mappite.org - create routes easily, feedback wanted!
Discussion in 'Trip Planning' started by gspeed, Apr 4, 2015.
  1. TTGator
    TTGator 2016 BMW S1000 XR, 2018 G310 GS
    Jun 14, 2016
    337
    Kernersville, NC
    Looks pretty nice. I couldn't tell from the description in the app store... does it have voice turn-by-turn navigation?
    #61
  2. scootertrog
    scootertrog Been here awhile
    Mar 26, 2011
    664
    Missouri USA
    I don't know about the turn-by-turn, I gave up on wanting that feature as it was just too much hassle when using the Sena for both intercom and music. All 3 features never wanted to play well together.
    #62
  3. TTGator
    Jun 14, 2016
    337
    Kernersville, NC
    Hmm.... good to know since that's one of my use cases.
    #63
  4. gspeed
    gspeed Adventurer
    Oct 10, 2011
    62
    Around Alps, Italy
    @scootertrog what if you create the route directly using the iphone: when you try to export the file, does safari ask you to "open with" Galileo Pro or it just tells you that can't export?
    #64
  5. gspeed
    gspeed Adventurer
    Oct 10, 2011
    62
    Around Alps, Italy
    the red line always existed in mappite and it just visually connects waypoints and it is... well... useless other than visually connecting waypoints ;) When you export to a GPX file, the content of the file depends only on what you select in the menu (i.e. route, track or waypoint).
    #65
  6. gspeed
    gspeed Adventurer
    Oct 10, 2011
    62
    Around Alps, Italy
    well, I feel that's a bit overstated but thanks ;)
    #66
    9Realms likes this.
  7. scootertrog
    Mar 26, 2011
    664
    Missouri USA
    I don't use Safari or create a route on the iPhone.
    #67
  8. gspeed
    gspeed Adventurer
    Oct 10, 2011
    62
    Around Alps, Italy
    Ok... if you can try pls. let me know if it works! i.e. directly create a route on the iphone and export the gpx: it should ask to open it with galileo pro or whatever you have that can handle gpx. Thanks!
    #68
  9. DRTBYK
    DRTBYK All Things GPS
    Mar 26, 2003
    7,859
    47°50′15.8″N, 119°56′21.9″W
    Your GPX Export from within Safari on iOS is working now. But using Firefox on iOS does not bring up the "Download" page dialog. Instead, it opens your Garmin Connect dialog - see below.
    #69
  10. gspeed
    gspeed Adventurer
    Oct 10, 2011
    62
    Around Alps, Italy
    @DRTBYK the dialog you see in firefox is the mappite one, not Garmin Connect. I guess Firefox in iOS just saved the GPX in the Download folder (could you check and confirm? I woudl be glad to know!), while Safari asks you where to save or if to open with an app, that's a browser preference you can change within the browser options.
    #70
  11. DRTBYK
    Mar 26, 2003
    7,859
    I think you're most likely not very familiar with iOS. There is no "Download" folder in iOS. You, the developer, must recognize that it is a Mobile Browser and make the proper iOS Document Share API calls.
    #71
  12. gspeed
    gspeed Adventurer
    Oct 10, 2011
    62
    Around Alps, Italy
    thanks for the feedback, you are right I'm not that expert about iOS - but that's what iOS Chrome does (and yes, folders exists behind the scene in iOS too). I checked more about iOS Firefox and it seems download is not supported yet: what I would need to understand is if I can catch this rather than showing the message in the screenshot above...
    #72
  13. DRTBYK
    Mar 26, 2003
    7,859
    You are correct. My mistake, I thought surely I had downloaded from other Apps in Firefox.
    #73
  14. Macho Man2
    Macho Man2 Long timer
    Aug 19, 2009
    1,102
    Corryton,Tn
    I'm kinda GPS challenged and in need of help. I created a route and than to download it in GPX format to my Garmin Zumo 660 and it doesn't show up. I must have missed a step somewhere any help would be appreciated.
    #74
  15. Clampett
    Clampett Uncle Jed
    Feb 5, 2015
    1,453
    Clampett_Valley (Bama)
    I don't have the 660, but I think it would be under Tools>custom routes.....
    It's not where I expected to find it when I downloaded mine....
    #75
    Macho Man2 likes this.
  16. Macho Man2
    Aug 19, 2009
    1,102
    Corryton,Tn
    I checked there and than tried it again with the same results, I don't know what I'm doing wrong...such the life of a anything electronic dumb ass! I'll keep trying though and maybe I'll figure it out!
    #76
  17. Macho Man2
    Aug 19, 2009
    1,102
    Corryton,Tn
    Ok, I need a little help. I created a route and when I tried to export it I have tried route GPX, Tracks GPX and waypoints and none show up on my Garmin unit when I try to import it what am I doing wrong?
    #77
  18. DRTBYK
    Mar 26, 2003
    7,859
    What folder did you put the GPX file in? Have you tested the GPX file in another Application to make sure it can be opened/read?
    #78
  19. Macho Man2
    Aug 19, 2009
    1,102
    Corryton,Tn
    When I downloaded the GPX file I sent it to my garmin drive E, I will try to see if it will show up in my hard drive and try from that. I thought that it worked directly from the download to the GPS.
    #79
  20. DRTBYK
    Mar 26, 2003
    7,859
    You must place your GPX file in the zumo660/Garmin/GPX folder.
    #80
