Locus
Discussion in 'GPS 101 - Which GPS For Me' started by levain, Jun 26, 2014.
  1. flamingm0e
    flamingm0e Long timer Supporter
    Feb 21, 2017
    2,823
    Oklahoma
    I can only attach one pic at time to my posts and mods refuse to fix it....
  2. kubcat
    kubcat Riding is Eudaemonic Supporter
    Sep 22, 2016
    2,363
    Upstate NY
    Has anyone else experienced a failure in Locus to download and unzip either the openandromap or the theme zip files when clicking the Locus button through the web browser?
  3. AdvNener
    AdvNener Long timer
    May 29, 2013
    3,052
    Marseille, France
    I've had issues with one phone.. download seemed to work but locus had trouble unzipping correctly. Probably android permissions related. Never digged into it and simply downloaded from computer then copied files where they had to go.
    It works as intented on my new phone now.
  4. ohgood
    Sep 21, 2010
    10,235
    alabama
    provide a link to the maps you're having issue with and I'll test it.
  5. kubcat
    Sep 22, 2016
    2,363
    Upstate NY
  6. kubcat
    Sep 22, 2016
    2,363
    Upstate NY
    so the Elevate.zip file for manual installation from the openandromaps.org website only has one subfolder (ele_res), the readme file, Elements.xml and Elevate.xml in it. Where did all of the other files you show come from?
  7. kubcat
    Sep 22, 2016
    2,363
    Upstate NY
    Here is the error message I get when initiating a download from a 3rd party site - openadromaps.org. I checked the default file locations as configured in settings, and the zip files did download to the correct folders. When looking at the zip files with android's file manager, the contents seem to be intact. Manually unzipping them into the correct locations worked for the map, but not for the style. I'm stumped...
    Edit: I didn't have the error message ID captured in the screenshot. Here it is...
  8. flamingm0e
    Feb 21, 2017
    2,823
    Oklahoma
    Do you use the standard internal SDCard location for locus or are you trying to force it to use external SDCard? It won't really work with external SDCards. Permissions issues.
  9. SRTie4k
    SRTie4k Northeast Explorer
    May 11, 2009
    3,435
    Nude Hampster
    As flamingm0e says, if you are using an external SD card for Locus storage, you cannot use the Locus downloader because Locus does not have permission to write to the SD card in any location but the app folder (which is not really relevant to this discussion).
    If you are using an external SD card, you will have to manually download the theme. After downloading, create a folder on your desktop called "Elevate", then extract everything from the zip file into that Elevate folder. Then connect your phone to your PC and navigate to the _themes directory on your external SD card. Then copy that Elevate folder to the _themes directory. I think the key piece of missing information here is that you did not place the files in the Elevate folder in your _themes folder.
    The one catch to the above is that, for some reason, the manual download does not include icons for the themes. That said, they will still work in Locus, they will just have generic theme icons.
    If you are using onboard storage for Locus files, the theme downloader at openandromaps will indeed do everything for you.
  10. kubcat
    Sep 22, 2016
    2,363
    Upstate NY
    I'm using external SD storage. I assumed the failures were permissions related, so I was using the manual method using the android file management tools. I finally switched to a desktop approach, deleted the existing maps, installed the rendering engine/themes, followed the folder structure on the OAM webpage FAQ, rather than the screenshots you posted (put everything under the Elements folder under _themes), then reinstalled the map files after the theme files were there. Now everything is showing as it should. I'm not 100% on what actually did the trick, but at least the folder structure is logical and everything seems to be working. Thanks for following along...
    AdvNener likes this.
  11. RoundOz
    RoundOz Plenty of seasoning
    Jun 10, 2009
    2,400
    West Nebraska
    Are there any restrictions on what can be placed in Map Items to use as an overlay? I am trying to overlay a map of Native American reservations, for which I can only find fairly low resolution images online, either by pulling them into Map Items through Locus, (no result) or copying and pasting the jpgs into Map Items (file appears after Locus refresh, but is grayed-out and cannot be selected - i have a couple of map points in there, gpx or kml i think, which are not grayed out and can be selected).
    I'm assuming that not all jpgs are created equal, but i have tried taking screenshots of other online files, and these don't appear to work either.
  12. gefr
    gefr Life is a trip
    Nov 26, 2005
    5,086
    East Med, Greece
    An old question arises again. I still have problems navigating long distances. For a 2000kms trip the calculation runs forever and finally shows a message: memory limit reached. It seems there is an amount of memory dedicated to calculating that needs expansion? My phone has internal memory 256GB so it doesn't make sense. All installation has been done automatically.
  13. AdvNener
    AdvNener Long timer
    May 29, 2013
    3,052
    Marseille, France
    The memory mentionned is very likely to be the RAM, not the storage space. So 2/3/4/6 Gb etc.
    Which routing engine are you using?
    Just tested a Zurich to Porto with brouter offline on my 4Gb RAM phone, it computed for more than 5 minutes. I didn't see if it showed a message but did not finish the calculation anyway, so probably same error.
    Then i just tried again and he managed to calculate a 1900km route.
    Anyway, brouter doesn't look like it is the right tool for such long route calculation. I must admit I would never do that myself. I sometimes to such long "all trip in one track) planning", but then I use the route planner in locus as I have waypoints to enter (places to see, to sleep etc etc), and so it breaks the whole thing in small parts for brouter to calculate.
    Do you really use it like "I have to go 2000km away, i don't care where we go on the way, just calculate a path to there?"
    Sonny S. likes this.
  14. gefr
    gefr Life is a trip
    Nov 26, 2005
    5,086
    East Med, Greece
    Exactly. I leave it up to BRouter to do all the decisions. If I want to put intermediate waypoints, that would be 1 or 2. Do you think this would solve the problem?
  15. SRTie4k
    May 11, 2009
    3,435
    Nude Hampster
    Is there a reason you don't want to use Google Maps?
    Locus routing is pretty good, but if all you want is to get from point A to point B, Google Maps is a WAY better tool.
    EmmEff likes this.
  16. AdvNener
    AdvNener Long timer
    May 29, 2013
    3,052
    Marseille, France
    It certainly would help to split the distance.
  17. ohgood
    Sep 21, 2010
    10,235
    alabama
    you can use any size jpg image you like to create the kmz, which locus will then display on the map. locus does not display jpg images in the map by themselves, they have to be georeferenced first.
    did you see the "image map calibration"tool yet in locus ?
    use that to make any JPEG you want, into an overlay, and it will live in map_items after you're done.
    RoundOz and Emgo like this.
  18. RoundOz
    Jun 10, 2009
    2,400
    West Nebraska
    Aah...my mistake for thinking the image had to be brought in and overlayed prior to being calibrated. That seems almost too easy. Thank you.
    ohgood likes this.
  19. gefr
    gefr Life is a trip
    Nov 26, 2005
    5,086
    East Med, Greece
    The reason I use brouter for very long distances is I like the offline navigation. Truth is, for street nav, I prefer the Here maps. More user friendly.
    Cheers
    AugustFalcon likes this.
  20. jojojones
    jojojones Long timer Supporter
    Jul 21, 2016
    1,778
    NewYorkistan
    Have you folks checked out caltopo recently? They have updated the mobile app. The data served up leaves locus in the dust IMHO. The mvum layer is impressive.
