Marzocchi Fork Maintenance De-Mystefied?
Discussion in 'Trials' started by motobene, Oct 22, 2014.
  1. motobene
    motobene Motoing for 49 years Supporter
    Mar 9, 2013
    7,081
    Wichita Mountains SW Oklahoma
    I rewrote this to be more clear.
    First is background and last is the fork oil change procedure.
    Closed-Cartridge Forks - Poor & Contradictory Tech Info
    I found little (and contradictory) tech info regarding closed cartridge forks on trials bikes. There is much more available info on closed-cartridge USD forks for other bikes on YouTube. Anyway, here is exploded view of the Marzocchi aluminum-stanchion trials forks:
    In the exploded view all the parts are exploded, including caps, etc. In my descriptions below the parts are in described as subassemblies.
    The aluminum-stanchion closed-cartridge Marzocchi forks are quite common on many later-model trials bikes. These typically have a black coating on the aluminum tubes and various paint colors on the cast aluminum legs or sliders. Most common is white. These forks predominate the GasGas trials bike up to present (2014). The exceptions are Eco with Olle R16V forks and shocks, and the Replicas with Tech forks. The new Ossas use the Marzocchis. I have a `10 Econo 280 that has Sachs forks with black diamond coated steel stanchions and cast aluminum sliders that are also closed cartridge.
    And what is "closed cartridge?" Forks were long damper rod based. Oil was simply squeezed through orifices in compression and rebound. Later came cartridge forks where the damping was done inside cartridges with rods attached to the fork caps. A more recent innovation was the so-called closed-cartridge forks. The previous cartridges were then called 'open', that is, they exchanged a significant volume of oil with the surrounding reservoir at each stroke, being 'pump-through' designs, pulling oil from the surrounding reservoir and dumping that oil back to the reservoir from the caps. Closed cartridges are not truly closed. They still exchange oil from the surrounding reservoir, but they exchange little oil per stroke. They require a special bleeding procedure if you disassemble them or unwittingly pump the oil out of them during an oil change.
    My unpleasant intro to the closed-cartridge designs was doing maintenance on my `10 Econo's Sachs forks. I dutifully pumped the rebound cartridge out as one might do with open cartridge forks to get rid of the old oil in them. That took some effort, and I was rewarded with a Homer doh! forehead smack. I refilled the fork then could not get the cartridge to pump back up as expected. Off to the web I went to find complaints of no damping by riders after fork oil changes. I also found little or just crap info about bleeding procedures. It took about 10 hours of riding time for the rebound cartridge to finally exchange enough oil to de-air itself. This experience made me averse to changing oil in the Marzocchi forks, which I knew are also closed cartridge designs. Then it dawned on me while riding at Sipapu - one of those eyelid movies that play on the loop (for engineer types anyway) - that I could simply step around the hassle by changing only the oil bath around the cartridge, which is the majority of the volume of the oil, and that I could exchange all the oil by doing the simpler oil change more than once, avoiding any special bleeding procedure.
    If any of you have found a well-written bleeding procedure for closed cartridge forks, please post that here, as some of us may some day have to disassemble the forks. I have one I translated from an Italian guy who said he worked for Marzocchi, but I could not get it beyond a garbled mess.
    My `11 Raga Marzocchis
    I needed to do maintenance after a year of competition to keep the metal particulates count down, and I wished to change the oil as my forks have long been on the too-sat side, and I ended up dialing the adjusters near all the way in.
    The previous oil change was about 2012 by the former owner, who reported a big hassle because he was curious abou the cartridges and disassembled them. He was used to open-catridge forks and could not get them to pump up, so he disassembled them again thinking he had made some mistake. Many frustrated hours later, he learned there was some special procedure for bleeding them, but could not find it. I'm not sure how he got them to bleed, maybe just by riging the bike a while.
    The former owner said made up some of the recommended 7.5 weight oil by mixing half Redline synthetic 5 with half Redline synthetic 10 (they don't have a 7.5). I'd checked the oil after I got the bike. It was set to about 6.25" height (I later set mine at 6.00"), and it looked clean, so I just stuck with that oil until now.
