"Liquid" container bags
Discussion in 'Vendors' started by Scribe, Jan 24, 2015.
  1. cchristo
    cchristo Adventurer
    Dec 3, 2014
    41
    San Antonio, TX
    I made mine. Here's the short version. I folded a piece of nylon laminated canvas duck material over the bag with the fold on the bottom. Traced the back side around the container. I traced about 1.5 inches away from the edges on the Front side. I then marked where I wanted my loops to go. I cut it leaving a little extra to play with during dry fitting.
    I made the loops out of the same material and sewed them on.
    After a few trial fittings and some trimming, I sprayed heavy duty adhesive to the container and the material and carefully laminated the material to the container.
    It'll go pretty good as long as you do a few dry runs and strategic trimming before applying the glue. Use masking tape to keep glue off any parts of the material you don't want it on. It's some nasty stuff if gets anywhere you don't want it!
    If all that is too much effort, buried somewhere in this thread is a reference to a guy who can make one up for you to a professional standard.
    Front:
    Back:
    101, redrock88 and JagLite like this.
  2. grace
    grace Long timer Supporter
    Aug 22, 2006
    1,391
    denver co usa
    i just ordered one from the website.
    to those who have purchased and used these liquid containers, what's the feedback? vapor? durability? issues? caveats? tips? benefits?
    thank you.
  3. Eatmore Mudd
    Eatmore Mudd Mischief on wheels.
    May 28, 2012
    3,984
    Wet side of WA.
    Lock em up if you don't want em to disappear. They blow dromedary bags right out of the water.
    They're built like tanks from thick multi ply fabric reinforced synthetic stuff. Mine don't leak, seep or reek and the spouts a good length and plenty flexible.
    JagLite and grace like this.
  4. grace
    Aug 22, 2006
    1,391
    denver co usa
    thank eatmore mudd.
    btw, for anyone considering the desert fox 5000 bladder. don't. i bought one and after only a couple of uses, the inner liner punctured, apparently from the fuel nozzle at the gas station. fuel leaked into an outer liner (not the outer fabric) which meant squeezing bag to get the fuel back into the inner liner before i could get fuel out of the bag. a waste of money.
    Dao1 and JagLite like this.
  5. Gedrog
    Gedrog 1000 mile stare a 1000 stories to tell
    Oct 20, 2013
    3,957
    Lost in the Sahara
    I have had no issues I have even had the odd spill, however use the supplied D-Dring to fasten it to your bike not the attached straps these are meant to be used when storing the Fuel Bladder as Wiz-AU found out.
    @grace interesting to know, I have not encountered that before mine has 10K miles on them and during my trip the got regular use, I do use caution because the the first time I filled up I noticed that the fuel nozzle was dropped and had a sharp edge on it so I was always cautious as sharp edges and bags don't mix, but at least look at the bright side you did not lose your fuel although getting it back was a pain in the but.
  6. Eatmore Mudd
    May 28, 2012
    3,984
    Wet side of WA.
    This thread and the custom sewing and cordura items thread has me thinking about getting a set of tank bags made up. Anyone done it already ?
  7. lukasteam
    lukasteam Life is beautiful !!! Supporter
    Apr 6, 2009
    715
    Naperville,IL
    Mine don't leak , but reek gas like crazy . If I put it in bottom of my top box or one of the side boxes for lower center of gravity all my clothes that I have in there reek like gas too .
  8. Scribe
    Scribe £Bob£
    Nov 8, 2004
    13,737
    In my natural state
    Yeah, they can be a little stinky. I only use mine outside luggage, and for as short a time as possible. When not in use, fold in half then put in a gallon ziplock (or other) bag.
    On a business note, I'm out riding, and then moving, so the store is closed until August. See you out on the trails!
    phreakingeek likes this.
  9. Gedrog
    Oct 20, 2013
    3,957
    Lost in the Sahara
    I have to agree I also rather keep them externally especially if they have an outer gore tex cladding on them that first time you mess petrol on them they are for sure going to stink up anything they get in contact with and not an easy smell to get rid of.
  10. worthydog
    worthydog Shosholoza Supporter
    Sep 15, 2007
    764
    Santa Barbara, California
    does the containment bag fit in a 1 gallon ziplock when empty? Is there a bigger ziplock you could put the bag into when full?
  11. grace
    Aug 22, 2006
    1,391
    denver co usa
    i doubt that fuel and plastic bags work well together.
    JagLite likes this.
  12. worthydog
    Sep 15, 2007
    764
    Agreed. Im thinking using them to store the empty container after use.
  13. JagLite
    JagLite Long timer Supporter
    Jun 17, 2010
    9,503
    Anchorage Alaska
    I doubt the container bag would fit in a gallon size zip lock bag.
    It is quite thick and stiff material.
  14. worthydog
    Sep 15, 2007
    764
    I just found some 2.5 gal ziplock bags that might work to isolate the container bag stink. Will report back
    IDRIDR and JagLite like this.
  15. grace
    Aug 22, 2006
    1,391
    denver co usa
    for those interested, brady, at this thread, made me a bag for the liquid container and i feel quite pleased with the outcome. it's pretty darn perfect. if you looking for a bag for a liquid container, contact brady. excellent quality. made of 1000d cordura -so, it's tough. he can customize with colors.
    JagLite and PYG RYDR like this.
  16. grace
    Aug 22, 2006
    1,391
    denver co usa
    another pic:
    JagLite likes this.
  17. phreakingeek
    phreakingeek Big Ear Inc - Virginia Provider Super Supporter
    Sep 17, 2010
    2,349
    VA
    What a great idea, now why didnt I think of that? Oh yeah, I did...like 2 years ago.
  18. grace
    Aug 22, 2006
    1,391
    denver co usa
    here some photos using liquid container bag during recent camping trip. it works perfect. highly recommended. remember you may request at this thread.
    JagLite likes this.
  19. worthydog
    Sep 15, 2007
    764
    Here is my LC bag, in the cordura container bag that Brady made me. Worked like a charm in Botswana. Molly strips on both sides, easy to strap securely. When done, I put the empty bladder in a 2.5gal ziplock bag. It folded in half and flat under my luggage, disappeared completely. For me this is the solution to occasional need for extra range 5B2D6B86-98B1-43B9-A523-71526E7BD664.jpeg
    JagLite, Gedrog and grace like this.
  20. Gedrog
    Oct 20, 2013
    3,957
    Lost in the Sahara
    The bags just make sense doesn't it
    JagLite likes this.
