Long term KLX250S review
Discussion in 'Thumpers' started by bmwhd, Dec 2, 2005.
  1. AloneInTheHills
    AloneInTheHills Been here awhile
    Apr 23, 2019
    574
    Nevada, USA
    They probably felt that the slide would move too quickly and create a temporary bad air/fuel mix, based on the stock carb setup.
  2. mr. coffee
    mr. coffee wingnut
    Jun 17, 2010
    133
    big sandy mush, western n.c.
    6D3A4D1F-8D41-4F68-9097-5E09E8D57CB3.jpeg Finally got all the parts in the mail and I’m really happy with the setup! The new jets have made a nice improvement! No more popping on deceleration and runs better right off choke. I went with D pippins jet suggestions (Kawasaki parts) and stayed on the lean side (3000’ elevation and 250cc). I didn’t drill the starter jet or adjust the mixture screws and it seems to be running just fine. I did do the airbox mods, although I’m not sure removing the backfire screen does much. Currently running with out snorkel and so far so good... I’ll try to stay out of deep water. Removed smog stuff and it’s worth it just to have easier access to the choke.
    Installed a 13 tooth front sprocket... definitely better gearing. Will probably add a tooth to the rear when it’s time to replace.
    I’m really liking the Kenda K760 tires front and back! Tusk bark busters were inexpensive and fit well, and the Ricochet skid plate is gonna do the trick. For now it’s all set up and ready to ride... I’m starting to really like this motorcycle!!
    CPAT, Cav47, Jedi2Rider and 4 others like this.
  3. ColumboNH
    ColumboNH Been here awhile
    Apr 14, 2017
    178
    New Hampshire
    dmottv and Cav47 like this.
  4. Jblok
    Jblok Been here awhile
    Mar 20, 2018
    156
    Netherlands
    does any one know the part number for a float bowl.
    I accidentally broke the brass standpipe in the float bowl.
    Pretty fucked.
  5. SaugeenADV
    SaugeenADV Adventurer
    Jun 13, 2018
    28
    Southampton, ON Canada
  6. Jblok
    Mar 20, 2018
    156
    Netherlands
    I know but none of them say float bowl
  7. SaugeenADV
    Jun 13, 2018
    28
    yup, you are right. weird.
  8. Jblok
    Mar 20, 2018
    156
    Netherlands
    More like fucked
  9. AloneInTheHills
    Apr 23, 2019
    574
    Nevada, USA
  10. Jblok
    Mar 20, 2018
    156
    Netherlands
    Oké I fixed it.
    Had an old carburettor, pulled the tube, drilled the float bowl and pressed the tube in with some liquid metal/loctide
  11. markk53
    markk53 jack of all trades...
    Dec 20, 2007
    18,747
    Delaware Ohio
    Atta boy, when in doubt improvise!
    Jedi2Rider and Jblok like this.
  12. Rusty Rocket
    Rusty Rocket Life behind "Bars"
    Dec 22, 2005
    16,318
    Tri- Cities TN
    Carbparts Warehouse and Sudco have all kind of parts that often aren't available from the vehicle manufacturer
    interactive3, Jedi2Rider and Jblok like this.
  13. bultacobill
    bultacobill Long timer
    Feb 26, 2014
    1,003
    Dawson PA
    If you call bike bandits they will hook you up too.
    Rusty Rocket likes this.
  14. BergDonk
    BergDonk Old Enough to Know Better
    Nov 15, 2010
    13,089
    Snowy Mountains Oz
    I've fitted an overflow tube to an FCR carb that didn't have one. Some brass tube from a hobby shop and some epoxy like JB Weld and sorted.
    Jedi2Rider likes this.
  15. markk53
    Dec 20, 2007
    18,747
    Delaware Ohio
    Boy does'at look purty!
  16. SaugeenADV
    Jun 13, 2018
    28
    has anyone tried the new Wolfman enduro tank bag? Just wondering what the go to tank bag is on the KLX? I am looking for something water proof and small enough that its not in the way.
    norton73 likes this.
  17. Eastbayview
    Eastbayview Ride On
    Apr 15, 2010
    1,190
    Clearwater Bay, ON (Paradise!)
    I've got the Enduro tank bag on my KLX. It is a good size for the bike and for the IMS tank. I do a lot of standing and it does not get in the way.
    CPAT, SaugeenADV and norton73 like this.
  18. AloneInTheHills
    Apr 23, 2019
    574
    Nevada, USA
    Two questions on my 2013 klx250s.
    1. I'm getting a bit of resonant vibration from 5300-5800 rpm whether the bike is moving or not. I think it might be something random (lots of aftermarket addons) and haven't found anything loose, but on these bikes if the cam chain is loose would it do this just in this rev range? On my Triumph they will rattle more when the engine is cold if the tensioner is failing.
    2. I'll be doing a valve check shortly. I'll probably order the overpriced cam cover gasket anyway, but was wondering if they tend to be reusable despite being listed as a replacement part. I've seen videos out there and seems like guys are reusing them.
  19. SaugeenADV
    Jun 13, 2018
    28
    I have always reused my gasket
    bultacobill and AloneInTheHills like this.
  20. 250senuf
    250senuf Long timer
    Feb 17, 2008
    3,841
    Nelson area, Kootenai, BC, Canada
    The (some?) '09s had an issue with cam cover gasket shrinking when removed, the replacement is re-useable.
