Mitas Tyres
Discussion in 'OZ Vendors & Flea Market' started by Beet, May 21, 2011.
  1. Beet
    Beet adventurer
    Nov 26, 2005
    2,674
    VIC. AUSTRALIA
    wow that was one of the hardest tyre changes Ive done. I just hope I dont get a flat out bush as Im sure ill need a pub near by. On the positive side I did have My Ballard Tyre Levers and all the extras that My shed offers. all the best Beetle.
  2. lentil
    lentil King of the Dad Joke and Senior Status Legume Super Moderator
    Sep 1, 2006
    12,917
    Not Gunnedah
    Over 50, I'm still working on replying :-)
    And beet they are pricks cold but. Ok hot
  3. Flanman13
    Flanman13 Dinosaur
    Jul 11, 2009
    43
    Somewhere in the middle of QLD
    I recently was gifted with a hole appearing in the side of my E08 Rear. Figured "Well, cant exactly fix that." So i rode the 50k;s home whilst leaning up over the headlight.
    75% of the side wall was torn by the time I got home but it was still on the bead. Completely.
    Make sure you get her nice and wet round the edges before slipping on a new one.
  4. BurnieM
    BurnieM Nipple boy
    Sep 24, 2003
    4,104
    Sydney, Australia
    Always do :D
  5. The Bigfella
    The Bigfella Big Adventurer
    Apr 24, 2010
    4,156
    The Golden Triangle
    Only 75%.... mate... get into it a bit harder!
    Sorry to use car tyres to illustrate.... but the top one went at about 150 k... and that was the sidewall (untouched) by the time I stopped. The bottom one went at 170 kph on the main straight at Winton. The tread did a bit of damage to the car. The first one was a puncture. The second one was old rubber. I won't use a tyre that's over 5 years old now.
  6. Beet
    Beet adventurer
    Nov 26, 2005
    2,674
    VIC. AUSTRALIA
    More info - DR650 and it was actually getting the e09 on the rim, mainly the rear, what a battle, I ended up using a G clamp to asist. Popping the bead was simple enough, love the CRC. all the best Beetle
  7. Mitas
    Mitas caretaker
    Jun 8, 2011
    284
    Germany
    what was the dimension of the rim ?
  8. clintnz
    clintnz Trans-Global Chook Chaser
    May 17, 2004
    4,671
    Rotoiti, North Is, New Zealand
    If it's a std DR650 it would be 17" - The DR rears are well known to be tight at times.
    I've put a few of each E0-7 & E0-9 on the 18" rear of my 640 with no problems, similar to fit to any other tyre.
    Cheers
    Clint
    #8
  9. hunter_greyghost
    hunter_greyghost XS650 Allroads Traveller
    Sep 10, 2008
    11,105
    Yass, Australia
    Running a E-07 [18"] on one of my XS' & the bloody thing won't wear out!
    down to the centre 'bar' in the middle of the tread, what's the legal limit one of these tyres?
    Cheers
    Baza
    #9
  10. abhibeckert
    abhibeckert Long timer
    Feb 15, 2010
    1,960
    Cairns, Australia
    Hate to say it, but are you sure you weren't doing something wrong? Like making sure the tyre slips into the centre of the rim on the opposite side to where you're levering?
    The last three of four times I fitted an E0-7 (slightly different tyre of course) it was a piece of cake, even when I was doing it in a ditch with just a couple of short levers and no lubrication of any kind (the only hard part was pumping the blooding thing up again with a tiny hand pump).
    Every time I've ever had difficulty fitting tyre, I realised eventually that my technique was wrong.
    #10
  11. abhibeckert
    Feb 15, 2010
    1,960
    Cairns, Australia
    I don't know for sure, but I believe as long as it won't aquaplane and isn't unevenly worn out, you're perfectly legal. 2mm tread depth or something like that.
    It'll have no grip at all in the dirt, long before it's actually illegal.
    #11
  12. grimripper
    grimripper 1pissanter
    May 23, 2010
    199
    Byron Bay
    Qld Transport says:
    "Each tyre fitted to the motor vehicle must have a
    tread pattern of a depth of at least 1.5mm on
    every part of the tyre that touches the road, and
    must not be fitted with cleats or another device
    likely to damage a road."
    Same for NSW
    #12
  13. bbjay
    bbjay Been here awhile
    Jun 1, 2009
    442
    Frankston
    You spring for a new tyre beet ,, What gives :eek1
    B
    #13
  14. GagsD2
    GagsD2 ...Are we there yet?
    Feb 14, 2010
    1,398
    SW Vic (Aus)
    Got an E-09 Dakar fitted to my DR recently.....I was going to do it myself but when I went to pick it up, I felt how stiff the sidewall was and got them to do it.......and they had a hell of a time also.....:eek1
    #14
  15. Boo82
    Boo82 Been here awhile
    Aug 9, 2010
    394
    Brisbane, Australia
    Lupine and I had been trying ti fit a new EO-9, I think, to his DL1000. Ended up cutting the bead with an angle grinder to get the old one off. Was interesting to say the least. Was lucky we didn't set the fire alarms off in the cycle shop where he works.:huh
    #15
  16. TB650
    TB650 An average punter living the dream
    Sep 4, 2008
    866
    Blue Mountains, Australia
    I fitted an E-09 to my Tenere, it was the toughest tyre I have ever fitted had the sucker in my Mousse changer and all :eek1:huh Best tyre I have run on the Tenere to date but :evil
    TB
    #16
  17. Ando74
    Ando74 Adventurer
    Apr 19, 2011
    47
    Mid north coast NSW
    #17
  18. k0diak
    k0diak Roaming Hun
    Dec 7, 2008
    1,022
    Singapore
    Before I got my current sent, I did a bit of reading on the forum and someone asked the reseller in the US. The official answer from the manufacturer is that once the centre bar has no thread left, it's a goer. But I'll keep using it as well anyways.
    #18
  19. grimripper
    May 23, 2010
    199
    Byron Bay
    See RTA website AUSTRALIA.
    #19
  20. paddyhannen
    paddyhannen Been here awhile
    Aug 15, 2009
    102
    Perth, better side of australia
    Bloody hell! Did you maybe notice that the round black thing may have been a bit easier to spin/ moving the bike forward less effectivley than previously? Traction was designed to make the tyre grip using gravity to fight against inertia during acceleration, braking. cornering and stopping ( optional Extras ?) Referenced in the sub paragraphs of rider survival in a section called "antikamikazefaktorr",( english translation- dont kill yourself or anyone else if you can help it) a specialty division of the motorcycle riders code called" make sure you make it home " or " youre riding on your own so I dont have to fuck up my ride by scraping you off a fkn tree/ truck/ child / cow/ soccer mom on sunday afternoon in red a ford territory that somehow did not see you''.
    If it was that good, buy another one.
    #20
