Misadventures in 990 camchain changing
Discussion in 'Dakar champion (950/990)' started by tomdubz, Jan 19, 2020.
  1. tomdubz
    tomdubz getting there Supporter
    Jun 29, 2010
    1,298
    87505
    Decided to take on changing camchains on my 91k mile '09 990. Why would I engage in such torture? Whilst doing a prophylactic water pump rehab I noticed a little piece of broken off plastic jammed into the transmission gear down on the bottom of the sump. I assume this came off one of the timing chain guide rails. Maybe it was the cause of some clunky shifting that I've wondered about recently. Some precision chiseling with a precision screwdriver was necessary to dislodge it.
    For some guidance outside the manual, I've been following this:
    http://ktm950.info/how/Orange Garage/Engine/Cam/camchain/uk_mouse_chain_replacement/uk_mouse_camchain.html
    Stumped about how to pull off the highlighted
    Mine seems pretty stuck. Manual has that handsy dude just reaching in and pulling like so:
    Tried that to no avail. I assume I'm missing something.
    Rear is TDC.
    How should I "help" it?
  2. rinho
    rinho Rinho Féroce
    Jul 19, 2009
    1,720
    back in France but Soul still in North America
    Am I not understanding something ?
    First pic with the the hand taking the gear off has the comment "up to 2004"
    yours is "09, you need the special tool according to what's written on the same page ("05 and up)
  3. tomdubz
    Jun 29, 2010
    1,298
    87505
    Doesn't that special tool just put it rear TDC so the dots are aligned? Is that when the wheels are retained by each other? Can't turn anything with the locking bolt in. Or were you referring to the bottom pic puller contraption? And have you done this before?
  4. uk_mouse
    uk_mouse Aquatic adventurer
    Jul 20, 2006
    1,948
    UK
    If your engine has the split gear, the spring tension is probably holding it on the shaft. You can probably separate the two gears by getting a flat screwdriver between them and prising them apart. Careful as the spring might ping out when you do this.
    Assuming you've taken the cams out at this stage, I don't think it matters whether the engine is TDC or not. But there's no reason for it not to be. As long as everything is correctly aligned when you reassemble.
    thirsty 1 likes this.
  5. rinho
    rinho Rinho Féroce
    Jul 19, 2009
    1,720
    I thought you couldn't remove the wheel, but the tensionning wheel is not apart yet... my message is then irrelevant.
    tomdubz likes this.
  6. tomdubz
    Jun 29, 2010
    1,298
    87505
    Ooo the originator:
    Instead of the prising, I wound up using a beefy circlip plier. I'm afraid of sticking screwdrivers in a motor without that being articulated somewhere in a manual. One end on the spring indent and one on the sprocket's convenient hole. A good sqeeze made the spring shpoing. That'll be fun to get back together.
    Now, for my next trick, I'll figure out how to pull the balance shaft weight out. That seems pretty stuck as well. Manual eludes to using special tools (primary gear extractors) if you can't pull out by hand. I've got 59029021044, but that seems pretty useless in this application. Maybe I need to find something like 60029033000 that isn't +$100?
    Anyone got any better ideas?
    And I think it's time to change this thread title so you can all hold my hand while I bumble through the rest of this.
  7. tomdubz
    Jun 29, 2010
    1,298
    87505
    Ok. So, prying with a seal puller worked to get the weight off. Prying the center from behind.
    Now I'm stumped on the woodruff key. Soaking in penetrating oil now. Any advise?
  8. Boatman
    Boatman Membership has it's privileges ;-) Supporter
    Mar 9, 2005
    14,139
    Mill Spring, NC
    A couple taps straight to the end of the key with a flat faced drift should pop it out.
    #8
    tomdubz likes this.
  9. tomdubz
    Jun 29, 2010
    1,298
    87505
    That worked for the larger one for the weight. More like whacks than taps. I chickened out with the smaller one for the sprocket. I was afraid of marring the bearing and felt like the drift I had wasn't long enough to get in that angle comfortably. Maybe with the motor out of the frame this would all be easier.