    Yesterday I did the maintenance . Experience showed I needed a slightly thicker oil to bring the adjusters back to the mid range of clicks. That proved to be a right guess. I had on hand some Maxima Racing Fork Fluid, their top high-performance stuff. Maxima actually provides the oil viscosity as 165 SUS (Saybolt Universal Seconds) and equated with SAE 10 weight. Most oil retailer list their oils in SAE weights, which is not an accurate way to describe viscosity. I don't know what Redline 7.5 is in SUS, but I can tell you it is too thin. If you use Redline, which is a really top oil, use their 10 weight.
    Here is the web link to Maxima Racing fork fluid:
    http://www.maximausa.com/product/racing-fork-fluid/
    Also listed on the Maxima oil is the viscosity index or VI 150. Thus the oil I used is labeled as "165-150 SUS-VI" Viscosity index, the second number, is the measure of an oil's resistance to changing viscosity with temperature changes. A higher number is better, and the synthetics are tops in this category. Anyway, it was a very good oil I used. Had I had Redline in 10 weight, I'd've been happy to use that as well, but because they don't list the viscosity, how thick is it at a given temperature, really?
    Another aggravation I found is the web and the tech info is confused regarding the recommended oil height. Oil height is the best way to deal with forks. The oil-height spec is actually the depth from the top of the stanchion to the oil when the forks are fully bled, collapsed and the springs are out. Changing fork oil only by volume is a bad idea because it is not accurate. You can end up with too much or too little oil. As long as you have enough oil it won't affect the damping at all, but it will affect what can feel like damping at end of travel: the secondary air spring, the stiffness of which is determined by the size of the air bubble trapped in the fork above the oil level. With the springs in, the air bubble is pretty small and the pressure inside spikes way up when the forks are bottomed. Too much oil can lead to solid bottoming before end of travel (massive pressure spike). Too little oil can lead to too weak a secondary spring for harsher bottoming, and if there is way too little oil you can suck air into the cartridges for sketchy damping. The only way to know for sure what you have in there is to measure by the "height spec." I use a flashlight to see in there and a wire that goes down and touches the oil to find the level. On my Marzocchis, I bent wire 90 degrees at 6" and made the settled oil just touch the wire when it rest on the top edge of the stanchion. Some use fancy tools to suck out oil to a specific level, but I don't have one of those.
    So what is the Marzocchi height supposed to be? I found 180mm, then 160mm, and also 140mm. I think 180mm will have too much air and too soft a secondary air spring will be too soft. At 140mm the volume of trapped air may be too small. I opted for 152mm (6.00") and that is working as it should.
    A long test ride at the middle temperature of 70 degrees showed the forks to be working as they should. Controlled, but I could still hop with ease. The adjusters settled into 16 of 26 of a total of clicks in, which is on the slow side of the mid point. The Maxima '10 weight' oil is definitely confirmed as right and not too thick and it gives me a wide rancge of clicks for extreme temperatures compensation.
    My Simplified Maintenance Procedure
    Both Marzocchi forks are similar in build though the right side fork has rebound damping with an adjuster, and the left side has the compression damping with an adjuster. I suspect both sides share some rebound and compression resistance as these forks have a spring in both sides as opposed to previous forks with a spring only in the compression side to balance the spring and damping forces.
    On the rebound side when you remove the cap a long rod with o-ring at the end will pull out of the cartridge rod. The compression adjuster screw stays with the cartridge rod on the compression side.
    I pressure wash my bike first and hit the front end good with plastic covers and fender removed. I don't worry about nuking the hubs because I pop off the wheel bearing seals and blow out the old grease and re pack the wheel bearings completely full. Make sure you used brake cleaner on and wipe you brake disk to make sure you do not have any oil or grease on the disk! After you clean things up, ride the bike somewhere clean and bounce the front end hard to stir up the typical grey metallic sludge that will settle on the bottom insides of the fork when the bike is stored. Obviously it is better to change fork oils when the forks aren't freezing cold.
