lets see ur bike carrying extra fuel
Discussion in 'Equipment' started by Wistrick, Oct 6, 2011.
  1. ElMartillo
    ElMartillo I See Faces...
    Sep 18, 2009
    966
    Nationwide, USA
    Ebay. Cost around $35. I'll try to find a link. Only drawback is the rubber gasket that seals the removable cap swells with exposure to fuel vapors, so I have to flip it each time I remove the cap. Really needs a big viton o-ring instead.
    Link:
    http://m.ebay.com/itm/121311349509
  2. ben2go
    ben2go Long timer
    Jun 23, 2011
    7,522
    Gone
    How well does the foam work? Any restrictions? I've ofter wondered if it can release the fuel fast enough for a gravity feed system.
  3. ElMartillo
    Sep 18, 2009
    966
    Nationwide, USA
    It's relatively large, open cell. Drains plenty fast. Acts as a baffle, works very well in that regard. I consider it to be a prefilter of sorts, as well. :thumb
    ben2go likes this.
  4. Mercury264
    Mercury264 Once you go Triple...
    Nov 7, 2005
    25,001
    Masshole
    No issues with the plastic reacting to the gas ? What box is that on the back (and will it fit a full-face helmet) ?
  5. ElMartillo
    Sep 18, 2009
    966
    Nationwide, USA
    The fuel cell is made of polyethelyne, the same material most aftermarket desert tanks are made of (Acerbis, Clarke, etc.), as well as those red gas cans we are all familiar with. No issues.
    The box is a surplus, no name. Similar to Seahorse or Pelican, but not quite as high quality. Just under the size to fit a full face, but great for waterproof, lockable storage for groceries or touring.
  6. Tall Man
    Tall Man Medium timer
    Jul 14, 2007
    6,643
    The Occident
    2 gallons? Was that washer tank removed from a locomotive?
    I'd wager that the plastic used for the washer tank isn't compatible with motor fuels.
    Edit: Seems I was right.
  7. Bayner
    Bayner Long timer
    Mar 27, 2008
    2,372
    Penticton, BC, Canada
    Probably a Volkswagen.
  8. Baroquenride
    Baroquenride Everyone dies, but not everyone truly lives.
    Apr 10, 2011
    4,139
    Clark Co, Wa
    I like the resourcefulness of using that washer tank!!! I'm not sure that would work for my needs, but I'm hoping I can use that solution in the future.
  9. ElMartillo
    Sep 18, 2009
    966
    Nationwide, USA
    Dao1, turbodieseli4i6 and ER70S-2 like this.
  10. ElMartillo
    Sep 18, 2009
    966
    Nationwide, USA
    Uh oh. I noticed some cracks forming in the washer reservoir yesterday. Looks like it's being affected by the fuel after all. Bummer.
    Looks like I'll order the purpose-built 3 gallon. I'll post photos when installed.
    Dao1 and ER70S-2 like this.
  11. Maggot12
    Maggot12 U'mmmm yeaah!!
    Feb 21, 2010
    19,399
    Canada's ocean playground
    Could have been the way you had it strapped down and these were the stress points.
  12. ElMartillo
    Sep 18, 2009
    966
    Nationwide, USA
    I'll err on the side of "maybe, but the way it looks in person, I don't think so".
  13. tomo8r
    tomo8r Long timer
    Oct 9, 2014
    1,212
    Bathurst
  14. ElMartillo
    Sep 18, 2009
    966
    Nationwide, USA
    ER70S-2 likes this.
  15. Schlug
    Schlug JockeyfullofBourbon
    Jan 23, 2006
    12,110
    put something on and stay in that position.
    Taken just outside of Churchill Falls on the Trans-Lab. In fact, that's how I carried fuel for the entire Newfoundland/Labrador trip. Only needed it from Happy Valley/Goose Bay to Cartwright. Worked a treat.
    Held up to the 60 MPH Trans-Lab gravel road test.
    Right fork seal did not. Note fork oil on right boot.
    ben2go and Magus like this.
  16. ElMartillo
    Sep 18, 2009
    966
    Nationwide, USA
    New tank mounted, plumbed, working:
    bozmotodual16, Manny U, N-m and 3 others like this.
  17. JT105
    JT105 Let's Ride!
    Jun 24, 2014
    456
    SE Michigan
    Nice setup with the new tank. Does that gravity fill into your main tank when you open the valve or is it a sealed system and gets siphoned as the main tank gets drawn down?
  18. ElMartillo
    Sep 18, 2009
    966
    Nationwide, USA
    Thanks.
    Each tank has it's own shutoff valve and filter, but is plumbed to the carb via a "Y" fitting. If I keep the main tank valve closed and the aux tank open, the bike runs off the aux till it's drained, at which point I open the main tank valve and close the aux.
    ER70S-2 and woody071585 like this.
  19. GulfAdv
    GulfAdv Adventurer
    Apr 13, 2016
    10
    Bahrain
    Camel Tank or my F700GS 2016 is a great upgrade for carrying extra fuel.
    bozmotodual16 likes this.
  20. VIGUY
    VIGUY So many trails, so little time.
    Sep 22, 2007
    4
    Vancouver Island - BC, Canada
    Damn just the solution i was looking for. Had considered one of the Acerbis Aux tanks but at better than $160 that was way outside what I wanted to spend.
    This is a perfect solution, plus it looks pretty cool. Who says you have to fill the bottles with fuel? :-) Thanks
