Meanwhile back in the shop...
Discussion in 'Some Assembly Required' started by Fast Idle, Sep 14, 2019.
  1. DiggerD
    DiggerD DougFir from SuperDuke Days
    Mar 14, 2013
    4,366
    Mid Wet Or A Gun
    This thread goes along with the fixings.
    https://advrider.com/f/threads/macgyver-repairs-thinking-outside-the-box.1406621/
    #41
    Fast Idle likes this.
  2. zzzak2
    zzzak2 Been here awhile
    Mar 27, 2019
    114
    Narrandera NSW
    Chain clip was on backwards, w00t w00t, for cleaning mildly rusted parts try a brown vinegar bath.
    #42
  3. Fast Idle
    Fast Idle Since the Sixties Supporter
    Nov 9, 2012
    2,454
    The Great Land
    There seemed to be no end to the things that needed to be fixed on this bike. Beginning to see why the PO decided to let it go and move on. But that's ok, I like doing this kind of stuff.
    I noticed the stator cover was cracked in multiple spots when setting the timing. Easier to find a replacement than to repair. There were a number of the Suzuki twins that shared some common parts with this bike so there where many covers to choose from at affordable prices. The clutch cover also had a bad crack with a gnarly repair. Not worth screwing with it.
    Covers ordered and time to move on to the next issue. If you look close at the kick start you can see the top pivot had been brazed together in the folded out position.
    Well the kick start seemed to be a very rare part. All the low pipe bikes had a different one that pivoted at the bottom and easy to find one. The scrambler version pivoted up top. Could not find one.
    And being a left hand kick it would probably be tough to find a substitute so this ones going to get repaired.
    First step was to melt off the brass and get the pieces separated.
    Once that was done you could see the original damage.
    Had to weld up the crack on this piece and build up the pivot stop on the other.
    Now the parts just need to be filed and fit.
    #43
    OV10, JagLite and Pezz_gs like this.
  4. Fast Idle
    Nov 9, 2012
    2,454
    The Great Land
    While the low pipe bikes had chrome kick start levers this one was zinc plated. It will be cheap as easy to make it look good again.
    Scrounged up some springs, bearings and a snap ring to finish it.
    Looking at this picture I can see I did this earlier on. CRS is real!
    #44
    OV10, MrGoodwreck, JagLite and 7 others like this.
  5. Fast Idle
    Nov 9, 2012
    2,454
    The Great Land
    Got the engine case cleaned up best I could with it still in the bike. All the rear chrome parts went back on as did the stock air box. Going to touch up the frame here and there but no plans to take it all the way down and powder coat. This bike will have the survivor look.
    Replacement engine covers showed up and are in great condition. They just need the old clear coat removed and then some polishing.
    Time to start on the front of the bike.
    #45
    JagLite, TasTiger, AK650 and 6 others like this.
  6. Fast Idle
    Nov 9, 2012
    2,454
    The Great Land
    Someone must have had a lot of fun on this bike back in the day. There's ample evidence of a few spills and a couple of hits to the rims. But overall it's still in good shape. It's starting to look better and better as it gets cleaned up. Could it have been the electrical meltdown that forced it into early retirement? It was last registered in 1977 with 2607 miles on the clock.
    At least it was stored fairly well after that.
    Decided to go ahead and rebuild the wheels then put some new rubber on. Each rim was out of true and had a little hop to it. The spokes were mostly seized up so I sourced some new ones out of Thailand. Could not believe how fast they got here, like 5 days.
    I straightened the rims best I could. They aren't perfect but much better than they were. I did look for better ones but everything out there was worse than these. The chrome on them is good other than some scratches. No pitting which is kind of amazing.
    Cleaned and polished the hubs before lacing. The brake drums were both in nice shape. All the brake parts got cleaned up and fresh lube on the cams. The chrome on the brake arms was all good too.
    Spooned on some new trials tires.
    Went through the forks and installed new seals and dust boots.
    #46
    OV10, yamty175, MotoChris521 and 7 others like this.
  7. r60man
    r60man Long timer
    Mar 14, 2013
    1,818
    Robesonia PA
    New shoes always make a bike look great.
    #47
    yamty175, AK650 and JagLite like this.
  8. Fast Idle
    Nov 9, 2012
    2,454
    The Great Land
    Indeed they do.
    And trials tires always look great on a vintage scrambler!
    #48
    OV10, yamty175, AK650 and 8 others like this.
  9. bigride
    bigride n00b
    Dec 17, 2018
    8
    San Francisco
    Can you give us any instructions on removing the clear coat and polishing the cases? My 2004 Triumph engine cases needs help. Do you use chemical stripper and a polishing wheel?
    The bike is looking really good, as usual
    #49
  10. Fast Idle
    Nov 9, 2012
    2,454
    The Great Land
    I sand off the clear coat. Haven't had much luck with strippers, er, paint strippers I mean.:photogBut maybe that's because all the clear coated parts I've tried it on are really old.