    Before you remove the forks, loosen the top triple clamp screws and loosen the caps. Someone in the past may have thought these must assembled bone dry then gorilla tightened (argh!). I never torque fork caps! I just grease the threads and O-rings and just touch them to the stanchions. They seal by the o-rings and never unscrew!
    My oil change procedure does not require disassembling the fork, only the removal of the caps, preload spacers, and springs. You need to have the springs and preload space out to accurately measure the oil level, which is always done springs out and everything fully collapsed. Also, I typically hold my forks in a vice with a sock around the sliders to prevent scratches to the pain.
    Another helpful detail regards access to the aluminum cap retaining nut to remove the cap when the preload spacer and spring are still in place: Simply compress the spring by pulling the preload spacer down, then cock it under the cap retaining nut (part #24 in the exploded view). That frees both your hands to use two wrenches to remove the caps.
    The trick around special bleeding procedures on closed-cartridge forks is to avoid stroking the cartridge rods any more than barely pulling them up when there is little or no oil in the reservoir around the cartridges, such as after you dump the oil out. I collapse the forks and push the cartridge rods in, then tilt the forks and pour out the oil, observe how dirty it is. I refill the forks with the oil, the same oil I intend to end up using. I overfill them a bit then pull the rod up a bit and hand tighten the caps back onto the cartridge rods without the springs. I extend the forks fully slowly then screw on the caps until the sealing o-ring just passes inside the stanchions. Then I stroke the heck out of the forks against the floor using the trapped air as a return spring. Stroke, slosh, and dump the oil, observing again how clean it is. Repeat until very clean. It's more expensive to use fork oil instead of, say, a kerosene flush, but because of the closed cartridges you must use new fork oil as a flushing agent.
    My oil was clean enough that I only had to bench flush twice to have clean oil. If your oil is really trashed, and it is cleaning up well but not completely, given this procedure is simple, imperfect oil is better than trashed oil. Ride the bike a while to fully exchange the oil in the cartridges and later do the above again. Once you get the oil cleaned up, you should be able to do maintenance every year or two with just the above procedure. A plus about these forks is they come with great seals. I have seen forks with many impact damaged stanchions that have been smoothed and filled with fingernail polish and don't leak. I have three very slight small damaged areas and no leaks. Whatever they coat the aluminum stanchions with is pretty amazing stuff. I found the substance will smear up onto damaged areas and provide protection.
    I hope this has helped simplify the mysteries of these forks. If I missed something, please chime in.
    arroyo and Hatch like this.
  2. Bronco638
    Bronco638 Nobody Home
    Dec 1, 2004
    5,635
    Elk Grove Village, IL
    Does this apply to the forks on my Climber?
    If so, I can provide an exploded view of the forks and you can alter your instructions so that it corresponds to the numbered parts in the view.
    Any idea how the recommended oil amount (266cc or 9 oz.) measures?
  3. motobene
    Mar 9, 2013
    7,081
    I just completely edited the above to make it clearer and more educational. While the above regards right-side-up modern closed-cartridge forks, it would not hurt to read what I've written.
    You mean the exploded views like below?
    You'd be dealing with the forks similar to modern Marzocchis, from the cap side up, so the oil level issue is similar (or just go by volume in your case).
    This thread is about the modern Marzocchis, not the Marzocchis used briefly during the USD for craze on GasGas and Aprilia, but I will help you out a bit here as long as this doesn't take off into an Aprillia suspension thread:
    These are open-cartridge style and had a reputation for leaking seals. I fixed one of these set of forks by alterning a set of new seals. I removed and unscrewed the fork seal lip spring (look for the joint and direction of turn), then shortened the length by carefully cutting off the non-conical end, then screwing the spring back together and refitting it to the seal before installing the new seal. This increases lip compression, which helps extend seal life. As I suggested to you elsewhere earlier it would be bets to find modern SKF seals for the fork as the older seals were crap. You just need to know the metric inner, outer, and thickness of the oil seal #22 and wiper #20. Even if you can only get the oil seal you'd be much better off. It really sucks to re-do these fork only to have them piss oil again on your front brake pads within a year!
