Mosko Moto Soft Bags for Offroad & Dualsport
Discussion in 'Vendors' started by Sideoff, Oct 14, 2013.
  1. Matt_Mc
    Matt_Mc Long timer
    Jul 30, 2015
    3,818
    Hamburg, Pa
    Everyone there seems to be fit and in shape. I'll offer my services of product tester for the middle aged round shape fat guys group so you can get a better feel for those who will actually be buying this stuff. :lol3
    xit109, D-Train, MtnRubi and 6 others like this.
  2. D-Train
    D-Train Dusty Wessels
    May 1, 2008
    2,316
    Colorado
    That's funny right there!!! :clap:jack
  3. Antikid
    Antikid Been here awhile Supporter
    Sep 28, 2009
    979
    Cincinnati
    those small pants would probably fit my 11yr old son...just sayin...:D
    Snake Oiler likes this.
  4. Didado
    Didado Long timer
    Oct 5, 2015
    1,465
    Amsterdam
    Here's a tip for KTM 690 or husky 701 owners who need to move the R40 forward to fill the gas tank.
    I've been riding like this for almost two years with the R40 and R80.
    Though I use the filler hole in the R80 for gassing up, this system with G-hooks and Kriega loop works like a charm to quickly take the bags off.
    I also modified Perun's heel guards for quick disconnect of the lower webbing without having to slip it out of the buckle. If you crash you could bend the 'g-hook' part of the heel guard. That happened to me but it is no big deal.
    Basically with this setup I never take the webbing out of the buckles saving a great deal of time. I just loosen the lower webbing, take the upper G-hooks out and slide the bag forward to get access to the 701 tank.
    Then you can also use these instead of the Kriega loops and G-hooks. You replace the original webbing with a cut to size of these. The buckles are outside of the bags on top so that you can loosen them without taking the webbing out. Then you slide the bag forward.
    GeeSser, Sl33p3, Abersouth and 7 others like this.
  5. Plebeian
    Plebeian Scruffy-Looking Nerf Herder Supporter
    May 14, 2015
    8,143
    Shoreview, MN
    Any info on the apparel outers' material choice? Or, does that need to stay top secret for a while yet...
  6. Colonal Angus
    Colonal Angus Adventurer
    Jun 6, 2016
    26
    NEFL
    Love what MM’s doing! Killer gear! Currently shopping tank bags. I currently ride a CRF250L and am afraid the Nomad will just be too big? Can anyone shed light on the size of this bag on such a small dual sport? I’ve searched and haven’t found much. I saw somewhere that a smaller bag was in the works. Can you give us some insight on the features the smaller bag will have? Clear map holder, water bladder, etc?
    Also, can the Simple Cinch Straps be used in lieu of the zip tie strap on the nomad?
  7. Plebeian
    May 14, 2015
    8,143
    Shoreview, MN
    I just noticed that there may be an "eVent" logo on the jacket's lower arm. Is that correct? If so, that is good stuff for waterproof/breathability...
    Was not aware that they offered an abrasion-resistant fabric though... At least not sliding down the asphalt at 50 resistant...
  8. SFC_Ren
    SFC_Ren Been here awhile
    Mar 18, 2013
    857
    Salem,Oregon
    eVent is most likely bonded to the inside of the abrasion resistant fabric just like when you see a goretex label on a Klim jacket. Goretex doesn't make an abrasion resistant fabric either. That seems obvious to me.
    303arborist likes this.
  9. Plebeian
    May 14, 2015
    8,143
    Shoreview, MN
    To get the breathability performance, you'd have to go with one of eVent fabric options, then apply abrasion resistant "patches" in key areas. Then, all you have to do is make sure to hit one of those key areas if you go down. :D
    I know that Mosko was planning on having a separate rain layer, but the standard outer was also going to be waterproof. Maybe not as all-day rain proof as the dedicated rain layer with hood.
    easyrider11 likes this.
  10. marcin_gda2
    marcin_gda2 Been here awhile
    Aug 31, 2006
    291
    Milton Keynes, UK
    I did similar modification to my R40 :-) This allows to slide the bag forward for refuelling whithout need of loosening front straps but only Kriega cam straps which are stitched to the rear of the bag.
    Also I have assembled 2 Kriega rack loops the the R40 bag itself which allows to connect Kriega OS-6 pack :-)
    GeeSser, Sl33p3, guavadude and 4 others like this.
  11. marcin_gda2
    Aug 31, 2006
    291
    Milton Keynes, UK
    Some more pictures of R40 Bag plus Kriega OS-6 on Husky 701 :-)
    dfinn, AliveDK, Sl33p3 and 11 others like this.
  12. AdamChandler
    AdamChandler Ascending n00b
    Feb 29, 2016
    10,231
    Hanover, NH USA
    Trying to find a good method of sewing this on..or maybe this is iron on and I don't have to? Advice would be appreciated as I don't want to ruin the bag.
    [​IMG] [​IMG]
  13. jdubb75
    jdubb75 Vicarious Adventurer
    Jan 11, 2008
    2,481
    Deep South(ern) Indiana
    Maybe iron on adhesive tape, or Shoo Goo for a no heat option?
  14. Oddfellow
    Oddfellow Beasty Rider Supporter
    Aug 26, 2002
    1,042
    Austin, Texas
    Take it to your local Shoe Hospital (Cobbler) and have them sew it on for you.
  15. gunnerbuck
    gunnerbuck Island Hopper
    Nov 19, 2005
    6,695
    N.V.I, B.C.
    Coat the patch with Aquaseal and then stick it on, try not to put too much around the edges so it doesn't squirt out... If you get a clamp and 2 small squares of plywood you can clamp the patch in place while the bonding agent dries..
    https://www.googleadservices.com/pa...hUKEwjLmvnI94zZAhUM5mMKHaWXD7EQ9A4IlgE&adurl=
  16. mfaoro
    mfaoro Been here awhile
    May 29, 2008
    286
    the Cascade foothills, WA USA
    Thinking about an R80. What are some of the proposed updates for v3?
  17. D-Train
    May 1, 2008
    2,316
    Colorado
  18. D-Train
    May 1, 2008
    2,316
    Colorado
    :tb:tb:tb
    Sweet set up! Thanks for sharing the details with all of us!
    marcin_gda2 likes this.
  19. mfaoro
    May 29, 2008
    286
  20. D-Train
    May 1, 2008
    2,316
    Colorado
    Most likely 19 but if it is 18 it will be late...
    ScooterNoMore likes this.
