Long term KLX250S review
Discussion in 'Thumpers' started by bmwhd, Dec 2, 2005.
  1. norton73
    norton73 drinkin' Supporter
    Dec 20, 2003
    12,541
    Beautiful Downtown Springville, Alabama
    I stick with 87 octane, but I use ethanol free gas. Even if I can't get ethanol free gas while out riding, I top it up with ethanol free gas before I park it.
    I also use the turn off the petcock method about a half mile before home and let it idle until it dies. Mine starts well.
    But it it a 351 with a rejetted stock carb.
  2. norton73
    Dec 20, 2003
    12,541
    I think I read you replaced the battery recently, but have you tried the battery out of the 18 yet? Quicker and easier than changing the starter as a first step.
    I guess having two similar bikes around should make troubleshooting easier.
    I am trying to convince my wife to step up from her xt225 to a klx to make parts stocking easier.
  3. jeepgeek2002
    jeepgeek2002 Long timer
    Jun 7, 2007
    3,704
    Jacksonville, FL
    i have an other battery i m going to swap in today.
    if that fails.. swap the starter motors.. if that doesnt work..
    im out of ideas
    i replaced the starter relay
    checked the cables
    checked all grounds
    checked relays
    Checked fuses
    How this started? a slow death.. It was running great.. then started taking long to crank and now its a slow crank.. its speeds up then slows to a crawl. then speeds up then slows down.. i hope its not the starter.. $411!!
  4. norton73
    Dec 20, 2003
    12,541
    Ouch!
  5. Lutz
    Lutz Fuzzy Rabbit
    Jul 17, 2010
    3,192
    North Shore of Lake Superior
    If it is the starter - and it very well could be - I’d try replacing brushes before purchasing a whole new starter.
  6. jeepgeek2002
    Jun 7, 2007
    3,704
    Jacksonville, FL
    i pulled the brushes out and checked them.. new are 12mm these are 11mm
    but we will find out when i swap the 2018 starter in the 09..
    norton73 likes this.
  7. norton73
    Dec 20, 2003
    12,541
    Time for a kick starter kit.
    :D
  8. jeepgeek2002
    Jun 7, 2007
    3,704
    Jacksonville, FL
  9. UtahGuido
    UtahGuido Long timer Supporter
    Nov 29, 2007
    10,612
    Spine 'O the Wasatch
    I don't know about that kick start option. I put one on mine and while it worked okay for a while, would start 8 time out of 10, now its rare that I can get it to fire off with the kicker. I give up and push the button. Right now my opinion of the thing is that it looks cool and adds weight.
    jeepgeek2002 likes this.
  10. markk53
    markk53 jack of all trades...
    Dec 20, 2007
    18,042
    Delaware Ohio
    Has to be the purity. Higher octane is harder to burn - the anti-knock characteristic, it takes more for it to burn. 87 should ignite easier. But it also may be a crappier blend. I run 87 in the 250, but use 89-93 in the 650.
  11. jeepgeek2002
    Jun 7, 2007
    3,704
    Jacksonville, FL
    i got to looking on babbits on what bike shares the same starter as the Klx250s.
    found 1.. the Super Sherpa.. Same "internals" but different position of the wires..
    In theory, (and if it is the starter issue) i ll swap the old core starter with that of a super Sherpa's starter.
    On Ebay they are like $50
    next week i ll pull the starters off. and see if thats the issue.
    LandsVW likes this.
  12. bultacobill
    bultacobill Been here awhile
    Feb 26, 2014
    940
    Dawson PA
  13. Big_John
    Big_John That'll be the day
    Aug 11, 2007
    4,060
    Black Forest, CO
    Just regular 'ole gas..... At elevation up here in Colorado our options are 85, 87 and 90-91. My son tells me he can get 95 in Texas at sea level. But...I have been running 85. I will fill up with 91 next time and see if that makes a difference.
    GhettoCanuck likes this.
  14. 250senuf
    250senuf Long timer
    Feb 17, 2008
    3,669
    Nelson area, Kootenai, BC, Canada
    Put 99999-0073 into Google. Some sites show the price. I did it a while ago but don't remember the price, under $500US I think. The price has gone up from when I first checked a few years ago. For Canadians it's well over $600 plus shipping. Yow, I'll pass. I do carry a jump pack and have the harness to the battery, so no panel removal req'd.
  15. MrCrisper
    MrCrisper LowHPchamp
    Oct 6, 2015
    468
    Davidson, NC
    I’m getting about three and a quarter when I log in.
  16. jeepgeek2002
    Jun 7, 2007
    3,704
    Jacksonville, FL
    i get $422 on most sites..
    same on Babbits.
    KIT.,KICK STARTER
    99999-0073
    Your Price: $422.22
  17. markk53
    Dec 20, 2007
    18,042
    Delaware Ohio
    I ride with friends. A beer will get a bump start any day! $400+ will buy a lot of bump starts! :freaky
  18. bultacobill
    Feb 26, 2014
    940
    Dawson PA
    Thanks for the info. That’s kinda steep.
  19. Frogger
    Frogger Adventurer
    Dec 5, 2001
    88
    Idaho
    Not sure if this is the correct thread to ask, but...
    I have an '06 KLX250. Will the 09-14 IMS 3gal tank mount onto my vintage bike cleanly and without modification? If not, does anyone have knowledge of exactly what's required to make it work?
  20. sjc56
    sjc56 Long timer
    Oct 26, 2006
    2,067
    Broad Brook CT USA
    What year KLX300 muffler and header will fit on an 09? Would one off a 2001 work?
