
    HaChayalBoded, L.B.S. and remzamora like this.
  2. Iron Rey
    Iron Rey Wingnut Extraordinaire
    Mar 15, 2008
    1,308
    Middle of I O Wah
    Never worried about theft, I also usually covered my bike with a Dowco cover as well, kinda like having a portable garage, I would recommend a cover for your Alaska trip.
    These are the two gallon cans, I would say if you have a 250-300 mile range on your bike you would only need the 1 gallon, however, as was in my case, I was hauling fuel also for my friend riding his Sporty, there was never a time on that particular trip I would have needed the fuel.
  3. NumberCruncher
    NumberCruncher Long timer
    May 28, 2009
    1,131
    Spokane, WA
    I'll have a cover with me for sure. Out of sight, out of mind.
    NC
  4. Gedrog
    Gedrog 1000 mile stare a 1000 stories to tell
    Oct 20, 2013
    2,930
    Lost in the Sahara
    Simples a Desert fox Fuel cell strapped to the luggage
    Once done roll it up and tie it to the luggage no bulk no fuss
  5. baka1969
    baka1969 Veteran Bubblehead
    Jan 2, 2012
    1,283
    NE Philly
  6. drbuzzard
    drbuzzard Long timer Supporter
    Sep 14, 2013
    1,146
    42.4n lon 83.02w 625ft
  7. Gedrog
    Oct 20, 2013
    2,930
    Lost in the Sahara
    Aren't you worried to have it so close to the silencer, and dragging on the ground, all that sparks:amazon, or does it have its own skateboard wheels :-)
  8. drbuzzard
    Sep 14, 2013
    1,146
    the wooden cage keeps the heat from the exhaust off the gas can and for ground clearance I haven't had a problem with that either. I use to just strap the can on the rack but on hot days the can would expand causing it to fall over
  9. KEN PHENIX
    KEN PHENIX "CERTIFIABLE"
    Jan 13, 2008
    752
    SOUTHEAST TEXAS
    I cried uncle and did an actual gravity feed fuel cell rig on the cheap. The gory details can be found in the captions of the pics in my smugmug. Enjoy!
    Petrolhead Tom, Dao1, jfman and 2 others like this.
  10. misterk
    misterk Been here awhile Supporter
    May 30, 2008
    643
    DFW Texas
    Uke likes this.
  11. Nnordsman
    Nnordsman Nnordsman Supporter
    Feb 14, 2009
    542
    Carlsbad, NM
    For all of you mounting containers to the back of your panniers, why the back instead of the front? I have found my bikes handle better when the weight in the cases and on the bike is as far forward as possible. What am I missing?
  12. JT105
    JT105 Let's Ride!
    Jun 24, 2014
    451
    SE Michigan
    Mounting things on the front of the panniers encroaches on the rider's leg and foot room. If the bike goes over, there is a risk of the panniers and mounted items trapping the rider's leg or foot.
  13. Fr8dog61
    Fr8dog61 Been here awhile
    Aug 15, 2016
    373
    Lake Barkley
    I'm prepping a single cylinder GS, and your pictures dropped off. Would you be so kind as to re-post?
    Thanks...
  14. Uke
    Uke visualist Super Supporter
    Oct 9, 2013
    4,259
    HouTex USA
    Can you share some details on the auxiliary tank, capacity, source, mounting, plumbing?
  15. misterk
    May 30, 2008
    643
    DFW Texas
    Bought tank on EBay, (bam manufacturing) bought the valve and plumbing from tour tank. I am using a 1.6 gallon, gravity fed into tank. The NC tank is under the seat. I drilled a hole in gas cap, used jb weld, i have a valve i can turn off and on while riding under the aluminum plate I replaced with the passenger seat.
    Sent from my iPad using Tapatalk
    Uke likes this.
  16. kermitridesagain
    kermitridesagain Been here awhile
    Apr 24, 2012
    620
    ireland
    think your luggage cost more than my klr
    kalonji, ER70S-2 and George Hanson like this.
  17. DivingDuck
    DivingDuck n00b
    May 12, 2016
    2
    Germany
    Moin,
    how did you fasten the holsters? Have you just drilled holes through the pannier walls? I'm afraid the plastic's too weak.
    Regards,
    DD
  18. kag
    kag Wander Lust
    May 29, 2012
    2,433
    Kansas
    Yes I drilled holes through the plastic then threaded the small bolts through.. Of course on the inside there are flat washers that increase the surface holding area. This set up is rock solid. On the left side I could of mounted two bottles side by side with no issue.
    DivingDuck likes this.
  19. DivingDuck
    DivingDuck n00b
    May 12, 2016
    2
    Germany
    Many thanks. That's just the encouraging bit of info I needed. I'm going to mount Touratech's base plate(s).
  20. ElMartillo
    ElMartillo I See Faces...
    Sep 18, 2009
    966
    Nationwide, USA
    I converted a surplus windsheild washer tank into an aux fuel cell for my '83 XL600. Approximately 2 useful gallons gets me around 80 additional miles.