    I was able to get the front cylinder chain out as articulated in post #8 here: https://advrider.com/f/threads/camchains-woodruff-key-stuck.619227/ and then I was able to get the new one back in too. Little bit of a rat fuck but it twerked.
    To remove, start turning counter clockwise while gently pulling with it like this:
    #9
  10. tomdubz
    Jun 29, 2010
    1,298
    87505
    Well, this was vindicating. Tip of rear cylinder guide rail had broken off. That was the little plastic bit on the bottom of the sump. A simple check would be to peek next to the balancer shaft weights and see that your tips are still there. Old broken on the left replaced with the complete on the right.
    #10
    Crazygreek and ElwoodBlues like this.
  11. uk_mouse
    Jul 20, 2006
    1,948
    UK
    Crap! I had the exact same thing happen, except in my case, the snapped off bit of plastic got caught in the cam chain, caused it to skip some teeth, and destroyed the engine.
    Good catch!
    #11
    tomdubz likes this.
  12. tomdubz
    Jun 29, 2010
    1,298
    87505
    If you're ever trying to finger out how to preassemble the spreader drive start by consulting the manual (5-14).
    Of course, it says you need special tools. You don't really. In the vise are a two appropriately sized and spaced sockets (one shimmed to make up difference). Rest the drive wheel's holes on the socket, have the wife hold it down, and spin the top bit with a pin spanner (not sure if that's what it's called). Use anything as a pin to hold them together. Something large enough to take up most of the hole worked better than something smaller. That same pin spanner majigger works for fork caps and holding the water pump wheel.
    It was a bit of a challenge getting the whole assembly back on the balancer shaft. I had to pinch and press them together while jiggling the pin just right in order to get them on without having to remove the primary pinion. I mean who has a 46mm socket lying around anyway.
    #12
    Crazygreek and Boatman like this.
  13. tomdubz
    Jun 29, 2010
    1,298
    87505
    In other snews, I made this shitty video. I think these are all normal clickety clacks, but I don't remember. Anyone want to tell me either way.
    #13
  14. uk_mouse
    Jul 20, 2006
    1,948
    UK
    I'm not sure I like the sound of that, but it's very hard to tell what the "clack" noise might be.
    Are you sure it wasn't your ratchet you were turning the engine with? :)
    #14
  15. ElwoodBlues
    ElwoodBlues Been here awhile
    Jun 13, 2017
    164
    Flatland
    Difficult to hear on the video. Is the engine turning the correct normal way around? And maybe pull the plugs and turn it without compression, maybe it’s better heard that way.
    #15
  16. tomdubz
    Jun 29, 2010
    1,298
    87505
    #16
  17. tomdubz
    Jun 29, 2010
    1,298
    87505
    Whelp, maybe I should've listened to the try turning it over without the plugs in.
    Won't start. Hearing a chuff sound from the throttle bodies. Will try to take a shitty video.
    Things that were done in addition to timing chains: plugs, valve adjust (1 intake on rear cylinder), water pump, starter o ring.
    Fuel pump works. Spark plug cap things are hooked up correctly. Battery charged.
    Where should I begin?
    #17
  18. tomdubz
    Jun 29, 2010
    1,298
    87505
    Here's a video
    Got it to kind of start once I hooked the throttle up and turned it a little while hitting the button
    Stinks of gassy exhaust. Strangely, the front header is hotter than the cold rear after just a few seconds of running.
    #18
  19. tomdubz
    Jun 29, 2010
    1,298
    87505
    I think this is where I fucked up
    I misread the order of things here. First I put front cylinder TDC, removed cams, then put rear TDC, removed cams, and then proceeded with timing chain stuff from there.
    Was I supposed to do rear first, then front, then put it back to rear before proceeding? If so, how do I recuperate from my present predicament?
    #19
  20. uk_mouse
    Jul 20, 2006
    1,948
    UK
    It doesn't matter what order you took it apart, what matters is how you put it back together!
    I wonder if you've not given the crank an extra turn when going from rear TDC to front TDC on reassembly.
    Check the manual, but the order of reassembly is:
    set rear TDC and put the rear cams in
    turn engine 360 + 75 degrees anticlockwise to find front TDC
    put the front cams in
    #20
