Lets see your Vintage Japanese Motos!
Discussion in 'Old's Cool' started by Kaptainkid1, Dec 9, 2015.
  1. bodine003
    bodine003 Long timer
    Jun 18, 2015
    1,952
    Melbourne Florida
    GS-750.jpg GEEZER GLIDE.jpg Couple of GS-850's around here also.
  2. liberpolly
    liberpolly Lazy rider
    Sep 21, 2015
    6,924
    Seattle
    Almost there, I set myself rule - one project at a time. Currently tackling the front sprocket. Cannot take the cover off - the screws are fused. No local hardware store has an impact driver, ordered one online. Waiting...
  3. ShOqUePoT
    ShOqUePoT GS Pot
    Mar 22, 2009
    8,556
    The VT of MA
    Just because it took me so long to find out about these I'll ask: do you have a set of JIS screwdrivers? They help a lot.
  4. liberpolly
    Sep 21, 2015
    6,924
    Seattle
    Yes, ordered them on Amazon a while ago, screwdrivers and bits. Still torn off the screw head...
    ShOqUePoT likes this.
  5. Rizingson
    Rizingson Vintage Rider
    Sep 27, 2013
    728
    Parker, CO USA
    My 1969 Honda Z50A K1, a first motorized bike for many of today's Boomers
  6. tom c
    tom c Teflon Tommy Supporter
    May 21, 2012
    8,593
    Delaware
    Picked up the DelMar tag today on my 74 CB550:
  7. PJay
    PJay Any bike, anywhere
    May 24, 2007
    1,526
    Russell, New Zealand
  8. BOOTLACE
    BOOTLACE Bikie Scum. Supporter
    Dec 24, 2005
    12,558
    Methane Central..(Sth Gippsland)
    Goodonya! :1drink
    Dunno. Guess I’d need to pull em off, and have a look if it really makes any difference? :scratch
    Well done old chap!
    :confused
  9. Rizingson
    Sep 27, 2013
    728
    Parker, CO USA
    Those heads are on correctly. Same orientation as mine as well as seen in this ad by Suzuki. 14125615_146239625819314_7853094482969090616_o.jpg
  10. PJay
    May 24, 2007
    1,526
    Yes, on the blue bike and the one in this ad - but see the black one in Bootlace's post that I was referring to.
    The fins and plug positions give it away.
    It would make sense to me that the greater area of finning would be nearer the exhaust side (and fits Suzuki design practice of the time), even though aluminium alloy is said to have the advantage that it heats fairly uniformly and loses heat similarly regardless of the precise configuration of the casting.
  11. hank2
    hank2 n00b
    May 3, 2012
    7
    Eastern PA.
    1981 GS650G. "The oddball". Plain bearing shaftie.
    chazbird, wfrpalm and tom c like this.
  12. JBSmith
    JBSmith Ink-stained wretch
    Dec 29, 2003
    5,595
    Southern Oregon coast
    Plain bearing--I never knew that. My 850G had a ball-bearing crank; I think all the other air-cooled two-valve fours did, too, though I'd not swear to it.
    The 650GS was underappreciated, IMO. The 850/1000/1100 shafties were just too damn big and heavy.
  13. hank2
    hank2 n00b
    May 3, 2012
    7
    Eastern PA.
    I just got the 650G late last year. It was the only 4 cylinder Suzuki with plain bearing bottom end. Way higher oil pressure, big pump. It was said to a direction that Suzuki was thinking about taking at the time. Strangely enough, the GS650E chain model had a roller bearing crank like the 550 with mostly the same head as a G model. They were real proud of the combustion chamber design on these 650's. It's a fun little porker with better mid range than 674cc should have.
  14. Rusty Rocket
    Rusty Rocket Life behind "Bars"
    Dec 22, 2005
    17,037
    Tri- Cities TN
    I tried finding one of those for a long time without success. Nice bike you have there.
  15. hank2
    hank2 n00b
    May 3, 2012
    7
    Eastern PA.
    Thanks. Been going through things with plenty do still do. Very rideable now. In my part of the world, they are scarce, although the "L" version of all the Suzi GS's are much more common. I've seen some outrageously well kept GS850GL bikes for less than $1k.
  16. Rusty Rocket
    Dec 22, 2005
    17,037
    Tri- Cities TN
    I saw "L" models in my search. Never cared for those, even back when they were new.
    My dad had a GS850G 1980 model. Really nice bike. I worked at the dealership he bought it from. I did not make enough money to afford one.
  17. JBSmith
    Dec 29, 2003
    5,595
    My 850G. (I forget the year, but it had points.) Nice bike, but even back when my knees worked it was too big and heavy.
    hank2 and Rusty Rocket like this.
  18. Vikingtazz
    Vikingtazz Will ride for food.
    Aug 15, 2010
    1,660
    Prescott Ontario, Canada
    My '73 CB500 - have been getting some early rides in this season after restoring it last summer.
    hank2, Isaanbiker, RolyKBiker and 3 others like this.
  19. Isaanbiker
    Isaanbiker n00b
    May 14, 2020
    6
    Sisaket/ Thailand
    two.jpg Here's my ride, a 1995 1100 cc Virago from Japan, The engine number and frame number starts with 4 PP and it's special. The first, second, third, and fourth gear has one more tooth, the fifth gear has two more teeth. That, on the other hand, makes my engine turn less RPM's when others are already in the red zone.
    I could never try my end speed, as Isaan is way too dangerous. The fastest was 175, but then came a U-turn and of course did the idi_t drive out and almost killed me.
    Vikingtazz likes this.
  20. RobbieO
    RobbieO Muskokatard
    Mar 24, 2007
    11,368
    Dumpmere - Muskoka
    Fun, aren't they?