    This guy also dealt with what you are dealing with:
    http://www.advrider.com/forums/showthread.php?t=870426
    Here is one more pic:
    ...what I wrote about the Gasser forks about the method will apply to the oil level, only you will be working from the machined aluminum upper part and cap pointing up instead of from the smaller stanchion. You'll need to find out what the oil level is or some volume spec for that particular fork, and 266cc sounds on the low side to me, but above it shows 225cc....
  4. motobene
    Mar 9, 2013
    7,081
    What about the bleeding procedure? None of you so far has posted anything, so I will post what I have. The following is an Italian writing in English, and I laud that effort, but I found it hard to figure out. I spent a little time editing the text as I recall, but gave up as there were too many things to correct. But hopefully if you need it, and have the parts in hand, it will make sense. Again, if any of you find a better written procedure or a link to pix, please post:
    Ciao, it's a plesaure help you with your fork. I'm racing Dep. For Marzocchi and I support Supermoto, Motocross, Freestyle, Enduro, Trial. Your Trial Fork, it's a 40mm. Marzocchi which uses 7,5wt oil.
    Oil level : 140 mm (5.51”) in both legs (previous from GasGas USA says 160mm (6.3”). (as I said above, I trusted 6" a bit more and that works just fine)<?xml:namespace prefix = "o" ns = "urn:schemas-microsoft-com:eek:ffice:eek:ffice" /><o:p></o:p>
    <o:p> </o:p>
    Right (rebound side). You need to make a vacuum by first flipping the cartridge upside down.
    1st) put the cartridge upside down and put the oil inside and start make a manual
    vacuum (push the shaft up and down and release the air inside)
    2nd) put oil level to the small hole (up to the tube) and put inside the flooting piston (put grease in the teflon ring) without the screw (take easy because the oil can coming outside ........ In your face!!!!)
    3rd) push the flooting piston to 60mm. (From the top of cartridge ..... With out the small screw) and make 2/3 time up and down with shaft (if you have a air .... Use torche for take out)
    4th) push the flooting piston to 70mm. (10mm. More) and close the hole with a small screw)
    5th) put spring and cap.
    6th) push the shaft wide inside and you will see the extra oil coming out side from the small hole in the cartridge
    Put all togheter and make oil level .... In both legs at 140mm.
    <o:p></o:p>
  5. Bronco638
    Dec 1, 2004
    5,635
    Yes, I was asking if this was (specifically) about the USD Marzocchi forks on my '93 Climber. It is not but I can/will benefit from reading/understanding, thanks.
    Yes, I have an exploded view, of my USD forks, from Mike (Tryals Shop). Since this post is not specifically about those forks, I'll not post an image here (but I do have one). :D
    The 266cc (9 oz.) of fork oil, per fork, comes from Mike (Tryals Shop). He suggested I go with 10w in cooler weather and switch to 20w (dampening side) and 5w (rebound) in warm(er) weather.
    :thumb
  6. the toe cutter
    the toe cutter Adventurer
    Apr 14, 2009
    91
    East Bay CA
    Thanks motobene, regarding dumping old oil what are ur thoughts on removing the bolt located at bottom of the fork legs?
  7. motobene
    Mar 9, 2013
    7,081
    Those aren't oil drain plugs but rather THE one bolt that holds the forks together and the two together keep the front wheel attached to the rest of the bike. With a fork minus cap in hand you simply tip and pour out.
    If you aren't replacing fork seals you should not be removing that bolt, especially when the forks are still on the bike :eek1.
  8. motobene
    Mar 9, 2013
    7,081
    Is not your image the same as the one above? If not, please post it here just to round up the issue, thanks.
    #8
  9. Bronco638
    Dec 1, 2004
    5,635
    It looks similar to the GagGas exploded view in your second post (Post #3). And, appears to be identical to the white print at the bottom of the same post. Mike sent this to me as a PDF and I exported it to PNG. This is just the exploded view, there's an associated parts list, too. If anyone would like to have either the PDF or PNG files, let me know.
    #9
  10. andilicious
    andilicious Adventurer
    Feb 1, 2014
    70
    Hi Guys,
    I stripped my forks for the first time and I am not sure the previous owner had the correct cartridge in the correct fork tube!
