Mondo Motos Auxiliary Lighting
Discussion in 'Central – From Da Nort Woods to the Plane States' started by Ice Bat, Jul 26, 2019.
  1. Ice Bat
    Ice Bat Been here awhile
    Jun 22, 2008
    128
    Location, Location
    Anyone use these? I know Prop did at one point because he turned me on to them. I don’t believe they’re in business any longer. They don’t respond to email.
    I like them with one major fault. I have yet to complete a trip of 1000+ miles without one or both mounts failing. They fatigue at the bend and break, leaving the light dangling by its wiring.
    Anyone else have this issue? I don’t know if it’s common or something to do with the vibration that’s unique to the crash bars on my GSPD.
    I’m looking for suggestions on a beefier mount that will fit now that I’m down to my last 2.
    Thanks,
    Ice Bat
  2. Tiger993
    Tiger993 Been here awhile
    Oct 24, 2014
    417
    St. Michael, MN
  3. Ice Bat
    Jun 22, 2008
    128
    Location, Location
    Thanks, Tiger. Yes, the MM10s are what I was referencing. Thanks for the link. This must be an issue unique to my setup.
  4. propforward
    propforward PIE!romaniac
    Jun 11, 2009
    14,530
    Central Minnesota
    Probably best just to make custom mounts to replace those brackets. Should be pretty simple - let me know I can help you with that. My own MM10's have been fine, but they are nevertheless not the sturdiest brackets, so we should be able to come up with something better.
    Tiger993 likes this.
  5. propforward
    Jun 11, 2009
    14,530
    Central Minnesota
  6. Tiger993
    Oct 24, 2014
    417
    St. Michael, MN
    I had seen the ADV Monster lights you mentioned on their website and thought at the time that they were a very similar design to the MM10, and might even be identical. Has the ADV Monster version been good lights for you?
  7. propforward
    Jun 11, 2009
    14,530
    Central Minnesota
    They've been solid. Having had both, I'm sure the MM10's are the same unit as these. I've been happy with both types.
  8. Ice Bat
    Jun 22, 2008
    128
    Location, Location
    Thanks Prop. I’m going to contact AdV Monster and get a suggestion as to which bracket he’d recommend based on my experiences the last number of years.
    I may very well be in touch with you regarding fabricating something even beefier.
    #8
    propforward likes this.
  9. propforward
    Jun 11, 2009
    14,530
    Central Minnesota
    Good. I have interesting scotches to test as well. Fabricate first. Then scotch. And dark and stormies.
    #9
    Paper likes this.
  10. Ice Bat
    Jun 22, 2008
    128
    Location, Location
    I can fabricate just about anything you want to hear as an excuse to drink scotch.
    #10
    Paper likes this.
