makita cordless or a pneumatic impact for automotive suspension?
Discussion in 'The Garage' started by hotwheels22, Oct 12, 2019.
  1. nickguzzi
    nickguzzi Long timer
    Feb 17, 2010
    7,520
    below the sea
    I doubt many pawn shops will have an compressed air for you to try it on. Front bearing play, trigger integrity and forwards/reverse buttton is about all you can see.
    They are easy to take apart, but I expect that will be too late. The vanes do wear, but well known brands are replaceable. Mine are still servicable after more than 20 years. The rotors do get scored but it has to be really bad to affect anything. Having an inline oiler and filter really helps.
    I would have a good look on ebay or any machine sellers and see what sort of prices are being asked - mine was not expensive brand new and this applies to most air tools - then you can see if something with a guarantee is better or worse value than what you find.
    I should have mentioned, check out the output of your compressor and the air consumption of your proposed gun. NFG if you only have a little pancake thing. I only ever used mine in workshops, so consumption was never an issue for me.
    #21
  2. usgser
    usgser Long timer
    Nov 6, 2005
    3,532
    Westside WA
    For auto suspension work you want pneumatic 1/2" drive impact wrench. Aslo get a set of real impact sockets not chrome ratchet sockets.
    #22
  3. 1greenmachine
    1greenmachine Long timer
    Aug 28, 2010
    3,823
    green bay, wi
    First off what are you working on, car or bike?
    Secondly and most important is what air compressor do you have at home, I have a 30 gallon compressor and maybe get 5 seconds of full power before the air pressure is gone and you wait for it to refill while at work I can go all day.
    #23
    hotwheels22 likes this.
  4. hotwheels22
    hotwheels22 formpig.com + motorradRP
    May 29, 2015
    5,721
    austin
    automotive suspension work.
    i have one of those massive makita compressors i bought with some construction money thinking i would use it for framing or a rag tag framing crew. but it just sits in storage for an odd job i need to pull it out for...
    if i had a pneumatic impact i suppose i would use it more...
    #24
  5. 1greenmachine
    Aug 28, 2010
    3,823
    green bay, wi
    https://www.harborfreight.com/air-t...te-xtreme-torque-air-impact-wrench-62891.html
    This impact gets a lot of love on a different site, I prefer ingersoll rand impacts as they have served me really well and tons of parts available if needed.
    I would suggest checking out new as any used impacts I've seen have always been completely worn out. These are my work ones that were barely used and the other a demo. 20190919_145256.jpg
    #25
  6. hotwheels22
    May 29, 2015
    5,721
    austin
    gents. how about this thing?!
    #26
  7. 1greenmachine
    Aug 28, 2010
    3,823
    green bay, wi
    No.
    #27
  8. hotwheels22
    May 29, 2015
    5,721
    austin
    thanks...
    #28
  9. roger123
    roger123 Long timer Supporter
    Jun 23, 2007
    2,359
    VA Beach, VA
    I have that Makita 18V impact, it's a beast, super powerful. Problem is that it's HUGE and VERY heavy, there are places that you just can't get it into (at least on my Grand Cherokee).
    Having said that, I seldom break out my IR air impact gun anymore. But I'm primary using an impact for tire work. It's just really convenient to not have to drag out the air hose when I can just grab the electric and go.
    #29
  10. 1greenmachine
    Aug 28, 2010
    3,823
    green bay, wi
    I'm not trying to be a dick but youre wasting your time trying to find anything quality at pawn places, it's either worn out or they want to much for it. The earthquake hun at HF is quite capable and you can get some decent impact sockets when you're there.
    #30
  11. 1greenmachine
    Aug 28, 2010
    3,823
    green bay, wi
    The makita is definitely huge, Milwaukee is a lot shorter and more powerful but not to cheap.
    For 3/8 stuff I stick to mostly cordless but working on semis in the rust belt you need that extra power the 1/2 air impacts bring.
    #31
  12. HeavyMetal
    HeavyMetal Been here awhile
    Oct 12, 2009
    350
    Kimberly, ID
    If you're only using it once in a while or a one-time job on your suspension get the electric. A Harbor Freight will work for what you are doing. Or the Makita if it uses the same batteries you already have.
    The spec's for that Makita say 790 ft. lbs.
    That will break anything loose on a car, although that's probably an optimistic figure. And get impact sockets.
    #32
  13. showkey
    showkey Long timer
    Jun 25, 2007
    2,355
    Wausau
    You guys need to get out more.
    I purchased a M18 Milwaukee impact three ago. Have not used my air impact since. The M18 handled every fastener on ground up restoration of two 70 year old GMC pickups.
    Just purchased a compact M12 Fuel compact 3/8” impact rated at 250 ftbs. More than capable to handle lug nots in very small package.
    #33
    Wasser likes this.
  14. HeavyMetal
    Oct 12, 2009
    350
    Kimberly, ID
    My son got a M18 Milwaukee that is rated at 1100 ft. lbs. if I remember correctly.
    I was sceptical so had him bring it over and we used it on a semi truck lug nut.
    They are torqued to 450. It broke one loose and retightened it to the same torque. But I doubt it would have enough battery power to do all 10 on one wheel. But it is half inch. I really didn't think it would even do one.
    I was pretty impressed though because that isn't what they were made to do.
    For the occasional home gamer doing automotive, probably any brand would work.
    #34
  15. beemerkid
    beemerkid Do you ADV
    Feb 14, 2009
    1,592
    Seward, AK
    @HeavyMetal it totally should take them all off with the appropriate battery.
    I believe any of the current offerings from any of the major manufacturers would be more than enough for what you're looking for. I'm of course taking about the high torque 1/2" guns , not a 1/4" driver, though those have a pretty big place in automotive work too with a nice set of socket adapters.
    #35
