Mad Max sidecar tribute build
Discussion in 'Some Assembly Required' started by 3legs, Jul 7, 2019.
  1. villageidiot
    villageidiot Long timer Supporter
    Apr 29, 2010
    17,309
    Orange County, CA
    I dunno how much volume. But generally when I select a volume, I go to 11
  2. Fast Idle
    Fast Idle Since the Sixties Supporter
    Nov 9, 2012
    4,708
    The Great Land
    3 gallons!
    :hide
    3legs and villageidiot like this.
  3. Damian_74
    Damian_74 Been here awhile
    Feb 4, 2008
    921
    Brisbane, Australia
    Is that US or Imperial Gallon?
    Fast Idle and Richarde1605 like this.
  4. Fast Idle
    Nov 9, 2012
    4,708
    The Great Land
    Which ever ends up being the closest.:photog
  5. 3legs
    3legs Real men ride sidecars Supporter
    Oct 3, 2007
    3,716
    Adelaide,South Oz
    :lol3:lol3:lol3
    That's cheating. Love your style :D:D:D
    So that's 11.35L from US gallons.
  6. GotDammitDave
    GotDammitDave Been here awhile
    Jul 27, 2016
    346
    Newport,NC
    Im thinkin 2 an a half to 3 an a quarter gallons..
    3legs likes this.
  7. Fast Idle
    Nov 9, 2012
    4,708
    The Great Land
    Or 13.6 from Imperial gallons. :D
    Two chances to win!:rofl
    3legs likes this.
  8. steam powered
    steam powered just a regular punk
    Jun 17, 2018
    1,234
    New Zealand
    8.51L, or being a sidecar outfit about half of what would be really useful.
    Fast Idle, 3legs and villageidiot like this.
  9. 3legs
    Oct 3, 2007
    3,716
    Adelaide,South Oz
    Bike is back at Nick's place for painting so I will post updates at each stage of painting.
    Just waiting on a fuel tap for the tank before I can confirm the capacity.
    MFP, Scrivens, Richarde1605 and 6 others like this.
  10. 3legs
    Oct 3, 2007
    3,716
    Adelaide,South Oz
    Woohoo!!!
    Trailer chassis is ready to pick up tomorrow. All other projects on hold except Mad Max.
    MFP, Roofchop, tomo8r and 7 others like this.
  11. 3legs
    Oct 3, 2007
    3,716
    Adelaide,South Oz
    Just a quick update ( because my bloody Victorian mate couldn't be bothered to read this thread .........Hi TD :lol3 ), the bike is still being prepared for paint but the trailer is coming along nicely.
    Made a lot of brackets for the tie down straps ready to be welded to the chassis. Made a removable winch mount.
    Will start making brackets to convert the draw bar to a tilt bar.
    Hopefully will have a look at the bike this weekend.
    sruss67, Fast Idle, tragerbon and 5 others like this.
  12. 3legs
    Oct 3, 2007
    3,716
    Adelaide,South Oz
    Spent the last week making tie down mounts and mounts to convert to a tilt trailer.
    Spent most of the time measuring, re measuring, working out the angle of the dangle, making the bracket then realising I [email protected]#ked up and starting again but now all done. Now to turn the trailer upside down and cut welds, drill, weld and probably still have some more [email protected]#k ups :lol3:lol3:lol3
  13. 3legs
    Oct 3, 2007
    3,716
    Adelaide,South Oz
    Little more on the trailer ( ok it's not the bike but it is the trailer specifically designed to take the outfit, well that's my excuse and I'm sticking to it :lol3 ).
    Now you can see the method in my madness. The outfit is going nowhere with those straps. One on each rear wheel. Removable winch mount up front.
    Will cuts the welds on the drawbar tomorrow and then weld the hinge mounts that are currently tack welded to the chassis.
  14. sruss67
    sruss67 Been here awhile Supporter
    Aug 2, 2009
    413
    Devonport, Tasmania, Australia
    Brilliant solution, nice work.
    3legs likes this.
  15. 3legs
    Oct 3, 2007
    3,716
    Adelaide,South Oz
    Got my new forward controls levers back from the benders.
    Now to get the levers welded to the rings and then off to the chromers once I've worked out where I'm going to put the cable holder. This is a simpler version of what I had originally. A cable will operate a master cylinder for the rear brake mounted under the dome. Personally I think these are better looking and not just because I designed them :lol3 plus they look close to the original items.
    Also what a PITA to take the drawbar off. Only managed to break 2 welds. I'm just using an angle grinder with a cut off disc but there is very limited space plus I'm laying on my back.
    Will certainly have some welding of cuts that I didn't want and cleaning them up. At least once the drawbar is off it's plain sailing from there on ( touching as much cellulose as I can find :lol3 ).
    sruss67, mrsdnf, Fast Idle and 4 others like this.
  16. Roofchop
    Roofchop Hands up mother stickers, this is a f**k up!
    Jan 9, 2016
    756
    Carool, NSW
    Tip the trailer on its side to access welds.....
    How come you didn't get the trailer mob to do the hinge bit?
    :jack
  17. 3legs
    Oct 3, 2007
    3,716
    Adelaide,South Oz
    I was thinking that but it's too bloody heavy to lift myself but I do an engine crane so I see what I can do.
    I was going to get them to build it that way but it was going to cost way too much to get them to do it.
    Roofchop and Richarde1605 like this.
  18. 3legs
    Oct 3, 2007
    3,716
    Adelaide,South Oz
    Got the drawbar off, I hate angle grinders, they are bloody dangerous at times but what choice do I/we have.
    Welded the hinges on and will put it back together again tomorrow and see if I did it right first time. My welding is getting better. I'm certainly not a professional but I know my welds don't break ( none of my sidecars have ever broken a weld so I must be doing something right :lol3 ). I really like the mig. Will never go back to stick welding.
    JagLite, scot_douglas, nostep and 5 others like this.
  19. 3legs
    Oct 3, 2007
    3,716
    Adelaide,South Oz
    Ok it works. Welded outside hinge plates and gave most of it a paint.
    Still have to weld on the locking plates on the front of the trailer. Will do that tomorrow then will go buy the floor. 3mm Ali checker plate.
    Then it's time to make a full width ramp. Probably out of steel with an Ali mesh floor.
  20. Fast Idle
    Nov 9, 2012
    4,708
    The Great Land
    Looks like maybe you could skip the ramp and just drive on with it tilted like a snow machine tilt trailer.
    It would transition to level as the weight comes forward and then you pin the locks.
    Just wondering if that might work for you.
    Any news on the MM paint?
    villageidiot likes this.