    So......
    Can someone confirm which is the compression cartridge and which is the rebound?
    Thanks,
    Andy
    #10
  11. motobene
    Mar 9, 2013
    7,081
    My educated guess is the rebound is be the one on the left with the series of holes that dump fluid on the up stroke.
    You can also tell by flooding a fork tube with any oil and push and pull on the rods by hand. Rebound will offer little resistance during compression.
    Were you able to get the modern greenish looking SKF seals and wipers for these forks? If not wipers, then just the green seals are a big step up.
    Don't forget fork seals need 'butter' like light grease on the lips during reassembly or the lips can get skid damaged during the first fast strokings.
    #11
  12. Barnman
    Barnman Been here awhile
    Oct 6, 2010
    279
    'up north England
    I have just stripped my forks down for a service (bushes, oil and seal) and found my way to this thread. Like Motobene I have found on line info quite sparse.
    The stripdown was straightforward, but watch out for the little ball bearing if you take the clicker spring out. :D That little thing had me on my hands and knees with a torch
    I may be wrong, but would suggest the fork on the left is your compression damper. I think the holes on the tube are to let the oil flow easily when on rebound and provide little damping. The piston and valve shim works when it is pressed down, and you can see the bypass hole being opened or closed by the adjustment rod.
    Also, on mine the adjuster on the top has 'C' for compression engraved on it :D. Looking at the state of the oil from the previous owner, I don't think he has ever changed the oil, never mind had them apart, so I would guess the cartridges are as installed by the factory.
    Just waiting on my replacement bushes to arrive, and then I'll get on with the rebuild and bleeding. If you want any pictures of them apart now would be a good time to ask
    #12
  13. andilicious
    Feb 1, 2014
    70
    Hey guys
    I have the forks back together now and working fine.
    The cartridge with the holes is the compression side. That means the fork was assembled correctly when I got them, albeit filled with pond water not fork oil!
    I filled the rebound cartridge up from the bottom and then assembled it into the fork. It got a bit messy but now I've done it once I should be fine next time!
    Cheers
    Andy
    #13
  14. motobene
    Mar 9, 2013
    7,081
    Thanks for that clarification. Holes can be deceiving:lol3
    Glad they are working well for you.
    #14
  15. HighSideEddie
    HighSideEddie n00b
    Jun 21, 2012
    1
    As so often is the case, despite above average experience with suspension components both front and rear, the closed rebound cartridge on the subject forks are not what they initially appeared (to me) to be. Like others posting here and elsewhere, I encountered "difficulty" in getting the rebound side functionally correct after an oil change. Thanks to all posts on this forum and a few from other forums, I believe I have now closed the loop on the mystery of why the difficulty occurred; how, exactly, the cartridge functions, and how to properly service it. Scroll back to see the photos posted by Andilicious. Clearly, the rebound cartridge is markedly different in construction from the compression cartridge.
    I have created a photo storyboard to illustrate the unraveling of the mystery which you will find below. That being said, in the following I will first make a few personal opinion comments regarding the subject forks for your review and comment. Again, I am thankful and grateful to all the posters to this topic. Without the clues and advice thus obtained, it would have been a long row to hoe.
    Comments:
    1. My comments specifically apply to "later model" Marzocchi forks with 40mm aluminum-stanchion fork legs. These were/are typically fitted to many Gas Gas and other trials models. Comments may apply in part or whole to other models but I don't know which they would be.
    2. It is important to recognize that the theory of operation of the rebound leg of these forks differs markedly from the compression leg. So, what applies to one does not necessarily, and probably does not, apply to the other. The compression damper is an "open" cartridge design that does, indeed, share oil with the oil reservoir contained in the outer fork leg. The rebound damper is a true "closed" cartridge design and, as such, is far more sophisticated in operation and maintenance than the compression side (imho).
    3. The Italian service technician had it exactly right. Technical translations are often buggy because technical terms in a given language are usually conscripted at random from the native language in which they are written and make little literal sense to speakers of another language. That being said, it was a very sensible translation, thank you very much! Change "flooting" to "floating" and you've pretty well got it. With parts in hand, one can immediately see the function of the "flooting" piston. However, how to install (properly), bleed and set the spring preload? This is where the translation was essential. Thanks again.
