1. Hey everyone, We’re going to start a weekly email to surface interesting threads in the forums. No worries, you can easily unsubscribe if you don’t find it interesting. If you’re like me, it’s nice to have someone willing to poke around a big community like ours and find the most interesting stuff. Saves time and I hate missing something great. It worked really well when we had someone discovering the best photos for the home page rotation back in the day. And if you have something fascinating to post, maybe this email does everyone some good by getting it noticed. Let us know what you think when you get it. Your feedback will make it better as we go (thread). Thanks! Baldy & rudy1220
    Dismiss Notice
Lever setup
Discussion in 'Trials' started by heffergm, Aug 2, 2018.
  1. heffergm
    heffergm Long timer
    Sep 22, 2014
    2,091
    Turns out, Pat and I have basically the same setup! That's why we ride so much alike obviously... :rofl
    Brewtus likes this.
  2. lineaway
    lineaway Long timer
    Oct 1, 2011
    8,502
    nm
    All the top riders run the clutch lM/C tight to the grip giving a hard pull, but an instant response. For us mortals just the opposite set up works for a longer throw and lighter clutch.
    MATTY, Fallacy and laser17 like this.
  3. heffergm
    heffergm Long timer
    Sep 22, 2014
    2,091
    My clutch side. As for angle, looks like (depending on where you measure) I'm at ~25-27 degrees down angle.
  4. motobene
    motobene Motoing for 46 years
    Mar 9, 2013
    5,144
    Wichita Mountains SW Oklahoma
    IMG_20180802_091943.jpg In detail R Us. The Motobene setup:
    15 degree down angle on levers (inclinometer on grip and on top of the lever), 11 degrees actual.
    Clutch perch 3.10" from the left grip flange.
    Front brake 1.40" from the throttle housing.
    I'm with Lineaway.
  5. 2whlrcr
    2whlrcr gooligan
    Jan 30, 2005
    12,165
    Dubuque, Iowa
    My bike has two levers on it...that's all I know.
    Buschog likes this.
  6. wheelieman14
    wheelieman14 Adventurer
    Apr 14, 2014
    63
    Until you ride motobene's bike, or have him adjust your bar angle and lever setup; you will not understand how much easier it is to control your bike with very little effort. 5 weeks after Chris helped me setup my Evo (200 & 300) I managed to have a "perfect day" with zero points dropped and 32 Cleans in sloppy conditions at NETA Championship Event#6 of 13 in Berwick, ME. Thanks Chris!
  7. motobene
    Mar 9, 2013
    5,144
    This issue is very programming based. The reasons behind preferences can be solid, or just 'used to.' People can get used to suboptimal and swear by that.
    It's complicated. Our bodies, minds and usage scenarios aren't all the same.
    Pat's bikes are to me stiff, abrupt, and a little ergonomically suboptimal in lever position. He is obviously well integrated to that and his trials world/level is different than mine... and most of us.
    You have to do what fits you. The difficult part is seeing outside the bubble and 'objectifying' the direction of more optimal and being able to justify that to yourself and others. While there is no final destination, there is direction.
    One of the short circuits in sports is conflating riding skill with everything else. Lend Vintagepro an ear and he will tell you many stories of working with (or trying to work with) top riders on suspension :-)
    One great aspect of neuroplasticity is that we can adapt or program our way around many impediments. It's why 'close enough' ends up good enough almost always.
    MATTY, slicktop, Norman Foley and 5 others like this.
  8. 2whlrcr
    2whlrcr gooligan
    Jan 30, 2005
    12,165
    Dubuque, Iowa
    I looked at mine, didn't measure anything, but my levers are slightly further inboard and I would guess about a 15 degree angle. My clutch engagement is close to the grip, as soon as I start to release my clutch finger, the clutch starts engaging. This is how I like it, so I'm not changing anything.
    #8
    MATTY, Brewtus and Huzband like this.
  9. fprintf
    fprintf Been here awhile
    Oct 24, 2017
    152
    Connecticut, USA
    When I rode Wheelieman14's Beta 300 this Spring, this close to the bar clutch engagement was one of the things I found hardest to get used to. I felt like I was smashing my fingers trying to keep the clutch from engaging! I just figured that is the way trials bikes are setup and I was going to struggle with that until I got used to it or that it meant I should be riding without the clutch to give the tops of my pinkie, ring and middle fingers a rest (using index finger on the clutch). I'm sure nerves played a role too, so I was squeezing way too hard to make sure the bike wasn't going to leap forward on me. :-)
    #9
  10. motobene
    Mar 9, 2013
    5,144
    You should ride it now. Much better, as wheelieman14 said :-)
    This ergonomic thing is subtle but very important. If you are in a bubble about it, it's hard to see another way without directly experiencing it.
    #10
    fprintf likes this.
