Locus
Discussion in 'GPS 101 - Which GPS For Me' started by levain, Jun 26, 2014.
  1. 2whlin
    2whlin Been here awhile
    Jul 16, 2014
    389
    not been on Locus in a while. where did Google maps go?
  2. ohgood
    Sep 21, 2010
    9,620
    alabama
    install locus map tweak
  3. lkraus
    lkraus Long timer
    Dec 15, 2012
    1,186
    Central Ohio
    and before you look, Locus Map Tweak is no longer available from Google Play. A search will find several other sources for the "side load" APK. I think I used this one: https://locus-map-tweak.en.aptoide.com/.
    ohgood likes this.
  4. 2whlin
    Jul 16, 2014
    389
    hmm..so would my map tweak have expired or something? Because it was there before..
  5. 2whlin
    Jul 16, 2014
    389
    did that map tweak some time ago, been years, on this device
  6. cyberdos
    cyberdos Easy Bonus Loop ♦♦
    Sep 2, 2005
    46,956
    Queen Creek, AZ
    I'm not sure if it was automatically removed in a previous update or not but I remember having to reload it.
    No worries. It's very simple and you shouldn't be bothered for a while after.
  7. ThomasD
    ThomasD Been here awhile
    Jul 9, 2004
    130
    Bonn, Germany
    When talking about additional online map sources for locus - there is a project called AnyGIS. Indeed a lot of eurasian and russian stuff, but also global and sat maps.
    ohgood likes this.
  8. krzydmnd
    krzydmnd Been here awhile
    May 15, 2018
    608
    US
    Locus won't stay open on android and I went through all of the software settings looking for a slider but can't figure it out. Any help? The app doesn't keep the screen on like all of my other GPS apps do.
  9. flamingm0e
    flamingm0e Been here awhile
    Feb 21, 2017
    662
    Oklahoma
    Settings, controlling, display
    Also, you might want to set it to run as a service.
    Settings, miscellaneous, run locus map as a service
    Sonny S., krzydmnd and ohgood like this.
  10. ohgood
    Sep 21, 2010
    9,620
    alabama
    check locus settings....
    settings >>> controlling >>> display >>> always on
    if the Android lock screen interferes...
    check android settings.:
    settings >>> security >>> device administrators >>> tick locus box
    the Android security settings change with each major Android version, this is how mine is accessed in 6.0
    Sonny S. and krzydmnd like this.
  11. krzydmnd
    May 15, 2018
    608
    US
    Thanks to both! I missed the display setting for always on. I did enable as a service to be safe too.
    ohgood likes this.
  12. Didediedide
    Didediedide Adventurer
    Jul 7, 2016
    49
    Gday all, to save me reading all 186 pages of this thread, can locus be set to show direction of travel ie travel to top of map and a rt turn looks like a right turn etc
  13. Didediedide
    Jul 7, 2016
    49
    Can añy one decephier the "Chinese ' instructions
    Thanks Paul
  14. lkraus
    lkraus Long timer
    Dec 15, 2012
    1,186
    Central Ohio
    Bottom of screen, second icon. Toggles between direction of travel and North up.
  15. Sonny S.
    Sonny S. Long timer
    Nov 23, 2015
    1,707
    Maryland
    I keep map rotation on. I can't stand how when I come to a stop the map starts spinning around at times.
    Is there a fix for that other than turn it off, then back on when moving?
  16. AdvNener
    AdvNener Long timer
    May 29, 2013
    1,092
    Marseille, France
    I prefer to always have the north on top, but there are settings to choose between compass and gps for direction of travel low speed/high speed. That's in "gps and sensor" parameters.
  17. Sonny S.
    Sonny S. Long timer
    Nov 23, 2015
    1,707
    Maryland
    I'm guessing this is what you mean. I don't remember the default setting but maybe I'll try it on auto. I thought I had it on auto a while back and didn't like it. Memory.... :-(.
  18. Cyclepath
    Cyclepath Lost wanderer
    Mar 17, 2006
    2,081
    SW. Wa. state
    Yes, don't look at the map. :-) ;-) opps, :hide
    Sonny S. likes this.
  19. AdvNener
    AdvNener Long timer
    May 29, 2013
    1,092
    Marseille, France
    yes that's the one i had in mind! Depends if your device has a magnetic compass of course..
  20. bcliff
    bcliff Been here awhile
    May 19, 2011
    708
    Northern Mass and NH Lakes Region
    I've been reading through all the pages of this thread and playing around with the Pro version of the app but am struggling with creating routes. How do you all build a custom route? From within the app or some other piece of software that you import into Locus?
