Mad Max sidecar tribute build
Discussion in 'Some Assembly Required' started by 3legs, Jul 7, 2019.
  1. Roofchop
    Roofchop Hands up mother stickers, this is a f**k up!
    Jan 9, 2016
    755
    Carool, NSW
    As above.
    I just hired a 2 ton excavator with a tilt trailer.
    It had 2 fat 4x4 shock absorbers to calm shit down as you "tilt"
    Worked really well. You'd be fine with 2 regular car shocks.
    Richarde1605 and 3legs like this.
  2. 3legs
    3legs Real men ride sidecars Supporter
    Oct 3, 2007
    3,696
    Adelaide,South Oz
    Yeah I had been thinking about that. I might delay building the ramp and try it when the outfit is finished although it will be used for solo bikes as well so either way it will still need a full width ramp.
    I don't like using single ramps due to my crook leg.
    Not only that but the ramp will be removable so I can store it upright.
    Slow progress on the paint work. Still waiting for a fuel tap and filler cap and bung.
    mrsdnf and Roofchop like this.
  3. 3legs
    Oct 3, 2007
    3,696
    Adelaide,South Oz
    Trailer tilt hinge works perfectly. All welded up. My welding is getting better. Even tried some vertical welding and whilst not pretty it will hold.
    I have 2 Ali fold out ramps that I'm thinking I might join the two together and whack some Ali mesh over the top and weld some hinges on. Might just work and it will use some ramps I've had laying around collecting dust.
    JagLite, MFP, Roofchop and 7 others like this.
  4. 3legs
    Oct 3, 2007
    3,696
    Adelaide,South Oz
    It works.
    Had to make a couple of small mods to the hoist mounts.
    1st attempt and trailer drawbar would not go past 90 degrees and the trailer got stuck in the upright position due to the cable being caught up in one of the safety levers. Had to call the neighbour over to give me a hand.
    Took off the cut out switches and now it works beautifully. Tried without the drawbar on for a test then attacked the hinge with a grinder and put the drawbar back on ( and sprayed some silicone lube which made a big difference ) and lifts straight and true however I will need to make a little "dolly" for the drawbar so it moves when I lower it because when I go to lower it the drawbar sits on the ground. Great for when it's stowed but not when I want to use it.
    As you can see from the side view it takes up very little room. I still have to make some minor mods to the hoist mount to make it stronger but it should work out nice.
    Looks like I will need to move the fridge to make some more room. First world problems, I know :photog
    Whacked the ali pieces for the floor on just to see what it looks like. Not bolted yet.
  5. Scrivens
    Scrivens Long timer
    Jun 5, 2011
    1,934
    usually the garage
    Neat work. I had my sea kayaks hanging top-in on the garage wall as the roller door mechanism stopped me using ceiling straps as I had in my previous house.
    3legs likes this.
  6. sruss67
    sruss67 Been here awhile Supporter
    Aug 2, 2009
    408
    Devonport, Tasmania, Australia
    Great stuff Alex, looks really good, and well thought out.
    A good solution.
    3legs likes this.
  7. 3legs
    Oct 3, 2007
    3,696
    Adelaide,South Oz
    Well i've had an eventful night. Some arsehole decided to see how fast he can drive down my street in the wet.
    Lost control and took out our fence and tree and did a runner.
    Car is not registered but not reported stolen ( probably has now by the offender ).
    So all morning it's been phone calls to various companies for a new fence and tree removal.
    Oh well, we wanted to get rid of the tree anyway and I need a break from the shed :lol3:lol3:lol3
    JagLite, MFP, AK650 and 5 others like this.
  8. Scrivens
    Scrivens Long timer
    Jun 5, 2011
    1,934
    usually the garage
    Good one. The hoons - bikes and cars - have been out in Magill for the last couple of weeks and the speeds are insane, especially with all the small cross streets.
    JagLite, AK650, Fast Idle and 2 others like this.
  9. 3legs
    Oct 3, 2007
    3,696
    Adelaide,South Oz
    Trailer and hoist are finished. Still have to make the enclosure for the trailer but it can now be used.
    You can see where the winch is mounted and where I will mount the wheel chocks for solo bike use. I will use the LHS wheel chock mounting holes for the battery mount for the winch. Just 4 bolts so will only take a minute or 2 to take off.
    I've strengthened the hoist mount to stop it from flexing too much. Just some minor adjustments and all done and then get stuck into the full width ramp.
    Then I can get stuck into finishing the forward controls of Mad Max.
    JagLite, MFP, AK650 and 8 others like this.
  10. Sidecarjohn
    Sidecarjohn SidecarJohn Supporter
    Aug 29, 2008
    1,351
    Yorkshire, England
    Any chance I could borrow the trailer next weekend ?
    Reckon a day will be sufficient.
    Day rate, or hourly ?
  11. 3legs
    Oct 3, 2007
    3,696
    Adelaide,South Oz
  12. 3legs
    Oct 3, 2007
    3,696
    Adelaide,South Oz
    Ok trailer finished and raised into it's stowed position. Will make a ramp later. I have more urgent things to finish.
    I'm going to get a full size banner made up to fit between the wheels to cover the underside of the trailer and just to make the area look neater.
    I'm thinking something like this.................
    To go between the wheels of this......
    Now to finish the S2A 350 while Nick is painting Mad Max.
    JagLite, MFP, Bluetonguejak and 6 others like this.
  13. Oldschoolrocker
    Oldschoolrocker a.k.a. EZE Supporter
    Sep 14, 2017
    3,158
    Reardan, WA
    Good idea!! Except make white background same color as your "3 legs" :D
    3legs likes this.
  14. 3legs
    Oct 3, 2007
    3,696
    Adelaide,South Oz
    That's a good idea OSR.
    Maybe something like the background of this Ferrari flag.
    Hopefully the banner place can overlap graphics. I assume they can.
    JagLite likes this.
  15. Sidecarjohn
    Aug 29, 2008
    1,351
    Yorkshire, England
    "Scuderia Tre Gambe"
    3legs and Richarde1605 like this.
  16. 3legs
    Oct 3, 2007
    3,696
    Adelaide,South Oz
    Something my daughter made up for me last night. Needs to cleaned up a bit but it's close.
    I like it.
    JagLite, MFP, tomo8r and 5 others like this.
  17. JimVonBaden
    Feb 11, 2005
    96,734
    Alexandria, VA
    Top and bottom are perfect. The middle needs integration work!
    AK650, 3legs and Fast Idle like this.
  18. Fast Idle
    Fast Idle Since the Sixties Supporter
    Nov 9, 2012
    4,693
    The Great Land
    I like it too, and your daughter came up with it so that's even cooler yet!
    A little touch up work and it will be Aus-some. :photog
    Cheers!
    Pezz_gs, MFP, AK650 and 6 others like this.
  19. 3legs
    Oct 3, 2007
    3,696
    Adelaide,South Oz
    Thanks Steve. Yeah I agree about the integration but there's not much I can do.
    I wanted an image to show the bike and Mel Gibson and Steve Bisley and that is the only shot that shows all in one scene.
    I will see what she can do with it.
    JagLite, Fast Idle, AK650 and 2 others like this.
  20. 3legs
    Oct 3, 2007
    3,696
    Adelaide,South Oz
    Ok my Daughter come through with an update for the banner.
    She softened the edges of the photo.
    See what you think.
    bk brkr baker, JagLite, MFP and 10 others like this.
