May just cry - right cylinder failure and leakage
Discussion in 'Airheads' started by Adam G, Sep 14, 2018.
  1. Adam G
    Adam G n00b
    Jun 26, 2018
    7
    UK
    To keep it short and sweet, I ride my R65 Monolever on certain days to one of my jobs, she's been due a new battery for a while as she's struggled starting, however I go to jump start as I'm now late, take her down the hill. No luck. Turn back around, pushing her all the way to the top, drop her on the right hand cylinder, have to pick her up with a knackered sciatic nerve. Get home etc.
    Buy a new Odyssey PC680 battery, 2x NGK Iridium spark plugs to assist in starting. All installed and the cranking power to start the bike is insane. However, it sounds completely off, try going for some throttle and it the engine dies, switch sparks and see the same issue. Right hand spark plug was covered in oil, fuel, something. Then I look below the bike, drip drip drip, oil coming from the seams of the right hand cylinder and the small boot cover.
    Anyone got any ideas of how bad this actually is - pictures are as follows, excuse the not so amazingly clean bike, been riding it in some bad weather here.
  2. Bigger Al
    Bigger Al Still a stupid tire guy Supporter
    Oct 12, 2004
    10,477
    Auburn, CA
    Do a complete tune up, including re-torquing the cylinder heads and adjusting the valves and go from there. The crankcase vents to the RH carb, so the oily right plug is pretty normal, and the pics show your push rod tube seals are leaking, again a common thing. This doesn't appear to be anything too bad, and it should..................should....be easily remedied.
  3. Solo Lobo
    Solo Lobo airhead or nothing Supporter
    Mar 16, 2004
    12,348
    Shoreline, WA
    Looks to me like you need to do a top-end seal job.
    I'd start with a full tune up, making sure the carb settings are good and you aren't running rich.
    If it is an oil issue, that could be rings or valve guides. How many miles on this bike?
  4. ccmickelson
    ccmickelson MonoMania Supporter
    Dec 11, 2013
    3,103
    Fanta Se
    Maybe it's just the pic or my poor vision, but that spark plug gap looks a tad excessive.
    ME 109 and Uke like this.
  5. TwoShoes
    TwoShoes Carbon-based bipedal life form
    Aug 18, 2003
    642
    Fredericton, New Brunswick, Canada
    ... and you might want to stick a nut on that engine mounting through-bolt, just saying.
  6. Adam G
    Adam G n00b
    Jun 26, 2018
    7
    UK
    She's at 67k at the moment.
    And right that's a good place to start, thanks everyone.
  7. Steve W.
    Steve W. Boxer Pilot
    May 14, 2005
    1,066
    Upstate South Carolina
    crankcase full of gas?
  8. mrclubike
    mrclubike Been here awhile
    Aug 11, 2014
    991
    O'Fallon MO USA
    I second that
    That sure is a lot of oil coming from the cylinder base area
    The iridium spark plugs are a waste of money
    You will oil or fuel foul them way before the wear out
    #8
  9. OdyBandit
    OdyBandit Long timer
    Apr 5, 2014
    2,006
    Central Illinois
    Just wondering if you were having the oil and base gasket trouble before you dropped it on the cylinder?
    #9
    ME 109 likes this.
  10. Beemerguru
    Beemerguru Beemerguru...G/S guy
    Nov 7, 2006
    2,633
    Redwood City, CA
    if it was on the side for a couple minutes, it wouldn't have time to fill the cylinder with anything so check elsewhere.
    Right hand side...take the gas tank off and check the 3 plastic connectors, check the kill switch and the carb cables. Drop the bowls and see if both have gas.
    If more than 3K miles since last tuneup...as suggested above start with the valve reset, check cables and free play, put in a set of NGK plugs, and yes..add a nut/washer to the engine mount so the engine won't rattle around in the frame..and torque both.
    And yes push rod seal weeping is expected with that number of miles...just be prepared because doing a top end on an R65 is not the same as a regular airhead because of the short rods and short cylinders..REALLY hard to get the wrist pin C clip off and on due to space limitation.
    But done right, this is something that lasts a long time.
    #10
  11. Disston
    Disston ShadeTreeExpert Supporter
    Aug 31, 2009
    18,881
    Silver Spring, Md
    Just dropping the bike on either jug rarely does more than scratch the covers. Don't ask me how I know this.
    The missing engine mounting nut is indicative of maybe this bike needs a few loose ends tightened up.
    #11
    ccmickelson likes this.
  12. cycleman2
    cycleman2 Long timer
    Jan 18, 2010
    1,588
    Alberta, Canada
    The oil fouled plug and the oil leaks around the base gasket/O ring don't have much to do with each other. The right side cylinder can tend to get slightly more oil in it because of the way the crankcase tube vents into the airbox.
    Likely what happened is that the carbs dumped some excess gas into the engine when you dumped the bike. If falling over caused all those leaks you have a stud problem. Re-torque heads, and do a tune up adjusting valves etc and see what happens.
    #12
    Mouse likes this.
  13. Richardtheroadie
    Richardtheroadie Adventurer
    May 9, 2017
    26
    Oakland, CA
    When mine leaked like that it was a stripped head bolt. Put in a helicoil and it is back to not leaking. If you are trying to torque the heads and they won’t tighten up you may have this issue. Good luck!
    #13
