Lightweight 790 Pic & Build Thread
Discussion in 'Parallel World (790/890)' started by MaineDrummer, Aug 11, 2019.
  1. Nowwhat
    Nowwhat I'll Go Second... Super Supporter
    Mar 2, 2007
    8,309
    On the Ground Laughing
    Going to put less gas in the tank hahahaha
    Seriously. I am out of places... latest pic all buttoned up. Fairing to tank pieces arrived as did the pigtails to connect the lights...
    When someone makes some billet triples I am in... 20191003_175110_1570204643418.jpeg
    #41
  2. windblown101
    windblown101 Long timer Supporter
    May 17, 2010
    5,598
    Star Tannery, VA
    Needs Air forks... :)
    #42
  3. Nowwhat
    Mar 2, 2007
    8,309
    AER Cone Valves....hahahaha....too much bike...
    #43
    windblown101 likes this.
  4. NoelJ
    NoelJ Been here awhile
    Apr 7, 2016
    975
    USA
    LOL...is that even a muffler, or more of a megaphone?
    Rimlocks? Lots of wheel weights there.
    #44
    undingen likes this.
  5. 2 SPOT
    2 SPOT bring the rape whistle
    Dec 14, 2005
    6,569
    Payson AZ
    looks good nowwhat,,,, crazy small muffler, how does it sound? and tthats is alot of wheel weight. how ya liking the fairing?
    #45
  6. Nowwhat
    Mar 2, 2007
    8,309
    Had to try to make it sound like a SE hahaha
    Fairing ... no regrets...no buffeting.....
    Yeah hopefully next front tire balances out easier
    #46
    2 SPOT likes this.
  7. 2 SPOT
    Dec 14, 2005
    6,569
    Payson AZ
    ive had a few scorp rally tires, really like them, but the last one i got had a wobble from a bad belt or something in the carcass, i've read a few others having quality issues with them as well, and now yours obviously has a very heavy spot? i think the QC on these tires might be lacking lately.
    #47
  8. Nysane
    Nysane n00b
    May 17, 2017
    8
    That's an SC S1 muffler, correct? Was it an off-the-shelf unit made for a Duke 790, or did you have to modify and tweak the pipe? I'm thinking about doing a similar thing on my 790 Adventure R, so would be grateful for any insights or advice. Thanks!
    #48
  9. Nowwhat
    Mar 2, 2007
    8,309
    Yup. It is the Duke pipe with a custom mid pipe...also has a spark arrestor welded inside....
    #49
  10. comac90
    comac90 Where's Charlie?
    Aug 26, 2009
    298
    Asheville, NC
    Like the fairing . who makes that?
    T
    #50
  11. Nowwhat
    Mar 2, 2007
    8,309
    Rebel X out of Italy....good stuff
    #51
    comac90 likes this.
  12. Nevada
    Nevada Been here awhile
    Oct 4, 2009
    349
    Utah Valley, Utah, USA - unless out riding.
    2lbs?
    Replace the fork shields with carbon fiber held on with titanium hardware. That might get you there.
    #52
  13. RibRoy
    RibRoy RibRoy
    Jan 29, 2011
    359
    Norway
    #53
    BobcatSig and CaseyB like this.
  14. strongleftleg
    strongleftleg Party Guy Supporter
    May 13, 2007
    276
    Vancouver,BC,Canada
    @RibRoy Please tell us more about your windshield!
    #54
  15. RibRoy
    RibRoy RibRoy
    Jan 29, 2011
    359
    Norway
    #55
  16. 1coolbanana
    1coolbanana Long timer
    Aug 25, 2009
    6,119
    NW Sydney, Australia
    You blokes that are doing a single rotor and tubed tyre/rim...
    The weight of a HD tube would nearly negate the loss of a rotor wouldnt it?
    HD tubes a heavy and especially the gyro effect out so far compared to a rotor.
    Just a question, not a criticism :-)
    #56
  17. Nowwhat
    Mar 2, 2007
    8,309
    2mm tubes not the UHD tubes
    Yup tubes add weight....but I have no choice. I cant run a tubeless wheel where I ride...it simply wont survive..
    My front wheel and tire are lighter than stock ... trying to make up for it..
    Also running a lighter rotor...
    Then there is the helium
    #57
    1coolbanana likes this.
  18. OhDuh
    OhDuh Adventurer
    Dec 27, 2019
    52
    Ger
    I suppose you always could ditch the back plastics including the compartments. Maybe they are another 400g or so
    #58
  19. Gaulin
    Gaulin Orange (& Blue) Crush
    Nov 20, 2004
    301
    Manitoba, Canuckistan
    460 g each actually. Not insignificant if you're trying to squeeze out everything you can. This is more weight loss than you'll see throwing Ti fasteners everywhere.....
    #59
  20. nibby
    nibby Been here awhile
    Feb 22, 2009
    415
    U.K. - Liverpool
    I know it's not the front but I've just swapped out the stock rear wheel with the same e09 tyre tubeless for the new DID rear, same tyre but with a uhd tube and rim lock - new rear with tube was lighter than stock rear tubeless - So if similar on the front then single rotor will be even lighter with the uhd tube.
    That's only of course if the front wheel is lighter than stock but it normally is from my experience previously.
    I'm really thinking about converting to a single front rotor as getting weight off the front should make it feel pretty good?
    @Nowwhat your thoughts? you happy with it off road and acceptable on road? - What are the weight savings in total going this route?
    cheers
    #60
