Lost Cause
Discussion in 'Airheads' started by Pokie, Feb 27, 2021.
  1. Pokie
    Pokie Just plain Pokie.
    Apr 4, 2013
    8,338
    Fort Collins, CO
    Yesterday I did the unthinkable,... I sold the forks! A fellow dropped by yesterday and fell in love with the forks, and we made a deal (giving me enough money to maybe finish the build) . Now I have to pull the forks and fit another set. It's ok as I have a few sets of rebuilt BMW forks on hand. Maybe I'll just build it into a "bobber". I'll have to stand back and look at it for a while to see if I can imagine it as something else. Not to worry though, it will still become a running bike, just not what it was intended to be.
  2. Arktasian
    Arktasian Feelin the BMEP
    May 23, 2014
    2,278
    BC
    Your faithful audience will be all "chopped up" by this development.
    Suppose you're getting a hair cut too?
  3. Jim K in PA
    Jim K in PA Long timer Supporter
    Mar 15, 2011
    5,747
    Pocono Mountains, PA
    Meh - it's an "evolving" build in every sense. The final result will still be cool.
    Time to rename this thread "Good Cause". ;)
  4. Pokie
    Apr 4, 2013
    8,338
    Fort Collins, CO
    "Suppose you're getting a hair cut too?"
    I cut my own hair, thankyou! Right now it's about 1/4 inch long,... not quite enough to braid or go dreadlocks.
  5. Arktasian
    May 23, 2014
    2,278
    BC
    That's fine, I try not to judge people. Letting my hair get long, could it be a mid life crisis? I don't think so, just doing it in part as its fun, and it bugs people at work that are going bald.
    I should probably start a Chopper build. I could title it something like "Without a Cause".
    MonzaCross and Texer like this.
  6. Texer
    Texer Been here awhile Supporter
    Jun 5, 2015
    922
    Seattle
    I don’t ever see going that direction, but I have respect for the basic chopper when a personal build (such as the Oakland type) is on the road.
  7. headtube
    headtube Been here awhile
    Sep 30, 2012
    864
    Toronto
    A set of vintage British bike girder forks would suit that build. If you could get your hands on them.
  8. Pokie
    Apr 4, 2013
    8,338
    Fort Collins, CO
    Yeah, I like girder forks but don't have any and they are kind of expensive when I do find them. I thought about making a set but the whole idea is trying to build something out of what I already have on hand. Yes, I am buying stuff for the build but mostly small stuff, nothing big,... yet.
    I think it's too bad that the previous owner cut so many "useful" things off the frame before I got it, I've been spending a lot of time re-creating those cut-off items. Down the road, if someone (after me) wants to restore the bike to it's original glory, hopefully I have gotten them closer. It just won't be me.
    Disston likes this.
  9. infinityedge
    infinityedge Long timer
    Jun 27, 2013
    19,369
    Tuolumne County
    They have some repos out of India for under $600 that could make a fun base, or at least inspiration to build your own.
    https://www.ebay.com/itm/2742502773...%2Fo0VSGTNuMow%3D%3D|ampid:PL_CLK|clp:2047675
  10. Pokie
    Apr 4, 2013
    8,338
    Fort Collins, CO
    Finally got around to fitting a set of standard forks,... doesn't look quite as interesting but will likely handle better.
    I guess this means I'm going to have to shorten the side stand.
    Uke, Ozarkroadrunner, Disston and 2 others like this.
  11. Pokie
    Apr 4, 2013
    8,338
    Fort Collins, CO
    Started working on the dashboard. Cutting the larger holes took a bit of fiddling but after reworking the cutter and clamping the board nice and tight, got it done.
    The start of the dash in place. Ignition and speedo temporarily mounted.
  12. Plaka
    Plaka Brevis illi vita est
    Jun 19, 2010
    9,173
    There are frankenstien bikes and then there are freakenstien bikes....
    Jim K in PA likes this.
  13. Jim K in PA
    Mar 15, 2011
    5,747
    Curious about the chimney on the tank . . . brisket smoker? :lol3
  14. Pokie
    Apr 4, 2013
    8,338
    Fort Collins, CO
    "Curious about the chimney on the tank"
    You have to remember that the tank was a throw away as it was damaged so badly. The top of the tank was all pushed in, so, I cut out the fuel cap inset to try to reshape the top of the tank. I have a sheet metal slug that I will reshape to suit the top of the tank. I didn't want to put the gas cap in the usual place, so I fabricated a filler and stuck it on the side of the tank,... that's your chimney. Yes, it would have been better to put it on the other side but that side was so trashed that I cut it all off and will be mounting the dash board in it's place.
  15. Disston
    Disston ShadeTreeExpert Supporter
    Aug 31, 2009
    19,086
    Silver Spring, Md
    I really like the tank with the chimney.
    darmahman and Jim K in PA like this.
  16. Pokie
    Apr 4, 2013
    8,338
    Fort Collins, CO
    I've been busy with other stuff lately, so not much action here. To update things a bit, I've fabricated the sidecar mounts to be put back on the frame. They don't look stock but I think will work as well as the stock ones.
    I thought I would start with the more difficult one,... the rear ball mount.
    Turning the ball.
    The finished ball mount.
    The ball mount and the upper mounts. Now I just have to do the final fitting and weld them to the frame.
  17. Pokie
    Apr 4, 2013
    8,338
    Fort Collins, CO
    Next up, I had to put a steering damper on the frame (more parts the previous owner cut off). I fabricated a simple bracket that needs to be welded to the frame, then made a damper plate like the original /5 plate but a bit longer and wider.
    The worn out original is on the right. The replacement is in the middle.
    The mount welded in place and the new plate fabricated.
    All the parts fitted. Presently in the process of making a new damper handle. The plastic /5 damper handle just doesn't suit my build.
  18. Plaka
    Jun 19, 2010
    9,173
    I'm seein' an 8-ball.
  19. crawler07
    crawler07 Been here awhile Supporter
    Oct 19, 2010
    343
    West Virginia
    Theres going to be a sidecar,,,,YES!!!!
    Great build Pokie, cant wait to see what you come up with next!
  20. Pokie
    Apr 4, 2013
    8,338
    Fort Collins, CO
    "I'm seein' an 8-ball."
    While a neat idea, I don't think it would be glove friendly. I'm thinking more like a key, like the early bikes.