    I'm sure there are easier ways but I'm usually dealing with stained covers so sanding is necessary anyway to get to fresh metal. On covers that aren't rashed up I start wet sanding with 320 or 400 grit. Then 600, 800, 1000, 1500, and finally 2000. After the wet sanding I buff them with automotive buffing compound like Mother's. Final shine is by metal polish of your choice. My favorite is Simichrome. Been using it for like 50 years! Lots of others to choose from too.
    It can be a lot of work for sure and takes a lot of elbow grease but it's totally doable without any special equipment. It brings them back to an OEM shine, not quite a show shine.
    If the cover isn't stained, rashed, or clear coated you can jump ahead. Just the Simichrome alone brings out a deep shine on aluminum. Polish by hand with a rag and then buff with a clean terry cloth.
    On road rashed covers I've started with files and/or 80 grit on pneumatic sanders. Starting with the right grit is important in saving you time and effort. Look at post #43 in this thread.
    https://advrider.com/f/threads/1968-triumph-street-tracker.1159194/page-3
    #50
    OV10, AK650, Pezz_gs and 3 others like this.
  11. willis 2000
    willis 2000 neo-quixote
    Oct 15, 2011
    4,821
    idaho
    Your rear brake cam may be off a notch, or the shoes are worn. Touchy setup with that brake arm angle.
    Edit, that brake arm is too short, oe or not.
    #51
  12. Fast Idle
    Nov 9, 2012
    2,454
    The Great Land
    Finished cleaning the bike up and fixing all the little things. Time to roll her outside, add some gas, and see if she'll fire up.
    #52
    OV10 and JagLite like this.
  13. Fast Idle
    Nov 9, 2012
    2,454
    The Great Land
    I road around the block a few times and it's all good so far. She's got some pep for a little 250. All the gears are there and it shifts well.
    Nice looking bike. If only she had an original paint tank.
    Even the stock seat cover is in decent shape although the foam has shrunk a little.
    The tach has a small chip in the lens. Other than that the instruments look pretty nice.
    I like the curve in the handlebar cross brace. At first I thought they might be bent but that's how they came new.
    Threw on some old mirrors for now.
    Repainted the center stand and footpegs. They were all rusty. Then installed new OEM rubber.
    I might repaint the exhaust down the road or maybe not. It's pretty much time to put this bike away for winter.
    There is one last thing I'd like to finish up though...
    #53
    OV10, Damian_74, busa1300 and 7 others like this.
  14. Fast Idle
    Nov 9, 2012
    2,454
    The Great Land
    Back when I first got this bike I went online to look for a replacement cylinder head. I couldn't believe it when I came across this.
    A stock paint tank! Yahoo!
    Nice looking tank with only one tiny ding but there is an issue with it. There was a botched repair on the petcock nipple. Looked like someone tried to weld it with a wire feed and welded over half the threads on the nipple. It was buggered up and unusable. They burnt off some of the paint as well. You can see it got the decal a little too.
    No worries, I got it cheap and it will get repaired. The bike looks so much better with the original paint tank.
    My good friend and fellow inmate @AK650 is going to make a repair nipple for me.
    The old nipple will get cut out and the new one welded in.
    #54
    OV10, MrGoodwreck, 3legs and 8 others like this.
  15. JagLite
    JagLite Long timer Supporter
    Jun 17, 2010
    7,747
    Anchorage Alaska
    Fantastic score!
    Stock paint looks so much better. :clap
    #55
    AK650, 3legs and Fast Idle like this.
  16. DiggerD
    Mar 14, 2013
    4,366
    Mid Wet Or A Gun
    I think Will is on to something with the rear brake arm.
    My vote is it's off a notch or two.
    Plenty of adjust thread left.
    Oh! You faked us out with the start up vido......No smoke...:lol3:lol3
    #56
  17. Fast Idle
    Nov 9, 2012
    2,454
    The Great Land
    Yep, probably off a notch. The shoes and drum looked great.
    #57
  18. Richarde1605
    Richarde1605 Long timer
    Jan 1, 2015
    3,890
    NSW Australia
    Looks okay to me, it is is a bit under the 90 deg to the operating cable, so about 90 on brake operation.
    #58
  19. more koolaid
    more koolaid Been here awhile
    Nov 5, 2015
    474
    Bel Air Md.
    Feel free to send me your pipes, as I have some 10 yr. old, black bar-b-que paint. [and a wire brush]
    I'll hook you up [PM me]
    So glad your back:clap
    #59
    yamty175, Richarde1605 and Fast Idle like this.
  20. Fast Idle
    Nov 9, 2012
    2,454
    The Great Land
    Looks like @AK650 got the repair nipple made! M22x1.0 thread and some extra real estate to make welding easier.
    Very nice job, thanks Jeff.
    Now I just need to get to town and pick it up.
    #60
    AK650, Pezz_gs, JagLite and 1 other person like this.
