Let's talk sleeping bags
Discussion in 'Camping Toys' started by BaRRaCuda1974, Oct 10, 2018.
  1. Ragin Rabbi
    Ragin Rabbi Semper Fidelis
    Sep 24, 2006
    14,519
    Western Maryland
    I have a Mountain Hardware Lemenia 30 degree bag. I’ve had it for fourteen years now.
    Packed it’s about nine inches long, about six inches in diameter (I can make it a small ball if I want).
    Synthetic as I do a lot of backpacking and learned long ago that a wet bag sucks, a wet down bag sucks a lot. I needed a bag to do both Moto-tour and backpack.
    Easy to pack, light, easy to clean, and obviously long lasting (durable).
    I sleep warm, so a thirty degree bag is way too warm most of the summer, just warm in the fall, and pretty comfy in the early winter.
    #61
    Don03st likes this.
  2. ohgood
    Sep 21, 2010
    9,692
    alabama
    for really cold campouts.... one light duty bag slipped into a heavier duty bag.
    for less cold, just use either of them.
    the Walmart bags are fine for this, although i know tons of guys will swear it's inferior/bad/certain death/fireball/whatever.
    #62
    thelastfoiter likes this.
  3. CaymanRider
    CaymanRider KMan
    Oct 11, 2013
    62
    Cayman
    #63
  4. theloop
    theloop Long timer
    Feb 15, 2013
    1,290
    #64
    Snake Oiler likes this.
  5. Bikerboy
    Bikerboy Been here awhile
    Dec 17, 2003
    268
    I heard that duck down sleeping bags had some smell when they are in a humid environment. This was a while back . They may have improved on this . Please report back on your experience. I’m looking into a duck down quilt but unsure about this
    #65
  6. Anders-
    Anders- 690R
    Aug 23, 2013
    3,912
    Швеция
    Another downside with duck is less lift.
    #66
  7. shrederscott
    shrederscott Long timer
    Mar 19, 2014
    2,593
    denver
    HI
    For years I have only used high quality goose down.
    3 years ago I bought the Serra Designs 700 fill backcountry bed ... they use duck down. ... I can not tell any difference.
    Key to me is high quality down 700 + fill ratings.
    Scott
    #67
  8. theloop
    theloop Long timer
    Feb 15, 2013
    1,290
    I think this may be true. But to get a bag or quilt that has the same temperature rating with duck or goose, it should have around the same loft (thickness) since there will be more ounces of fill with the duck to get the temp down to what the goose item is rated for, so the goose item will weigh less and pack a little smaller, I hope this makes sense.
    #68
  9. Motor7
    Motor7 Long timer
    Sep 16, 2013
    1,514
    East Tennessee
    Will do. I have been hanging for 4 years now and still fight cold when above 8,000 feet. Recently added a UQ, a insulated Exped selfinflator and a Costco quilt....almost there so the down bag should put me over the top.
    #69
    Snake Oiler and kjbetz like this.
  10. O'B
    O'B Long timer
    Feb 19, 2011
    6,084
    Passing By The Highway
    Feathered Friends
    Seattle Wa!
    #70
    CaymanRider likes this.
  11. Bayner
    Bayner Long timer
    Mar 27, 2008
    2,340
    Penticton, BC, Canada
    I have a bag from Taiga, as well as one from Feathered Friends. Both are very good quality and 'locally' made.
    #71
  12. Cilantro
    Cilantro Adventurer
    May 29, 2018
    90
    North Alabama
    #72
  13. Tanker4me
    Tanker4me Old, just effn old. Supporter
    May 15, 2015
    132
    LoCal
    I didn't know anything about BA bags, got stuck buying the Big Agnes Lost Ranger 15 deg. down bag 5 years ago while on a desert trip.
    The bag I had wasn't going to cut it as the forecast low temps were to be in the mid 20s F.
    The only bag rated at 15 F available at the local outfitter was the BA.
    It has worked for me down to 20 F.
    I've been happy with it so far, but it has never been wet so I can't comment as to its hydrophobic qualities.
    The air mattress sleeve system works amazingly well.
    #73
    kjbetz likes this.
  14. LateToTheGame
    LateToTheGame Been here awhile Supporter
    May 9, 2016
    188
    Wisconsin
    I've had great experience with Western Mountaineering bags. I use an Apache Super Dryloft (rated to 20 degrees F) for backpacking and climbing in non-winter conditions. I would probably not purchase this bag again because the Extremelite series bags have gotten so much better. The Apache Super has proven durable (18 years old now), warm, stuffable, and the workmanship is amazing. A Versatile or Alpinelite would be even lighter and more stuffable.
    As for temperature ratings, I don't see the point of buying something rated below 20 degrees unless you have some other use that requires sleeping in colder temperatures. But then I sleep reasonably warm, and the Western bags are very conservative in their ratings. My Apache is rated to 20, I've slept comfortably as low as 14 degrees in it.
    #74
  15. Snapper
    Snapper Long timer
    Oct 10, 2003
    3,405
    SW CT
    My favorite set-up is a Jack-R-Better Sierra series quilt/poncho paired with Mont Bell Hugger series mummy. Can cover a wide temp range using one or the other or both. The quilt in poncho mode negates the need for a cold evening/morning campsite wear (eg, down jacket) and is far warmer for the same weight due to the 'mitten' effect of all limbs inside while sitting cross-legged on a pad. Set-up a candle (I use my stove as an alcohol candle) in the protected triangle of your legs, and you can get deep heat soak (nicer than a hot tent) for crawling into bed almost 'hot' (Palmer Furnace concept).
    The hugger series mummy bags use elastic so has the stretch space for the quilt inside, and the mummy solves the quilt-alone draft problem if you toss and turn. I also have the hood for the poncho quilt.
    #75
  16. CopaMundial
    CopaMundial Wow, that broke easy
    Jun 27, 2008
    1,869
    US, SE PA & Central ME
    +1
    I find the Backcountry Bed great for use in my hammock (plus an under quilt in place of a pad in cold temps)
    The top ‘blanket’ section can be pulled up snug or left down, and I love the handy opening where you can have feet either inside or outside the bag while the rest of you stays covered. Very easy to adapt to the range of temperatures you get even in a single night.
    Much more convenient temperature control than any zipper type bag that I have used in the past.
    #76
  17. Nerb
    Nerb Been here awhile
    Jan 29, 2008
    636
    SE Melb
    I bought myself a reasonable quality duck down bag rated to -5 (23F) about 4 years ago but last time I used it I was cold. Ive been keeping it in its compression sack in the cupboard and was told I should have stored it unpacked and hanging. It that true? Have I killed it? Can it be resurrected?
    #77
  18. BluegrassPicker
    BluegrassPicker Been here awhile Supporter
    Nov 1, 2006
    544
    Rochester, MN
    throw it in the dryer on the delicate setting then store it uncompressed
    #78
    Jim K. likes this.
  19. Nerb
    Jan 29, 2008
    636
    SE Melb
    Thanks, I will give that a go!
    #79
  20. Bikerboy
    Dec 17, 2003
    268
    I would wash it . plenty of videos on how to wash it safely. Google search is your friend.
    #80
