Monza 10 inch hub cap/cover?
Discussion in 'Hacks' started by kailuasurfer, Mar 17, 2017.
  1. kailuasurfer
    kailuasurfer Dreamer
    Jun 8, 2009
    520
    PNW
  2. Prmurat
    Prmurat Long timer
    Oct 28, 2011
    2,205
    Scottsdale, AZ
    Did you try Watsonian in the US? I just I ordered a few things (luggage carrier/windshield etc) and they are a lot better than the mothership!!! I was thinking of using an Isetta hip cap (already using a tire from it).
  3. kailuasurfer
    Jun 8, 2009
    520
    PNW
    I just found the website - will contact them. "Mothership" is terrible when it comes to customer service - I hope the U.S. folks will be better.
    I was also thinking of switching out my wheel altogether - any experience with this firm for sidecar wheels? http://www.minilitewheels.us/
  4. kailuasurfer
    Jun 8, 2009
    520
    PNW
    BTW, just found a pic of a mag wheel from minilite - FR700 referenced this posting in the Lets see em thread. Not completely sold on the look yet. Would like to try to find a hub cap...
    pops likes this.
  5. Prmurat
    Prmurat Long timer
    Oct 28, 2011
    2,205
    Scottsdale, AZ
    Nice website for wheels... I'll may try as I am not crazy about the stock wheel!! I[​IMG]
  6. kailuasurfer
    Jun 8, 2009
    520
    PNW
    I have the same wheel. My hub cap fell out somewhere between Northern VA and South Carolina. I suspect it ended up in a hub cap heaven - otherwise known as a junkyard.
    What happened to your luggage rack?
  7. Prmurat
    Prmurat Long timer
    Oct 28, 2011
    2,205
    Scottsdale, AZ
    Pic was taken before I got it from Watsonian ... I still have to install the windshield: typically Brit in its complication!!!
  8. DirtyDR
    DirtyDR Dana
    Feb 17, 2003
    3,258
    Avon, Hotchkiss Colorado
    #8
  9. Mr Mark
    Mr Mark Adventurer
    Feb 25, 2012
    45
    Coastal Maine
    Happy to see other Watsonians.......I just picked up an early Monza and was thinking about the hub cap too...mine looks like it went through a chipper.....I'm also missing one mount....Thanks for the link, I will check it out....
    Heres mine, body number D102..(I think, hard to see)..going on a Guzzi or a Yamaha XS 11.. not sure which yet.....
    #9
  10. Mr Mark
    Mr Mark Adventurer
    Feb 25, 2012
    45
    Coastal Maine
    #10
    pops likes this.
  11. Prmurat
    Prmurat Long timer
    Oct 28, 2011
    2,205
    Scottsdale, AZ
    Don't forget to change the wood!! Mine was rotten completely!!!
    #11
  12. TheOtherBart
    TheOtherBart Long timer
    Jan 16, 2006
    3,056
    DeKalb County, Illinois
    Interesting to see this pop up, I'm looking for a hubcap (or better looking 10" wheel) for my Monza too. @Prmurat, any more details about the wood rot and replacement? Specifically where to look, and what's involved with the repair?
    #12
  13. Sidecarjohn
    Sidecarjohn SidecarJohn
    Aug 29, 2008
    890
    Yorkshire, England
    Also, checks the four large mounting bolts which screw through the chassis into the fibreglass body. Over time the body located elements are prone to becoming loose.
    Another worthwhile mod is to weld a steel loop to the chassis under the body around the locations of the two front body mounts. This has a positive effect on stiffening the chassis, something that Watsonian did on later models. See http://www.watsonian-squire.com/monza/
    #13
  14. kailuasurfer
    Jun 8, 2009
    520
    PNW
    Still looking for one...
    #14
  15. Prmurat
    Prmurat Long timer
    Oct 28, 2011
    2,205
    Scottsdale, AZ
    on my Monza, the bottom of the body had some wood sandwiched in the fiberglass... with age and rocks flying the fiber cracked and let humidity get in there.... Can't remember if we tackle it from the inside or outside but you should be able to see on which side the fiber is thicker or not. we replaced the wood and recovered it with fiber. and bolted a diamond plate on the bottom too for rigidity and protection. DMC chose wisely to not use the mounting in the middle of the noise but still was able to fix the sidecar by 5 points to the Tbird. My guess for the hubcap is to try Watsonian...I Did not put any on mine (Don't like the look). The steel loop in the front was an idea I had too... may painter/welder/fiberglass man just forgot about it!!!
    #15
