MITUTOYO dial gauge recommendations?
Discussion in 'The Garage' started by hotwheels22, Oct 11, 2019.
  1. concours
    concours WFO for 48 years
    Dec 2, 2008
    7,420
    NH USA
    Milling will fail.
    As stated previously.
    Those are GROUND to finish.
    Run, Forrest, run.
    A diamond stone is meant to cut HARD metal, which your rotor is not. A stone is used to clean up burrs, SMALL imperfections.
    Run away....
    #21
  2. concours
    Dec 2, 2008
    7,420
    NH USA
    German vendor selling.... ????????
    I’m not familiar with them, BUT, all too often, I see low-rent crap sold as UPGRADE...
    So, be suspicious. The fact you are going through this is a red flag, unless you bent it mounting the tire.
    What part of the OEM rotors performance was substandard?
    #22
    hotwheels22 likes this.
  3. hotwheels22
    hotwheels22 motorrad3DP
    May 29, 2015
    6,180
    austin
    hey man.
    THANKS a lot for your help. i realize my noob status with some of this can be a pain. i try my best. if i miss any points please let me know. for obvious reasons i would like to know this stuff and do it properly.
    OEM brakes on these bikes are notoriously poor braking power. with very long distances required for braking.
    i used the word "milling" but i just basically used it. because i have NO idea how you work on these.
    you ARE making me realize i complained to the company that the rotor felt like it was pulsing and then i ended up forgetting about it. partly because i complained and they sort of put me off and then said i could mail it back. text of this email is below. basically i half got busy with life and half said fuck it.
    but i should address it now and do it properly. ONE thing i am in the process of doing is to get a FOUR PISTON brembo instead of the TWO PISTON brembo on there now. this modification to the OEM would /either/ involve milling off 3.5 mm from the connecting tabs on the brembo where they connect to the fork - OR buying a 13.5mm ring spacer instead of the 17mm ring spacer that is on there now.
    LONG STORY short is i got to wanting to measure the "planarity" of the rotor because i was getting pad hammering that left the brake lever slack after a day of riding.
    so you are saying a diamond stone is a BAD IDEA? are you saying i can work on it using a natural (?) stone stone?
    either way it sounds like you are suggesting i cut bait on the rotor itself?
    THANK YOU
    jonathan
    #23
  4. concours
    Dec 2, 2008
    7,420
    NH USA
    Yes.
    Quit fucking with it. Get a new one.
    #24
  5. hotwheels22
    May 29, 2015
    6,180
    austin
    fucking hell.
    thanks for the great help.
    - jon
    #25
