Locus
Discussion in 'GPS 101 - Which GPS For Me' started by levain, Jun 26, 2014.
  1. jojojones
    jojojones Long timer
    Jul 21, 2016
    1,339
    Northeast
    I appreciate it if you do fix it but I'd really like to know how because I tried to remove the Gap numerous times and it did nothing. Somehow I think it's corrupted.
  2. nibby
    nibby Been here awhile
    Feb 22, 2009
    498
    U.K. - Liverpool
    Had some good experiences yesterday having finally decided to give Locus Pro a try on the phone - very powerful - Couple of questions, haven't searched yet so sorry and probably already covered.....is there anyway to remove the "X" from the mapping screen? when I touch it says it's a "note"?? I didn't put any notes on the map so not sure why there are there??
    second. I will probably have to purchase some extra mapping - Am I right in thinking that I need to but some "locoins"? to purchase extra maps?? Strange as the free mapping they allow you is now saying there is an update but I've got no locoins left so I need to purchase these so I can upgrade the mapping??
    Cheers
  3. webmonstro
    webmonstro A Aventura Continua....
    Jul 21, 2008
    1,146
    Portugal
    Is this the gap your referring to ?
    You seam to have alot of bears in your area . Screenshot_2019-08-25-09-55-20.jpg
    ohgood likes this.
  4. webmonstro
    Jul 21, 2008
    1,146
    Portugal
    Sorry that's in OsmAnd
    In locus you can touch the endpoint of the track then touch the little pencil thing and create (free hand the track until the other end )
    But that's a lot of work for bigger thing
    You could also just make a new route between the two points let locus calculate the track with BRouter then join it with the main track .
    I bet ohgood knows of a better way
  5. ohgood
    Sep 21, 2010
    9,963
    alabama
    this is weird, loss like the track was butchered at some point ?
    this one is fine
    but the end points... are just gone ?
  6. flamingm0e
    flamingm0e Long timer
    Feb 21, 2017
    1,349
    Oklahoma
    No idea on the "X". It sound like you are using a theme and have "notes" turned on?
    On the maps, yes, to update you LoMaps you have to purchase more LoCoins which is stupid.
    I just use https://openandromaps.org and use the locus button on the maps I want to download the maps.
    Cyclepath and nibby like this.
  7. jojojones
    Jul 21, 2016
    1,339
    Northeast
    the track was very butchered yes. There were at least 2 merge operations involved. I took a clean track then overlayed it on tracks I have run then tried to cut out and add so I was not going to ride the same parts...so in all this butchering the red dot end point is now in the middle and there are 2 gaps that no matter what I try will not get fixed. This is not mission critical in any way but a learning experience because the route planner is my weak point. I do not find it intuitive and I'm sure that's just me.
  8. jojojones
    Jul 21, 2016
    1,339
    Northeast
    turn off open street map notes
    nibby likes this.
  9. jojojones
    Jul 21, 2016
    1,339
    Northeast
    no that is the correct end point which is near the start. I just want to learn why the red dot end point is not there and how to fix that.
  10. nibby
    Feb 22, 2009
    498
    U.K. - Liverpool
    Thanks for info re mapping, just downloading now - also re @jojojones post below re notes in openstreet map - that's sorted it - Thanks @jojojones
    Really good app - loving that I don't have to use various maps, seems to do everything I need all in the one app.
  11. arghhh
    arghhh Adventurer
    Jun 14, 2015
    57
    UK
    Do you guys use Locus to track record or a different app? I'm mainly thinking in terms of battery usage.
  12. flamingm0e
    Feb 21, 2017
    1,349
    Oklahoma
    I use Locus to record and view. Basically everything
    arghhh likes this.
  13. AdvNener
    AdvNener Long timer
    May 29, 2013
    1,620
    Marseille, France
    Yeah nothing special about recording with locus. It works. With screen off and no navigation i'd say about 2% battery life per hour for me.
    arghhh likes this.
  14. ohgood
    Sep 21, 2010
    9,963
    alabama
    i record with locus. it's battery usage while recording is about 1% every two hours, maybe.
    settings to take note of:
    location settings "GPS only"or "device only" .... never use "high accuracy", as it will drain the battery faster and attempt to use Google services (cellular/wifi/Bluetooth) to locate via triangulation. triangulation is a very poor location estimate, you want to use trilateration, which is excellent.
    battery saving (Android settings) - don't use it. it will interfere with GPS usage on newer devices
    locus widget - you can start and stop recording with the locus widget and never need to open the full locus application.
    track recording settings (inside locus) can be manually set to very fine or very coarse, neither of which effects battery life at all.
    airplane mode: acts differently on Att vs Verizon units. airplane mode will disable the GPS antenna on att, but not on Verizon. for att models, use "radio switcher" to turn off the cellular radio. then you can still use the GPS antenna with the wasted energy going to the cellular antenna
    arghhh likes this.
  15. SRTie4k
    SRTie4k Northeast Explorer
    May 11, 2009
    2,678
    Nude Hampster
    Can you give me an example?
    Restricted roads are already marked with red X's, while other "trails" (like abandoned railroad tracks, bicycle trails, walking trails) currently appear differently.
  16. Cyclepath
    Cyclepath Lost wanderer
    Mar 17, 2006
    2,210
    SW. Wa. state
    Hi ohgood. I am using a Kyocera e6820. It is unlocked but it is a at&t branded phone and I did not know this when I bought it. You are right about it not allowing me to use air plane mode without losing the gps signal and also I can not use the hot spot unless I sign up with at&t. So I am using pdanet to by pass the at&t bullcrap. I was wondering if there is a different model Kyocera that isn't at&t or verizon branded. Non of the info on amazon says anything about that except that it is unlocked.
    Also my version of Locus pro is 3.34.1 and I can not find the gps settings for gps or device only. I thought they were there but now can't find them anymore. now all I have is "hardware compass" , "orientation via gps" or Auto change. I have it set for orientation via gps.
    What am I missing ?
    Thanks ohgood :-)
  17. flamingm0e
    Feb 21, 2017
    1,349
    Oklahoma
    Sprint, T-Mobile (I think), AT&T, and Verizon
    The options for GPS/device only is in the device settings. It has nothing to do with Locus
  18. Cyclepath
    Mar 17, 2006
    2,210
    SW. Wa. state
    Thanks for the info. I had a brain fart as to where the gps settings are. :-)
    What I was asking about the cell phone was is there any models that are not branded to any of the big 4, unlocked and not branded.
    I have an old Asus zen fone 2 lazer that is beginning fail and it is not branded to anybody. It's just a gsm phone. I am using Cricket and have been for many years.
  19. bradrh
    bradrh Been here awhile
    Sep 4, 2011
    722
    poncha springs, co
    N38.459419° W105.984737°
    At that position, the rainbow trail (motorized), intersects with columbine trail (non-motorized). These are both tagged (in OSM) as highway=path, the motorcycle trail adds the tag motorcycle=yes
  20. ohgood
    Sep 21, 2010
    9,963
    alabama
    Android location settings is where "GPS only" resides.
    i only know about the att Verizon models
