For sale Loaded 2002 KLR-650 Price lowered
Discussion in 'Bikes' started by flyinlow, May 23, 2020.
  1. flyinlow
    flyinlow Adventurer
    Apr 28, 2010
    70
    West Virginia
    $1900. Bought this KLR last summer while looking for a Terra, then found a nicely farkled Terra last fall. Just don't have room for 3 motorcycles now and unable to talk my wife into letting me park one in the living room! Only issue is I don't know the mileage as the aftermarket instrument cluster resets the odometer every startup. I do know from the original builder thread it had 8900 miles in 2011 when he started the build.
    A partial build list: 2004 RMZ 250 KYB front forks and triple, converted using an Emig conversion stem, top clamp Pro Taper Accutrax with rubber mounted 1 1/8 bar mounts, Pro Taper Contour Windham/RM Mid handlebars, All Balls upper and lower bearings and seals, IMS 6.6 gallon Fuel tank, Trail Tech X2 headlight dual sport version, Front fender Polisport UFX Freeflow, 2006 KX 250F Front wheel hub laced to Excel Takasago rim with heavy duty Moose spokes,2006 KX 250F front master cylinder and caliper with Galfer stainless steel brake line, Wave Rotor with Galfer pads, Zeta XC handguards with integrated turn signals.
    IMS 6.6 gallon fuel tank, Mylers Supercool radiator, Ernie Bell modified clutch arm, Ernie Bell skid plate, Sargent seat, CVK40 pumper carb with pilot and needle jets from KLR stock carb 142.5 main and KLX needle in second slot, stock pilot jet, torsion spring DooHicky from EagleMike, FMF Q4 muffler, but I put the stock muffler back on as FMF is a little loud for my taste, Supersprox front sprocket with EagleMike countersprocket nut, Supersprox 43 T rear sprocket, DID Gold X-Ring chain, KLR 600 hollow rear axle, Russell stainless rear brake line, Happy Trails master cylinder mount, 2006 KLR rear wheel, Galfer rear brake disc, Cogent Moab shock, 2009 KLR rear fender, rear led turn signals. No horn is wired and no ignition switch, a lighted toggle switch mounted on frame below gas tank controls electrics.
    This KLR runs strong and rides great! Located in southern WV.
    El Lobo Loco, Dan Diego and ogklx400 like this.
  2. cls
    cls Long timer Supporter
    May 7, 2009
    2,060
    N GA
    PM.
  3. CliffElam
    CliffElam OldN00b
    Jan 24, 2020
    94
    Naples, FL
    Still available?
  4. flyinlow
    flyinlow Adventurer
    Apr 28, 2010
    70
    West Virginia
    Still available.
  5. norton(kel)
    norton(kel) He’s my President! Supporter
    Apr 13, 2010
    3,198
    Berthoud CO.
    Is this titled and street registered?
    Thanks.
  6. flyinlow
    flyinlow Adventurer
    Apr 28, 2010
    70
    West Virginia
    Yes, titled and licensed. It does not have a horn installed and the rear turn signals are really small. Minimalist street setup.
  7. ag_streak
    ag_streak Tiene Ruta Cuarenta? Super Supporter
    Aug 9, 2006
    7,283
    Blue Ridge, GA
    What is the mileage listed on the title? (at the last transfer of ownership)
    Does the title say "not actual mileage" or "exceeds mechanical limit" or something like that?
  8. iyaoyas98
    iyaoyas98 Long timer
    Apr 11, 2006
    14,482
    Murfreesboro, TN
    From when he built it to when I dropped it off, less than 2k miles.
    This is the best KLR on the planet if you plan to go offroad.
    #8
    flyinlow likes this.
  9. flyinlow
    flyinlow Adventurer
    Apr 28, 2010
    70
    West Virginia
    The title states "odometer reading not required". If I remember correctly, WV doesn't require odometer reading once a vehicle reaches a certain age.
    #9
  10. flyinlow
    flyinlow Adventurer
    Apr 28, 2010
    70
    West Virginia
    Bump
    #10
  11. flyinlow
    flyinlow Adventurer
    Apr 28, 2010
    70
    West Virginia
    Price lowered to $2000.
    #11
  12. flyinlow
    flyinlow Adventurer
    Apr 28, 2010
    70
    West Virginia
    New price $1900.
    #12
