Lets see your Vstrom OFFROAD!
Discussion in 'Japanese polycylindered adventure bikes' started by LaOutbackTrail, Aug 1, 2006.
  1. eakins
    eakins Butler Maps
    May 29, 2002
    38,933
    Fort Collins, Colorado
  2. The Sexy Medic
    The Sexy Medic Been here awhile
    Mar 4, 2017
    118
    Kings County, Nova Scotia, Canada
  3. Whiskey Tango
    Whiskey Tango 1*
    Mar 16, 2008
    1,329
    I cannot speak for Righty65 but I did something very similar for my V-Strom by cutting to an appropriate length a piece of ABS pipe and installing rubber expending plugs on each end. I was planning on using clean-outs on each end but I didn't have enough room to go beyond the diameter of the pipe I was using so I used the rubber expanding plus because they go on the inside rather than a clean-out plug adapter which would be glued to the outside of the pipe. U-bolts and straps finished off the installation to int inboard sides of my pannier mounting racks.
    davyjones likes this.
  4. Bultaco206
    Bultaco206 Back-to-back motos suck Super Moderator Supporter
    Feb 11, 2007
    70,423
    Mineral Point, WI
    :photog
  5. Righty65
    Righty65 Wet behind the ears
    Nov 28, 2013
    403
    Shedd, OR
    I'm very happy with the tool tube. My friend welded the mounting brackets.
    I like that it's 4" diameter let's me get my arm inside, to reach the tool bag at the bottom.
    I placed a nyloc nut on the top plug as a sort of lock. It requires a 14 mm socket to open.
    I keep a socket and ratchet under the seat, that I can get to if I use my key to remove the seat. Then I can gain access to my tools and air compressor that are inside the tool tube 20200523_204658.jpg 20200523_204629.jpg 20200523_204621.jpg 20200523_204616.jpg 20200523_204610.jpg
    davyjones and Deleted405664 like this.
  6. The Sexy Medic
    Mar 4, 2017
    118
    sbn and vanislejay like this.
