Looking for some advice involving Krauser 4 valve heads
Discussion in 'Airheads' started by Myduffy, Nov 16, 2019.
  1. ccmickelson
    ccmickelson MonoMania Supporter
    Dec 11, 2013
    2,499
    Fanta Se
    Wow, what a find. If you can't find any takers here there's a fairly active NM Airheads group and a number of members in Silver City. You might hit them up.
    #21
  2. Myduffy
    Myduffy n00b
    Nov 16, 2019
    7
    Silver City NM
    That sounds interesting, any chance you have a link to that?
    #22
  3. bmwrench
    bmwrench Long timer
    Nov 10, 2006
    7,741
    Two Krauser-headed bikes were entered at a race at Daytona "back in the day". They were impressively fast, but neither finished the race. The team claimed both bikes suffered gearbox failures, but...
    #23
    spo123 likes this.
  4. El Matador
    El Matador Adventurer
    Jul 30, 2003
    44
    Tucson, AZ
    Please check your inbox.
    #24
  5. scottyb
    scottyb Been here awhile
    Nov 30, 2004
    310
    Texas
    Built back in the day. Have a spare set of heads with cylinders. anyone interested?
    #25
    getonyourbikeandride likes this.
  6. Arktasian
    Arktasian Lets call it Naturalized
    May 23, 2014
    1,542
    Canada
    How does John communicate - on line or at the track? I've only encountered a couple of projects/ individuals that were open to discussing their craft with another squirter.
    #26
  7. Kiwiabbo
    Kiwiabbo Been here awhile
    Apr 16, 2014
    893
    Taihape New Zealand
    Check with David Hunn in one of the above comments. That’s the bike there but there was also a turbo, injected 90s aswell.
    #27
  8. tennessee thumper
    tennessee thumper Long timer Supporter
    Nov 3, 2007
    2,052
    Arkansas Ozarks
    I'd be looking for a buyer on these, sell em off and fund other parts of your build.
    Neat find, nonetheless.
    #28
  9. wallaman
    wallaman Been here awhile
    Aug 10, 2013
    116
    The Krauser heads are a great addition to an airhead! The only real downside is the addition of some weight to the valve train due to the addition of an "extra lifter" that fits in the head itself. (Stock lifter - new Krauser pushrod - new Krauser "lifter" - new Krauser rocker arm). That heavier valve train tends to be hard on stock cam and lifter contact surfaces, particularly at higher RPM. I don't recall who, but someone made a nice cam for this setup that had ramps that helped minimize this aggravation. Also, the Krauser lifters that ride in the heads had press fit "buttons" in the ends of the "lifter tube". These tend to leak and the lifters fill up with oil making them extra heavy. When (not if) this happens, the cam/stock lifter wear gets really bad eventually with catastrophic results. (I've never found a used set of these lifters that didn't have at least a little oil inside of them.) Easy fix is to silver solder the "buttons" into the tubes so they don't leak. That gives you a reliable top end that breathes well - a major improvement to stock based on the seat of my pants :) The Krauser pistons use Porsche rings that are readily available and can be had for chrome or cast iron barrels. And yes, the heads (even if not complete with all the other bits) are worth a LOT of money!
    #29
  10. gsd4me
    gsd4me 90% bluff Supporter
    Dec 11, 2005
    9,580
    Brisbane, Australia
    That would be Ray Peake, not John.
    #30
    Kiwiabbo likes this.
  11. Kiwiabbo
    Apr 16, 2014
    893
    Taihape New Zealand
    Roger.... I knew it was one of those clever buggers
    #31