    4. Shame on Marzocchi, Gas Gas and others for selling stuff and leaving customers high and dry on proper service procedures. Gives me a royal case of red ass I'll tell you.
    5. I make no attempt in the following to explain the theory of operation of the cartridge. I merely attempt to show the factory intended procedure for reassembly and recharging with fluid.
    Storyboard Corresponding to Marzocchi Description (more or less...)
    The promised storyboard for adding fluid to and bleeding the REBOUND cartridge follows. This DOES NOT apply to the COMPRESSION cartridge as the construction is different and, hence, so is the procedure.
    First, and so it can be easily compared with my storyboard, I will now paste Motobene's prior post regarding the Marzocchi technician's translated description of how to assemble and oil the rebound cartridge:
    "What about the bleeding procedure? None of you so far has posted anything, so I will post what I have. The following is an Italian writing in English, and I laud that effort, but I found it hard to figure out. I spent a little time editing the text as I recall, but gave up as there were too many things to correct. But hopefully if you need it, and have the parts in hand, it will make sense. Again, if any of you find a better written procedure or a link to pix, please post:​
    1st) put the cartridge upside down and put the oil inside and start make a manual vacuum (push the shaft up and down and release the air inside)
    Put all togheter and make oil level .... In both legs at 140mm."​
    1. If you have completely disassembled the rebound cartridge, this photo shows all the parts that are to be reassembled. Note that the parts shown are not necessarily arranged in the correct orientation. I didn't think to do that when taking this photo. See the excellent photo's by Andilicious in a previous post. The cartridge on the right hand side of Andilicious's photo is for rebound and is the topic of this post.
    To avoid unnecessary stress on the piston shaft seal, I would recommend that you disassemble the rebound cartridge exactly to the point as shown by Andilicious, i.e. do not pull the piston shaft all the way out of the cylinder as I did because the threads on the piston shaft will abrade the upper cylinder seal to some extent. If you do wish to completely remove the piston shaft, gently use an "unscrewing" motion and unscrew the threads of the piston shaft through the upper seal rather than just jerk the thing through. Suggestion only.
    2. This photo shows a simple jig to hold the cartridge in an upside down position to charge it with oil. It is simply a board with a 1/2" drilled hole that has been clamped to the workbench. You will either need 4 hands, or an assistant or the jig to complete the work and you are still going to get oil squirted in your face.
    3. This photo shows the "bleed" hole. It is a multi-function little bugger and I won't discuss theory behind it. As You can see, it is located about 43 mm from the BOTTOM of the cartridge cylinder. In this photo, the cartridge has been inverted in order to fill it with oil. Duh. Fill the cartridge with oil up to the bleed hole to start. Slowly pump the piston rod up and down a few inches in order to release the few air bubbles that will be trapped under the piston after the initial dry assembly. Be advised that as you move the piston upwards, the oil level will rise above the bleed hole. I simply stuck a finger over the hole to keep it from running out while I was attempting to work. As you will see later on, just fill the cylinder to the bleed hole, more or less. Doesn't have to be precise at this point.
    4. The next photo shows the bleeder screw located in, what Marzocchi calls, the floating piston. Good as name as any. I would call it a deCarbon piston but that is a very long story and we'll save it for another time. Remove the screw and o-ring as shown and set aside.
    5. Now place the floating piston in the top of the damping cylinder as shown. You'll have to compress the piston ring and, maybe, use a light tapping force to get it started. Make double sure that the side that the bleeder screw was removed from is the exposed side as the piston enters the cylinder. It will be necessary to reinstall the screw later in the process so don't mess up at this point.
    6. Next, slowly and carefully tap the piston down the cylinder until it is about 60 mm in. You will note that when the piston contacts the fluid previously installed, first air, then fluid starts coming out the bleed hole and stays on top of the floating piston. Exactly what it's supposed to do. However, it can get messy. If you remove any of the excess fluid as you are tapping the piston down, just be sure to leave some as a blanket on top of the bleed hole.
