1. Livestream NOW at 9pm EST / 6M PST! Any Questions for Marc?
    Baldy + Alta CEO & Co-Founder Marc Fenigstein YouTube Live Chat here
    Dismiss Notice
Long term KLX250S review
Discussion in 'Thumpers' started by bmwhd, Dec 2, 2005.
  1. Lutz
    Lutz Fuzzy Rabbit
    Jul 17, 2010
    3,196
    North Shore of Lake Superior
    Isn’t the issue related to both sides being wired to a common flashing indicator light? I think the fix is something along the lines of eliminate the indicator, or add a resistor or diodes to it. I’m sure this has been hashed out here over and over, but my KLX is long gone, and I never converted to LEDs.
    kbuckey likes this.
  2. NurseBill
    NurseBill Been here awhile
    Aug 20, 2017
    852
    Central PA
    You can get the resistors at Walmart if need be, automotive section. I think it's because the KLX has 1 indicator light on the dash, not 2 for each side. That's the only way mine would work.
  3. NurseBill
    Aug 20, 2017
    852
    Central PA
    Kenda Trackmaster 110/100-18
  4. RuffnReadyXJ
    RuffnReadyXJ Just thumping along...
    Aug 25, 2010
    232
    Central Coast Hwy 1
    Anyone have the round factory mirrors from a 09 and newer? Either both or at least a right one they don’t need? I can get a new OEM one for 51 bucks but figured if someone upgraded or don’t use theirs I’ll throw a few bucks their way. If not I’ll just order one.
    If you can try to PM me and/or quote this post so I don’t miss any replies. Thanks!
  5. markk53
    markk53 jack of all trades...
    Dec 20, 2007
    18,739
    Delaware Ohio
    Why not buy a couple Emgo folding dual sport mirrors. Work pretty well. Under $15 a shot.
    You set them up so they can fold to the middle above the key switch when off road.
    bultacobill and RuffnReadyXJ like this.
  6. RuffnReadyXJ
    Aug 25, 2010
    232
    Central Coast Hwy 1
    The image doesn’t work but I’ll google it. They any good as far as keeping adjustment or not vibrating like crazy? I actually had some double take mirrors I spent good money on, then sold a while ago, I didn’t like them at night because they vibrated terribly. I need a mirror after I wiped my bike out on the road, lol.
  7. markk53
    Dec 20, 2007
    18,739
    Delaware Ohio
    I don't think it was horrible for vibration. The mirror ball mount can be tightened up some, essentially it is a standard round mirror with a ball mount base.
    bultacobill likes this.
  8. 1994klr250
    1994klr250 Long timer
    Aug 16, 2007
    1,255
    Southeast michigan
    Finally tested the fuel range of the klx 351 today with the Acerbis 3.7 gallon tank. I got 165 miles plus another 21 miles on reserve. It ran out of gas at 186 miles and I leaned it over to the left side to get a little bit of fuel out of the right side of the tank. I made it to the gas station and put in 3.65 gallons which is right around 51 mpg with a 15 tooth front sprocket.
    The fall colors are a bit late here in southern Michigan. I'll probably head back out next week again to see if the leaves have more color.
    IDRIDR, LandsVW and Jmcqq37 like this.
  9. UtahGuido
    UtahGuido Long timer Supporter
    Nov 29, 2007
    11,010
    Spine 'O the Wasatch
    Nice, and the mileage sounds about right.
    I took my 351 out yesterday and after not having ridden it for a while, and having spent most of the intervening time tooling around on a Beta 125, I was surprised at the amount of vibration that motor has. And noise - it has pretty "throaty" exhaust and it's...throaty. Put in 86 miles of mixed tarmac and dirt and except for my sore ass at the end by virtue of my wretched homemade seat I enjoyed the ride. That motor - that torque! Very intoxicating. Not super fast but it really pulls in a satisfying way at anything over 4K rpm. I actually came up the same road as in the attached video and I think I went up at least as fast as this guy (though I'm not saying the 351 is in the league with this motor) and really didn't shift that much, except on the hairpins, just let the torque pull me through. And the bawl of that exhaust as the motor yanked me out of the turns! Aaargh! I felt a little bit of the hooligan.
    norton73 likes this.
  10. barko1
    barko1 barko1 Supporter
    Nov 24, 2004
    5,079
    PJ Forest
    My 06 electric start button snapped off, I was in the woods parked at the bottom of a hill :lol3, but it started as it snapped. Got a replacement off Ebay but it wasn't plug and play, different connectors but the color codes were the same. Fixing that I noticed the fuel line was crapped out,$2 at Autozone and all is well again.
  11. markk53
    Dec 20, 2007
    18,739
    Delaware Ohio
    FWIW I bought a box of male/female connectors 3.9mm which are same as some of the Japanese bikes. Under ten bucks for a bazillion of them. click here.
    Used them to fix the corroded, broken connectors on an XT225.
  12. barko1
    Nov 24, 2004
    5,079
    PJ Forest
  13. markk53
    Dec 20, 2007
    18,739
    Delaware Ohio
    As cheap as both kits are, it's not a bad thing to have on the shelf. Auto stores don't have the bullet connectors most of the time, having only those flat blade type. Plus you always need them the day before you are going somewhere. Less than $20 to be ready. Plus throw some in a baggie and you have them on the road if needed.
  14. mriderleon
    mriderleon Been here awhile
    Nov 17, 2005
    332
    Masaryktown, Florida
    Bike and I went down hard on the left side. Now it shifts up, at least it did until it got to 6th gear. Both up and down now feel the same, the shifter moves but doesn't catch anything and the spring returns it to center.
    I suspect it has a broken downshift finger. Has anyone else had this problem? How much work will it be to replace this?
  15. Smopho
    Smopho Been here awhile
    Aug 9, 2012
    293
    Central TX
    Service manual PDF files are online if you google them.
    mriderleon likes this.
  16. Lutz
    Lutz Fuzzy Rabbit
    Jul 17, 2010
    3,196
    Is it a 2009? If so, yes, fairly common and pretty easy to repair.
    https://www.kawasakiforums.com/forum/klx-250s-71/shift-star-design-change-35512/
  17. mriderleon
    Nov 17, 2005
    332
  18. jeepgeek2002
    jeepgeek2002 Long timer
    Jun 7, 2007
    3,806
    Jacksonville, FL
    anyone replaced their Exhaust Cam ? my ACR is failing.
  19. 250senuf
    250senuf Long timer
    Feb 17, 2008
    3,841
    Nelson area, Kootenai, BC, Canada
    I had to replace the cams on my '09. Still have the old ones, ACR wasn't part of the problem causing need to replace. Postage from Canuckistan tends to be pricey. PM me your zip code and I'll check the cost.
  20. jeepgeek2002
    Jun 7, 2007
    3,806
    Jacksonville, FL
    i ll just replace the whole unit.. im not even sure how the acr comes off the cam.. $244 for a new part.. looks like its the same part # even for the 18's
