Meanwhile back in the shop-Alaska
Discussion in 'Some Assembly Required' started by Fast Idle, Sep 14, 2019.
  1. Kai Ju
    Kai Ju Long timer Supporter
    Jul 29, 2009
    5,180
    Long Beach, California
    You know that there are people charging big bucks for what you do, but their output doesn't match yours.
    Simply amazing...
    AK650, JagLite, sruss67 and 6 others like this.
  2. Garry Mayfield
    Garry Mayfield AHRMA 20z
    Feb 27, 2005
    311
    Southwest United States
    Just in case you run into an unexpected bs deal. and need to share some cussing. Mine today. Simple transmission repair on my Cheney 650 Triumph. As it turns out the motor mounts are welded and the inner transmission case won't come out without removing the engine.
    AK650, JagLite, sruss67 and 4 others like this.
  3. BergDonk
    BergDonk Old Enough to Know Better
    Nov 15, 2010
    16,242
    Snowy Mountains Oz
    That's why God invented angle grinders isn't it?
    Bummer :baldy
    AK650 and JagLite like this.
  4. Kai Ju
    Jul 29, 2009
    5,180
    Yeah, but look at that weld...
  5. BergDonk
    Nov 15, 2010
    16,242
    Snowy Mountains Oz
    CGI :D
    AK650, JagLite, Roadracer_Al and 2 others like this.
  6. Scrivens
    Scrivens Long timer
    Jun 5, 2011
    1,953
    usually the garage
    Classic. Is there room to rotate the engine forward and up if all the mounting bolts are removed? Doesn't look like you need to make much clearance to pop the inner off.
  7. Fast Idle
    Fast Idle Since the Sixties Supporter
    Nov 9, 2012
    4,721
    The Great Land
    A brief detour from the Cobra yesterday to work on the 78 GS1000. Would like to get the new tank together and put on the bike.
    Just temporarily to get it running and check things out. The whole bike will come apart when it gets it's turn.
    The petcock was in dire need of a rebuild.
    Cleaned then soda blasted the parts before installing the K&L kit. Had to re-glue the inlet screen to the body.
    Polished the seat for the vacuum operated valve. It's an o-ring seal. I hate vacuum petcocks but will use it at least for now.
    A little fuel lube on the o-ring and the petcock seals.
    Waiting on new mounting bolts and sealing washers.
    Ordered a new gasket for the fuel gauge sender too. The new tank came with one installed and I'm hoping it works. I'll pull it, check it out and reinstall with a new gasket.
    The unit from the original tank had the wire corroded off.
    AK650, JagLite, sruss67 and 15 others like this.
  8. Wildebeest90210
    Wildebeest90210 Long timer Supporter
    May 24, 2013
    5,734
    In my de-railed TZ thread I spent a post rebuilding the petcock, very therapeutic and on a really small scale as satisfying as building a whole engine !
    I realise we are talking to a niche' group here :D
    AK650, Franque, JagLite and 10 others like this.
  9. Fast Idle
    Nov 9, 2012
    4,721
    The Great Land
    The zinc is back in state, might see it tomorrow or Saturday. Lots of things can start moving once it's here. Have to tell you that our friend @villageidiot has been working overtime making things happen for this build. Many thanks my friend. :super
    Parts cleaning and sorting continues.
    Rear fender parts. All new except the cushion spacers.
    Lots of cleaning to do on electrical parts. Picked the best ignition switch that even has a key.
    It cleaned up well and ohms out good.
    Have new shells for all the harness connectors.
    Put ties wraps on the rubber boot to keep it firmly in place since it is a little weathered. P1070607.JPG
    Not an OEM key but it works. Been looking for a factory pre-cut but nothing out there yet.
    Polished it up anyway.
    There's a washer in the re-plate batch that goes under the nut. P1070623.JPG
    The horn needs a restoration. There's a cool looking chrome grill that's out for plating. I need to get this stuff cleaned up and painted in the mean time.
    The inside looks like new.
    Will have to re-plate some zinc parts.
    Sand blasted and painted on one side. Will paint the other sides tomorrow.
    AK650, JagLite, sruss67 and 14 others like this.
  10. slartidbartfast
    slartidbartfast Life is for good friends and great adventures Supporter
    Dec 23, 2003
    14,073
    Southern Louisiana or Southern England or ...
    Way to go with the details :clap. I've never seen anyone rebuild a horn before. Inspiring!
    Old Smokey, AK650, JagLite and 5 others like this.
  11. Fast Idle
    Nov 9, 2012
    4,721
    The Great Land
    Thanks. Had to on this one, it's pretty rare.
    AK650, JagLite, sruss67 and 9 others like this.
  12. zzzak
    zzzak Long timer Supporter
    Mar 11, 2004
    4,778
    Narrandera
    Just popped out for lunch.
    mike, AK650, JagLite and 3 others like this.
  13. Bowler
    Bowler Been here awhile
    Sep 30, 2012
    157
    Zwolle, the Netherlands
    Where'd you get those shells? I'm looking for new ones for the wiring loom of my GSX1100E(T) :)
    sruss67 and Roadracer_Al like this.
  14. VX Rider
    VX Rider Long timer
    Dec 11, 2015
    8,634
    Phoenix
    Bowler, JagLite, sruss67 and 2 others like this.
  15. pancholasvegas
    pancholasvegas The Gambler
    Dec 7, 2017
    158
    Iowa
    @Fast Idle What kind of spray can paint are you using for the little details like the horn when you paint them? Or do you actually break out the spray gun for little stuff like that?
  16. Fast Idle
    Nov 9, 2012
    4,721
    The Great Land
    I got these at 4into1.com
    Pezz_gs, Bowler and JagLite like this.
  17. Fast Idle
    Nov 9, 2012
    4,721
    The Great Land
    I cheated and used Krylon All In One. Too much effort to set up the paint booth and break out the spray gun. :photog
    But it is good paint for something like this. May not be catalyzed but it holds up very well. And this bike will live an easy life. :-)
    AK650, JagLite, 3legs and 6 others like this.
  18. Roadracer_Al
    Roadracer_Al louder, louder, louder!
    Aug 5, 2007
    2,738
    Oakland, CA
    I'm curious, what will become of the rusty gas tank? I have a project in mind -- I want to make an aluminum replica GS tank for a bike I'm building. I could use it as a pattern if it's too shagged to be useful as a gas tank.
    Richarde1605, AK650, JagLite and 2 others like this.
  19. sruss67
    sruss67 Been here awhile Supporter
    Aug 2, 2009
    419
    Devonport, Tasmania, Australia
    This thread is inspirational on so many levels, just saying :-)
    Scoozi, busa1300, AK650 and 5 others like this.
  20. Fast Idle
    Nov 9, 2012
    4,721
    The Great Land
    Not sure yet Al. It's nice & straight other than being full of holes.:photog
    I still think it could be a good usable tank once lined with epoxy. But would I ever need it? Who knows.
    I'll have to think on it.
    AK650, JagLite and villageidiot like this.