    At this point (60mm in) the Marzocchi tech recommends slight stroking the piston rod. I recommend against as you are almost sure to get a geyser blowing out the bleed hole. There is no way in hell at this point that there can be any air left in the cylinder. So, be your own judge.
    I will suggest that you use a soft rod of some type to gently tap the piston down with. I'm showing an aluminum rod but almost anything is suitable. If you just try to push the piston by brute force, as I did on the first try, it will jump in increments. One of those increments will be too far and you will have to disassemble and start over. Also, you will have to take a break to clean the oil off your face. The Marzocchi tech was dead right on that point.
    Finally, in this step, tap the piston down to 70 mm depth (or so). The photo shows the piston at the 70 mm depth and also, if you look carefully, you can see the aluminum rod that I've also got crammed in there.
    7. Next step is to reinstall the bleed screw previously removed. Just tighten enough to compress the o-ring by about 25%. No need to squash it and ruin it.
    8. Next, install the spring and end cap as shown.
    9. Finally, install the snap ring, then temporarily using the Allen head screw that attaches the end cap to the bottom fork slider, pull the end cap towards the end of the cylinder which will make the snap ring captive.
    Later Edit:
    Oops!!!!! The careful observer will notice that the photo below is simply a repeat of that shown in Section 5 above. What you should be seeing is the End Cap as shown also in Section 8 above. Sorry, I don't have the correct photo showing the end cap flush fitted into the damper tube and retained by the snap ring. However, it would look very similar to the photo below except substitute the end cap photo for the floating piston photo as shown. Hope I have not overly confused with this faux pax. Ta.
    U are now done with the reassembly of the rebound damper cartridge. Congratulations!
    #15
    Brewtus likes this.
  16. motobene
    Mar 9, 2013
    7,081
    This thread has been about conventional flow-through forks, and also about what is called 'open' cartridge forks, which are also flow through (you just pump the rod to bleed them). The difficulty in bleeding some modern, so-called 'closed cartridge' forks is really a separate issue and thread, but since you put that in here, I'll address them and my current solution.
    Closed cartridge forks also exchange oil with the oil surrounding the cartridge, they just do very slowly. Eventually they will self bleed, but it can take many hours of springy lack of damping and toping out and a WTF reaction.
    I had that happen to me with my Sachs closed cartridge rebound side on my GasGas Econo, and was not at all happy about it. The technology had changed while I was away from it a while. The lack of info on these types of fork is just sad. I tried one time to make sense of what that Italian guy wrote, but failed, so I decided to just steer around the issue.
    I have found modern forks like the Marzocchi and Sachs closed-cartridge designs to be very well made, with few or no uncoated or un plated components that slough off metal particulates at a rapid rate as they slide past each other. As a result, they don't seem to trash their oil fast, and unless you have a bike with a ton of hours, maybe the oil won't be all that nasty. So... I've just been changing the oil in the reservoir around the cartridge, no bleeding required. I'll do it twice or three times if needed, and can do it by just leaning the bike over with the caps out.
    I'll be doing this to Marzocchi forks soon, so I'll get a chance to see how clear the oil is after 22 months.
    #16
  17. Hatch
    Hatch Perpetually lost
    Sep 23, 2007
    4,970
    850
    what a timely thread! Thanks for posting!
    #17
  18. motobene
    Mar 9, 2013
    7,081
    Welcome, Hatch. Kind of a catch-all thread. I noticed my comment just above is out of phase with the thread, and I started it (sometimes I wonder about myself :-). HighSideEddie sure did a great job of posting nice summary and how to. Kudos.
    #18
    Hatch likes this.
  19. Hatch
    Sep 23, 2007
    4,970
    850
    Really the exploded parts diagram was all I needed. Replaced fork seals on a 2010 GG TXT PRO 250. Did anybody ever measure how much oil goes in the forks? Mine drained out about 150mL, but they were leaky...
    #19
  20. lineaway
    lineaway Long timer
    Oct 1, 2011
    11,333
    nm
