mappite.org - create routes easily, feedback wanted!
Discussion in 'Trip Planning' started by gspeed, Apr 4, 2015.
  1. hennessyktm
    hennessyktm Still here...
    Apr 9, 2009
    261
    Munster, Indiana
    Still can't get it to work.
    I cannot get a route built (not just waypoints, an actual route) to go from mappite, into basecamp, and into my GPS. I understand BaseCamp is not necessarily required to transfer waypoints from mappite to a device; however, as mentioned, having only waypoints in my GPS isn't what I am looking for. I am looking for a route.
    I am sure I am screwing something up, or missing a step, but I can't get to to work.
    Thoughts...anyone?
  2. gspeed
    gspeed Adventurer
    Oct 10, 2011
    99
    Around Alps
    A route gpx file basically contains just waypoints and the instruction to tell the device to recalculate the route across them. If you export as a "route (gpx)" and copy directly the RouteName-rte.gpx file in the GPS device (/GARMIN/GPX) - that will work. You should find the way to make it working with basecamp as well , I'm aware of other folks importing mappite routes fine. Unfortunately I can't help on that one since I don't use windows!
  3. sajor
    sajor Been here awhile
    Sep 2, 2015
    293
    arizona
    In the past i used this application with success but now when im in mid point of making my route when i press to make a way point it goes forward instead of connecting with my last way point.
  4. hennessyktm
    Apr 9, 2009
    261
    Munster, Indiana
    Thanks for the input. I'll keep at it and report back WHEN I figure it out.
  5. gspeed
    gspeed Adventurer
    Oct 10, 2011
    99
    Around Alps
    Here we are: long tap (or right click) on the bar icons and the correspondent items on map will disappear. I would need to create a new video tutorial soon or later...
    Starstruck likes this.
  6. gspeed
    gspeed Adventurer
    Oct 10, 2011
    99
    Around Alps
    I finally updated the video... about one minute for a quick overview:
    Clampett likes this.
  7. sajor
    Sep 2, 2015
    293
    arizona
    I'm about to leave for a Lil day trip to do some trail riding, I used mappite to create my route from start/end of trail, the trail starts off the highway and could be a little hidden lol, is there anyway I can edit mappite to start from my home to start of trail.Thx
  8. Starstruck
    Starstruck Been here awhile Supporter
    Oct 25, 2010
    202
    Traveling
    Nice! Works great.
  9. gspeed
    gspeed Adventurer
    Oct 10, 2011
    99
    Around Alps
    Hi, not sure I get it - do you mean how to add a new waypoint at the beginning of an existing route? [answer is click on + sign next to the first waypoint name on the bottom left panel]
  10. raiderone
    raiderone Been here awhile
    Apr 1, 2013
    228
    north texas
    I use mappite and scenic now for all my route and navigating now. Got rid of the garmin crap, your site is perfect. Thanks for making it
    Clampett and Suncoaster like this.
  11. gspeed
    gspeed Adventurer
    Oct 10, 2011
    99
    Around Alps
  12. Dolly Sod
    Dolly Sod I want to do right, but not right now
    Aug 18, 2003
    18,873
    Richmond, Va
    You should combine forces with the guy that does kurviger. His curvy road routing with your ability to save tracks to the browser would be a good combination.
  13. gspeed
    gspeed Adventurer
    Oct 10, 2011
    99
    Around Alps
    thanks Dolly - that looks interesting, it actually uses an open source routing engine which I might use as well... I'll check better and maybe contact them.
  14. Scrooge
    Scrooge Adventurer
    Jul 6, 2007
    10
    Central Indiana
    Just stumbled on this thread and and checked out your creation. Gotta say, love the mappite site. Very well done. I've also been playing with furkot for a few days and like it as well for different reasons, but it can be confusing and frustrating at times. I like the premise of Mappite; lite, simple, and just plain works. For me it's perfect for laying out a day trip or even a weekend when all I'm interested in is riding. It's very quick to lay out and export a route and that is a huge benefit to me. Thanks for making it.
    I do have one issue that I can work around but don't understand why it is happening. I create a route, name and save it, and then export. It goes into my downloads folder, but the file is just called "unknown". Doesn't have file name or extension. Apparently all the data is there because I can rename it with Finder and then send it to my gps, open the track in Osmand and everything is there. By the way, my browser is Safari 8. I don't think it's user error or a browser setting because it doesn't happen when I export a furkot file.
  15. gspeed
    gspeed Adventurer
    Oct 10, 2011
    99
    Around Alps
    @Scrooge I realized I never answered you. Thanks for the appreciations - Safari 8 ignores an html5 attribute preventing the file name to be set properly when the file is generated in the browser. Technically, Mappite gpx files are generated within the browser in javascript language, rather than in the server and pushed to the browser, as furkot does. The issue should be solved in Safari 10.1+ (if anyone can confirm I would appreciate!)
  16. gspeed
    gspeed Adventurer
    Oct 10, 2011
    99
    Around Alps
    Some news
    • import routes in gpx/itn format. Once imported the route can be saved/updated/exported as if it was created in mappite. Well, I hope... If you import multiple routes they get concatenated.
    • import tracks in gpx format. The elevation info, if available, is displayed. You can import multiple tracks. For the time being tracks can't be saved.
    • You can use tags to tag (!) routes... useful if you've several saved routes.
  17. kurviger
    kurviger Bloke from Kurviger.de
    Apr 29, 2017
    99
    Feel free to contact me. We are offering our curvy routing algorithm as API as well. The Kurviger API is available via the GraphHopper directions API.
  18. gspeed
    gspeed Adventurer
    Oct 10, 2011
    99
    Around Alps
    Sure, I'll do - thanks
    kurviger likes this.
  19. gspeed
    gspeed Adventurer
    Oct 10, 2011
    99
    Around Alps
    An update on Kurviger: mappite.org is currently a non-profit tool and Kurviger plans are not as flexible as other provider' ones. For the time being we'll remain focused on enhancing mappite with other features and we'll re-consider to implement Kurviger when/if there will be a revenue stream to sustain the cost.
  20. gspeed
    gspeed Adventurer
    Oct 10, 2011
    99
    Around Alps
    It's a bit I'm not posting features updates here, I shall do better marketing ;) Well, actually, the number of users increased greatly and I've quite the opposite issue since some of the services used by mappite behind the scenes are free just up to a certain threshold - and donations does not compensate the costs. It's likely I will need to think seriously about some premium features to make the tool sustainable in the mid/long term.
    In any case, I'd like it to continue being the fastest way to create and share routes ;)
    Suncoaster likes this.
